Darkhog Posted December 2, 2016 Share Posted December 2, 2016 Anyone know a good one? While googling I've came across CV Tracker, but it seems to be dead and ABC is unintuitive. Should export to C and work with Newcoleco's kit. Quote Link to comment Share on other sites More sharing options...
PkK Posted December 2, 2016 Share Posted December 2, 2016 […] ABC is unintuitive. […] Many scorewriters can export ABC or export some format for which a converter to ABC exists. Philipp Quote Link to comment Share on other sites More sharing options...
youki Posted December 2, 2016 Share Posted December 2, 2016 I made my own tool that generate code in C compatible with newcoleco toolkit . if you want try. But i give no support for that , it is not very advanced. http://atariage.com/forums/topic/249418-we-could-really-use-a-playmusic-command-for-c-language-hint-hint/?p=3448654 Works on windows XP. Quote Link to comment Share on other sites More sharing options...
Darkhog Posted December 2, 2016 Author Share Posted December 2, 2016 I see... Too bad it's French-only and lacks noise channel support (needed for things like drums, hihats in particular). Quote Link to comment Share on other sites More sharing options...
nitrofurano Posted December 25, 2016 Share Posted December 25, 2016 (edited) Vortex Tracker ( http://bulba.untergrund.net/vortex_e.htm ) is still the very best i know up to now (and it works fine on Wine, which is really great for GNU/Linux-only users like me) - it’s designed for ay-3-8910, but i think it’s not that hard converting the data generated from that (its default file format is txt-based tracker file) to sn76489 Edited December 25, 2016 by nitrofurano Quote Link to comment Share on other sites More sharing options...
NoelleAmelie Posted April 27, 2017 Share Posted April 27, 2017 Sorry if this is a bit of a necrobump but there's actually a proper SN7 tracker out there, based on Famitracker. https://github.com/HertzDevil/SnevenTracker/releases/ Not sure if there's a way of playing SN7 VGMs on the Coleco, but if there is or someone makes one then you could play music made in this on a real Coleco (or any other system that uses the SN7). 2 Quote Link to comment Share on other sites More sharing options...
digress Posted April 27, 2017 Share Posted April 27, 2017 It' sa real nice interface. The included sample file sounds great. Can it import any music types? There is a way to play vgm music on coleco so an expeort to a vgm file would be great. Can this open say nes files and convert them to sn7. Sorry if this is a bit of a necrobump but there's actually a proper SN7 tracker out there, based on Famitracker. https://github.com/HertzDevil/SnevenTracker/releases/ Not sure if there's a way of playing SN7 VGMs on the Coleco, but if there is or someone makes one then you could play music made in this on a real Coleco (or any other system that uses the SN7). Quote Link to comment Share on other sites More sharing options...
NoelleAmelie Posted April 27, 2017 Share Posted April 27, 2017 (edited) It' sa real nice interface. The included sample file sounds great. Can it import any music types? There is a way to play vgm music on coleco so an expeort to a vgm file would be great. Can this open say nes files and convert them to sn7. There's no import function last time I checked, nor is there a way to convert NES music to SN7 music. You could always make a cover by ear though like most people have done (I linked one below). I might give that a shot sometime if I can be buggered to learn another chip to compose on Edited April 27, 2017 by Noah120 Quote Link to comment Share on other sites More sharing options...
youki Posted April 27, 2017 Share Posted April 27, 2017 It' sa real nice interface. The included sample file sounds great. Can it import any music types? There is a way to play vgm music on coleco so an expeort to a vgm file would be great. Can this open say nes files and convert them to sn7. There is an export to VGM alreayd, i just tested. go to Tracker Menu , and Log VGM file. Then start playing the music , when you stop , you will have your VGM file. The issue i have with SGM file for colecovision is that a music take too much rom space. At least with raw VGM . Quote Link to comment Share on other sites More sharing options...
digress Posted April 27, 2017 Share Posted April 27, 2017 Is there a location of more music to listen to or open in the program so I can get some ideas how they created that song. That gyruss version for example or similar. There's no import function last time I checked, nor is there a way to convert NES music to SN7 music. You could always make a cover by ear though like most people have done (I linked one below). I might give that a shot sometime if I can be buggered to learn another chip to compose on Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 27, 2017 Share Posted April 27, 2017 The issue i have with SGM file for colecovision is that a music take too much rom space. At least with raw VGM . I don't know about the SGM part of that, but raw VGM is why I created a compressor. (If it's using the SGM sound chips though, it won't help.) http://www.harmlesslion.com/software/vgm I've also got a really really hacky (but functional) NES to VGM converter. It runs in a hacked Winamp plugin and spits the raw data out to the debug console, so it's non-trivial to use. But the results are decent - PM me if you want it (and understand what I said well enough to use it ). 1 Quote Link to comment Share on other sites More sharing options...
youki Posted April 27, 2017 Share Posted April 27, 2017 I don't know about the SGM part of that, but raw VGM is why I created a compressor. (If it's using the SGM sound chips though, it won't help.) http://www.harmlesslion.com/software/vgm I've also got a really really hacky (but functional) NES to VGM converter. It runs in a hacked Winamp plugin and spits the raw data out to the debug console, so it's non-trivial to use. But the results are decent - PM me if you want it (and understand what I said well enough to use it ). Thanks , i will surely try your compressor and playback routine. i know your NES to VGM converter plug'in for winamp. It is what i used for music and sound of Gnz in 2008. I had never realised that the output bytes was VGM in fact. .. lol!! Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 27, 2017 Share Posted April 27, 2017 Thanks , i will surely try your compressor and playback routine. i know your NES to VGM converter plug'in for winamp. It is what i used for music and sound of Gnz in 2008. I had never realised that the output bytes was VGM in fact. .. lol!! Ahh! I knew someone had gotten that.... but you're right, that's not VGM format, that's just the raw sound bytes. if you want a version that DOES output VGM, then, I'll be happy to hack that together. I'd been planning it anyway. (Disclaimer: IF I can still build the code for the plugin... my system has updated a few times and I can't build some old code anymore.) 1 Quote Link to comment Share on other sites More sharing options...
youki Posted April 27, 2017 Share Posted April 27, 2017 Ahh! I knew someone had gotten that.... but you're right, that's not VGM format, that's just the raw sound bytes. if you want a version that DOES output VGM, then, I'll be happy to hack that together. I'd been planning it anyway. (Disclaimer: IF I can still build the code for the plugin... my system has updated a few times and I can't build some old code anymore.) Thanks a lot for your proposition, but i don't need that right now, and i think i have also the source of the plugin, if i remember well i add modified it too in the past. What i would need it is more a tool that convert VGM to Coleco sound bios sound format. ( detecting pattern and organizing the right way to produce the melodie ) But it is not simple to do. Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 27, 2017 Share Posted April 27, 2017 That one's not for me, I don't have any interest in the Coleco sound bios format. When I started it was too hard to find documentation on the BIOS code and I just bypassed it all. But, the VGM format is very simple - no more complex than the byte stream out of my plugin (just with additional bytes thrown in between the actual data bytes). The docs for the format are at smspower here: http://www.smspower.org/Music/VGMFileFormat Despite all the options, the real life files tend to be pretty straight forward. Quote Link to comment Share on other sites More sharing options...
NoelleAmelie Posted April 29, 2017 Share Posted April 29, 2017 Is there a location of more music to listen to or open in the program so I can get some ideas how they created that song. That gyruss version for example or similar. Just search "SnevenTracker" on youtube and you'll find a bunch of videos. This one has a .SNM file you can download if you wanna open it in the program; I can also make something real quick to show off a few features in it. Quote Link to comment Share on other sites More sharing options...
