Help With Getting Apple IIc to Function
milry62
Hello everyone, I was able to find an Apple IIc computer from a garage sale with tons of classic game floppys, the original monitor, external disc drive, power supply, mouse, and video modulator. I have never had any experience with vintage computing, but I am more than willing to learn.
It's in kind of a rough state with plenty of dirt and grime, but I am having issues with the hardware functioning. First, the monitor is faded out on the left side so that I am unable to see anything typed there. There are also green lines extending across the screen. Secondly, every time I insert a disc into the drive, the message "check disc drive" shows up at the bottom of the screen. I have even tried triggering the external drive using the "PR#7" command, and it will do one of three things. First, it will simply say "check disc drive" again. Second, it will click and whir for a second, then the internal disc drive will start making grinding noises at a timed interval. Third, the disc will continue to spin, but there will be a series of characters at the bottom of the screen that look like this: X=XX (with the X's representing some letter or number).
Any help finding a solution to these problems would be greatly appreciated. I would love to be able to use this machine for classic gaming, and to learn about classic computing.
Picture of the issue are added: post-47346-0-70142500-1478885917_thumb.jpg
The series of characters at the bottom tells me the system isn't fully reading a disk.
One of the first and simple things I'd try would be to use a known, good, and verified disk to boot the machine. Second, ensure that the drive heads are clean.
Failing that, then it'll be time to look at hardware & chip issues.
Edited by Keatah
I just opened up the machine and did a dumb thing by unseating the keyboard rom chip and breaking two of the legs by mistake :( Now when I boot I am only seeing bars across the screen. Is there anywhere I can buy a new chip?
Don't know off hand. Try google searching. Otherwise you'll need to get a blank rom and burn it. The code is available. Or get someone to repair the chip. Repairing the chip is a cinch - keep in mind the repaired chip will be a little more fragile.
Another idea is to get another //c and keep one for parts. I do that with all my Apple stuff - keep spares and a coupla piles of parts..
Edited by Keatah
You can get rom code from ftp://ftp.apple.asimov.com/pub/apple_II/emulators/rom_images/
.. since I don't know the part number offhand I can't tell you which one. Is it 342-0132-D
Then you need to get a blank EPROM, again, part number needed. But likely a 2716 style.
And finally you need to get EPROM burner, ebay sells them pretty cheap.
All-in-all, it may be cheaper to get another //c and scrap it for parts, or use the one you have now for parts to repair a "newer" unit. Or find someone to do a chip repair and/or general system cleanup.
Such is life with classic computing.
Edited by Keatah
Thank you very much for your responses. I will look into some of these solutions and see what I can do, because I really want to get this system up and running. I am completely fascinated by it. But being a college student doesn't help since I don't have much money[emoji23]
Any insight into why the monitor is acting the way it was in the photo?
Sent from my iPhone using Tapatalk
