sparkdrummer Posted December 23, 2016 Share Posted December 23, 2016 I did a dsrscan at 1300. Sio is not present. Rs232/1,2,3,4 are. As well as just rs232. 1 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted December 23, 2016 Author Share Posted December 23, 2016 I did a dsrscan at 1300. Sio is not present. Rs232/1,2,3,4 are. As well as just rs232. Maybe Fred can modify his CF2k to also look for RS232, RS232/1,RS232/2,RS232/3,RS232/4 ???? Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted December 23, 2016 Share Posted December 23, 2016 In the last file, CF2N I changed the occurrence of SIO to PIO and it now seems to work. I used dsku sector editor to make the change. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted December 23, 2016 Share Posted December 23, 2016 In the last file, CF2N I changed the occurrence of SIO to PIO and it now seems to work. I used dsku sector editor to make the change. Temporarily, yes—but, if you try it on a true CF7+, it will certainly fail because it will find PIO in the first test and think it is a nanoPEB and, once again, set the wrong port addresses. It puzzles me that Jaime would not only remove SIO from the DSR for the nanoPEB but also add PIO, when the nanoPEB cannot possibly manage that. ...lee Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 23, 2016 Share Posted December 23, 2016 can someone make a step by step guide for the fix. This doesn't affect me yet as I have not started playing with CF2K that much but I'd like to not run in to any issues... Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted December 23, 2016 Share Posted December 23, 2016 @Shift838, @sparkdrummer, does OPEN #1: "PIO." work? ...lee Quote Link to comment Share on other sites More sharing options...
Shift838 Posted December 23, 2016 Author Share Posted December 23, 2016 @Shift838, @sparkdrummer, does OPEN #1: "PIO." work? ...lee Yes, OPEN #1:"PIO." works. odd....it's gotta be a DSR issue. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted December 23, 2016 Share Posted December 23, 2016 (edited) I wonder if he just left PIO in there by accident in place of SIO? He has been building the CF7+ again too. . .and he may have done a code update that missed a label. Edited December 23, 2016 by Ksarul Quote Link to comment Share on other sites More sharing options...
Shift838 Posted December 23, 2016 Author Share Posted December 23, 2016 I wonder if he just left PIO in there by accident in place of SIO? He has been building the CD7+ again too. . .and he may have done a code update that missed a label. yup that's very possible. I have contacted Jamie about the issue. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted December 23, 2016 Share Posted December 23, 2016 I agree with @Ksarul that the occurrence of PIO. in the DSR should, in fact, be SIO. I have asked Fred (@F.G. Kaal) for his input. It does seem like a mistake that Jaime should fix; however, it would be fairly simple for a version of CF2K to also check for RS232. as a nanoPEB v1 device for the purpose of setting the IDE I/O port addresses (easy for me to say! ) and Jaime would likely need to exchange nanoPEBs with folks to fix the problem from his end. ...lee Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted December 23, 2016 Share Posted December 23, 2016 Is it on an easy to pull EEPROM that can be read, sector edited and re-programmed? Quote Link to comment Share on other sites More sharing options...
Shift838 Posted December 23, 2016 Author Share Posted December 23, 2016 I agree with @Ksarul that the occurrence of PIO. in the DSR should, in fact, be SIO. I have asked Fred (@F.G. Kaal) for his input. It does seem like a mistake that Jaime should fix; however, it would be fairly simple for a version of CF2K to also check for RS232. as a nanoPEB v1 device for the purpose of setting the IDE I/O port addresses (easy for me to say! | ) and Jaime would likely need to exchange nanoPEBs with folks to fix the problem from his end. ...lee I sent Fred an email too asking the same thing if RS232 could be added for the check. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted December 27, 2016 Author Share Posted December 27, 2016 All, I have been conversing with Fred on the issue many of us are seeing. Fred has made a modification to his code to remedy our issues for many of us that have certain version 1.x NanoPEBs. You can download CF2K 2.5 from Fred's website : HERE The below was copied directly from his website which outline his changes. Version 2.5 There are nanoPeb version 1 without the SIO device name and therefore these will not be recognized as a nanoPeb. Changed: Cf2k5.c99::detcfmod(): Looking at CRU address >1300: 1) If device name "SIO." is available it is a nanoPeb 1. 2) If device name "COM1." is available it is a nanoPeb 2. 3) If device name "RS232." is available it is a nanoPeb 1. 4) If device name "PIO." is available it is a Cf7a+. Looking at CRU address >1000: 5) If device name "PIO." is available it is a Cf7a+ running in the Ti994w emulator environment. I have verified this version works with my NanoPEB version 1 as expected. Thanks Fred! 3 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted December 28, 2016 Share Posted December 28, 2016 ...so we need a new topic title now Quote Link to comment Share on other sites More sharing options...
Shift838 Posted December 28, 2016 Author Share Posted December 28, 2016 i think you're right... i'll start one.. 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted December 28, 2016 Share Posted December 28, 2016 oops, I just thought about chanigng this one, as long as possible Quote Link to comment Share on other sites More sharing options...
