RSS Bot Posted December 12, 2016 Share Posted December 12, 2016 Received a question via Messager that I'm going to reply to here as others may find it interesting as well: Hey. I was discussing how people overcome Atari 2600 hardware limitations to a friend and I used your Space Rocks as an example, but am unable to offer any explanation. Do you think you could tell me a bit about how it was achieved? Thanks. Long story short, extra hardware in the cartridge. Short story long, one or more of the following are added into the cartridge: Extra ROMWhen the Atari was designed ROM was expensive so they only used 2K for the games (think Combat, Air-Sea Battle, etc). They did plan ahead though and designed the Atari so it could use 4K ROMs. As the cost of ROM dropped 4K games like Space Invaders and River Raid could then be written. Bankswitching - AKA even more ROMAtari thought the successor to the 2600 would be out before they needed to go beyond 4K of ROM. The 2600 turned out to be more popular, and longer lived, than they expected so eventually 4K was no longer enough and they had to figure out a way around the 4K limit. What they came up with is known as bankswitching. For bankswitching you can think of the cartridge as a book, and each page in the book contains 4K. The Atari can turn the page to see different parts of the cartridge. A "2 page book" would be an 8K cartridge, like Asteroids and Ms. Pac-Man. A "4 page book" would be 16K for games like Solaris. I believe the largest game released back in the day was Fatal Run at 32K. Extra RAMAll that extra ROM allowed for more complex games that needed to keep track of more things. The Atari only has 128 bytes of RAM and the cartridge port does not have the required signals to support RAM in the cartridge; critically it's missing the Read/Write line which is used to determine if the memory is being accessed is to be Read From or Written To. Eventually they figured out how to work around that by repurposing an address line as the R/W line. This means each byte of RAM in the cartridge shows up twice in memory - one location is used for Reading, the other location is used for Writing. Games like Jr. Pac-Man used extra RAM in order to track of all those dots in the large scrolling mazes. Games that use extra RAM tend to also use extra ROM. CoprocessorThe Atari's unique in that the program has to update the video chip in real time, scanline by scanline, in order to create the display. This part of the program is known as the kernel and is very time critical. Activision came up with a coprocessor, known as DPC, which sped up kernel calculations and was used in Pitfall 2. Sadly the market collapsed before DPC could be used for other games on the 2600, though coprocessors were very common with later systems like the NES. Space RocksSpace Rocks uses all of the above - extra ROM, RAM and a "coprocessor" known as DPC+. Those are air quotes as the DPC+ coprocessor doesn't actually exist. So how'd we pull that off? Well the Harmony Cart (and Melody board, which is a stripped down Harmony used to create stand alone games) has an ARM processor that runs different drivers which emulate the different types of hardware that can be found in an Atari cartridge. One those drivers emulated the DPC chip, allowing you to play Pitfall 2 on it. The Harmony has a lot of unused resources when running the DPC driver so we created a new driver, known as DPC+, in order to unlock those extra resources (extra RAM, ROM, and even running game code on the ARM processor itself). The FutureAs we learn more about the 2600 we can create new drivers for the Harmony/Melody to take advantage of that knownledge. As an example we're currently working on a bus stuffing driver and have created a few demos so people can try it out. Expect to see a lot more activity on this new driver after the holidays.Bus stuffing in action: Attached thumbnail(s) http://atariage.com/forums/blog/148/entry-13507-extra-hardware/ Link to comment Share on other sites More sharing options...
