Sinphaltimus Posted December 14, 2016 Share Posted December 14, 2016 (edited) I purchased 2 x 5v 3000mA USB Adaptors and a USB to 5.5 mm/2.1 mm 5 Volt DC Barrel Jack Power Cables. EDIT: the power supplies from one vendor and cables from a different one. Both from China. One set for my nanoPEB and one set for my 32k Side Cart. The barrel fits perfectly.However; the USB to Barrel Jack does not make note of the polarity anywhere. So I'm reluctant to use it.I have a pocket multimeter. Can I use this to verify polarity? If yes, how? It's a generic HDM350. Edited December 14, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
+save2600 Posted December 14, 2016 Share Posted December 14, 2016 You most certainly can use your DMM to figure out polarity. Stick the red lead in the barrel and black lead on the outer edge. If you see negative voltage indicated by a minus sign (-) just to the left of your reading, your center tip/inside of barrel is negative. No minus sign indicates positive of course. 1 Quote Link to comment Share on other sites More sharing options...
SIO2 Posted December 14, 2016 Share Posted December 14, 2016 As Save2600 said, but I would add to set your meter to a DC voltage range nearest but greater than 5v before trying the test. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted December 14, 2016 Share Posted December 14, 2016 And... You might check a battery with known polarity to insure your leads are hooked up properly. ...lee 2 Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted December 14, 2016 Share Posted December 14, 2016 put your red lead where you want + to be, and the black where you want - to be.. turn to dc volts, test with power on if you get a negative number, its the wrong polarity swap leads and it'll become non-negative Greg 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted December 14, 2016 Share Posted December 14, 2016 BTW, you/we want tip-positive, so inside of the barrel should be about +5V. This is most common. You can also do continuity testing with info from a page like this: https://www.moddiy.com/pages/USB-2.0-%7B47%7D-3.0-%7B47%7D-3.1-Connectors-%26-Pinouts.html In this case, you want continuity between VCC and the inside of the barrel, and continuity between GND and the outside of the barrel. -M@ 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 14, 2016 Author Share Posted December 14, 2016 Alrighty then. Thanks all. Rolling outta bed soon, will check in a bit. Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 14, 2016 Author Share Posted December 14, 2016 (edited) OK, Looks good to me except, well, should I be worried about the overage? Edited December 14, 2016 by Sinphaltimus 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted December 14, 2016 Share Posted December 14, 2016 That should be ok for the sidecar 32k. Everything on that board will tolerate it. I can't speak for the nanopeb. -M@ 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 14, 2016 Share Posted December 14, 2016 5.2v is within spec for a 5v adapter... also the voltage will usually drop slightly when a load is applied. You'll be fine. 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 14, 2016 Author Share Posted December 14, 2016 Sweet. Can't wait to get home. Looked up at the clock and I swear it slowed down right before my eyes. Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 14, 2016 Author Share Posted December 14, 2016 Works with 32k Side Port Expansion by M@.. Have yet to try the nanoPeb. I kinda don't even want to plug it in until I understand how to use it. I have yet to make time to RTFM. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted December 14, 2016 Share Posted December 14, 2016 i use one with my NanoPEB with no issues. If you are supplying external power to the nano, then power the nano up first otherwise the TI will not boot. 1 Quote Link to comment Share on other sites More sharing options...
