ATLynxer Posted December 11, 2016 Share Posted December 11, 2016 Hi guys, I've an Atari Lynx II not working. Or better...you see that it would work....but it can't. I try to explain me better: the screen is not totally blank...but it's like grey and some few lines of the game appear. i recognise the colors of the game. And from the speaker some crackly part of sound sometimes come out. It's not the screen (tried with a surely working one) and not the flat cable. And it's not the speaker. I did a recap: nothing to do (oh...about that...on tech wiki https://console5.com/wiki/Atari_LynxI found that there are 10 uF 6,3V capacitors, while they are 16v...I don't now if 6,3 voltage is enough, and 16v on that capacitor is for safety, but 6,3v it's not the original voltage.) Anyway, all the diodes seem good, except for D7 which is totally broken, without continuity. I see from schematics it's a 1N4148 diode. For you: could it be the reason for the not working behavior? Have I to buy it and trying to replace it or it will be time lost? Thank you! Quote Link to comment Share on other sites More sharing options...
ATLynxer Posted December 16, 2016 Author Share Posted December 16, 2016 Diode 7 replaced and again the two 2.2 uF capacitors near it. Now the image works! Unfortunately the audio not Quote Link to comment Share on other sites More sharing options...
ATLynxer Posted December 17, 2016 Author Share Posted December 17, 2016 Diode 7 replaced and again the two 2.2 uF capacitors near it. Now the image works! Unfortunately the audio not I've repaired the audio also....changing the two audio amps....now the Lynx is 100% working! :D 1 Quote Link to comment Share on other sites More sharing options...
