Dropcheck Posted November 26, 2016 Share Posted November 26, 2016 Several weeks ago, maybe a month or two back there was a thread about the 1200XL cartridge port and the problems some were facing with some cartridges not fitting. At that time I purposed a simple extension pcb that would hopefully correct that problem. Well it worked, but..... if you tried to use it without support it put a lot of strain on the internal cartridge port. After modifying a 3d cartridge case design I had already started working on, I think I have addressed that weakness. So here's the offer: It consists of two parts. One is hardware and the other is a 3d printable file for the cartridge case that is designed especially for this pcb. The 3d printer files should produce a case like this. Your 3d printer, slicer settings and filament quality will directly affect the quality of this print. One major difference is that I am trying to add a horizontal brace in the form of a pcb hook like in the grey Atari XE cases. In the finished version no lower pin and hole vertical brace will be needed. The 3d model file will be available for download at shipping time of the pcbs to customers. I will be partnering with tf_hh in the production of the pcb for EU customers. This means cheaper shipping costs for those in the EU. I'm going to give Santos a break again this time. He's next up in 2017. Okay for the details: Cost per pcb: $15.00 Shipping for domestic flat rate will be $8.00 for a max of three pcbs.per order Shipping for EU orders will also be $8.00 for a max of three pcbs per order Timeline: Ordering will go live Cyber Monday and last for two weeks. Parts and board ordering and receipt will take up to three weeks. Assembly and shipping should be done by Jan 20th or sooner. As per previous offers ABBUC members will recieve a 10% discount. You must note on the order before submitting your membership #. You may show your support or non support in this thread, but ordering will be done on my website. 5 Quote Link to comment Share on other sites More sharing options...
+Larry Posted November 26, 2016 Share Posted November 26, 2016 Could you post a picture with the extender and the cartridge shell visible (assembled)? Extender is quite similar to the breakout board that you offered? and the cart shell slips over the end to support the extender and provide the "pins" to open the trap door on the brown Atari carts? Presume that in lieu of the DIY cart shell, there is no reason that right-angle extender can't be used (with proper support)? -Larry Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted November 26, 2016 Author Share Posted November 26, 2016 Could you post a picture with the extender and the cartridge shell visible (assembled)? Extender is quite similar to the breakout board that you offered? and the cart shell slips over the end to support the extender and provide the "pins" to open the trap door on the brown Atari carts? Presume that in lieu of the DIY cart shell, there is no reason that right-angle extender can't be used (with proper support)? -Larry I don't have a finished printed case yet and the pcb will not fit the one pictured above. So unfortuanately I can not provide a fitted pcb/case picture yet. The Dual Right Angle cart expansion pcb should insert into this cartridge port extension board bare as well as with the 3d printed case enclosure. Quote Link to comment Share on other sites More sharing options...
gilsaluki Posted November 26, 2016 Share Posted November 26, 2016 I will order this. Quote Link to comment Share on other sites More sharing options...
gozar Posted November 27, 2016 Share Posted November 27, 2016 Is there a reason it's so long? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
tjlazer Posted November 27, 2016 Share Posted November 27, 2016 (edited) Can you make it so the green PCB does now show when it's installed? It looks like it's too long. Edited November 27, 2016 by tjlazer Quote Link to comment Share on other sites More sharing options...
gilsaluki Posted November 27, 2016 Share Posted November 27, 2016 It looks just fine. Thanks for doing this. Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted November 27, 2016 Author Share Posted November 27, 2016 (edited) Is there a reason it's so long? Sent from my iPhone using Tapatalk Can you make it so the green PCB does now show when it's installed? It looks like it's too long. You mean you don't like the cart extending outside the case? While I can shorten it some, the point was to allow the Polish cartridges to be inserted without having to shave them down. Also I like to be able to see where to insert the cart. Once the socket disappears inside the funnel, it becomes more of a feelly thing to get a cart inserted. But I see if you use the 3d printer file to make a cartridge case it does extend the length a bit more. I can shave about 5-10 mm off the length. Edited November 27, 2016 by Dropcheck Quote Link to comment Share on other sites More sharing options...
gozar Posted November 27, 2016 Share Posted November 27, 2016 Here's a picture of the Side 2 cart plugged into an SDX cart plugged into a 1200XL: The SDX cart slot is slightly recessed into the cavity. I don't know which way is better, but I lean toward the "use as much of the cavity as possible" group. :-) 1 Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted November 28, 2016 Author Share Posted November 28, 2016 Update: Order window is now open. Quote Link to comment Share on other sites More sharing options...
Smokeless Joe Posted November 28, 2016 Share Posted November 28, 2016 I'm probably blind, but I'm not seeing where we go to order these. Any hints? Thanks, - Joe Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted November 28, 2016 Author Share Posted November 28, 2016 I'm probably blind, but I'm not seeing where we go to order these. Any hints? Thanks, - Joe The website is in all my posts as my signature. Quote Link to comment Share on other sites More sharing options...
Smokeless Joe Posted November 28, 2016 Share Posted November 28, 2016 Oop! I'm using the mobile version of the forums, which doesn't show any signatures (at least, not on my mobile device). Switching to the full version lets me see everything. Short story: I'm a big monkey. Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted December 2, 2016 Author Share Posted December 2, 2016 Update: Near mid-order window. 4 of 20 have been sold 1 in the US 3 in the EU 1 Quote Link to comment Share on other sites More sharing options...
Timothy Kline Posted December 2, 2016 Share Posted December 2, 2016 Update: Near mid-order window. 4 of 20 have been sold 1 in the US 3 in the EU Good morning, Dropcheck! I just finished placing my order, although I was limited by the cart from ordering more than 3 of the extensions. Thank you, in advance, for all your work and diligence! --Tim Quote Link to comment Share on other sites More sharing options...
sargie Posted December 3, 2016 Share Posted December 3, 2016 I've ordered one - thanks for making this! Quote Link to comment Share on other sites More sharing options...
Xebec Posted December 7, 2016 Share Posted December 7, 2016 (edited) Just here to show support (will order 1) . I have 2 x 1200XLs, and waiting for the right 'mood' to figure out why they're not working flawlessly, and the tightness of the cart port really surprised me.. thanks for making these! And another good use for the homebuilt 3D printer Edited December 7, 2016 by Xebec Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted December 8, 2016 Author Share Posted December 8, 2016 Update: Four days left. 10 of 20 have been sold 3 in the EU 7 in the US Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted December 11, 2016 Author Share Posted December 11, 2016 Update: Last day to order. Need 10 to make. 12 of 20 have been ordered. Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted January 8, 2017 Author Share Posted January 8, 2017 Final update: Board is done. Final shipment should begin this Monday. 3d printer files for the case should be available from my website later on today for those with 3d printers. Your mileage may vary depending on the quality of your printer/slicer program. Definitely I recommend Simplyfy3d for it's flexible support capability if it supports your printer. It's not free, but if you do a lot of printing, it will pay for itself fairly quickly. Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted January 8, 2017 Author Share Posted January 8, 2017 Extra boards are available for purchase now on my website. Quote Link to comment Share on other sites More sharing options...
tjlazer Posted January 10, 2017 Share Posted January 10, 2017 (edited) Nice! I might have to order one. Edited January 10, 2017 by tjlazer Quote Link to comment Share on other sites More sharing options...
+Larry Posted January 10, 2017 Share Posted January 10, 2017 I believe this board is functionally the same as DC's breakout board. So I tested the breakout board with a 1200xl and my old ICD XE cart expander, which gives the added advantage of making cart insertion vertical. Worked fine with several carts I tried. Just need to add support to where the two pieces join. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted January 12, 2017 Share Posted January 12, 2017 (edited) Mail arrived today with a Dropcheck package. Everything looks good, but when ordered I did not know the function of the switch and still some what confused. OOPs wrong thread.. But the extender arrived also.. Edited January 12, 2017 by rdea6 Quote Link to comment Share on other sites More sharing options...
Mathy Posted January 12, 2017 Share Posted January 12, 2017 Hello guys Mine arrived today too. But mine was sent by Jürgen. Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
