Atari++ 1.81 available for download
thorfdbg
Now just the RPi build to sort ...............
Your latest build, after './configure' and 'make', creates the executable atari++, on running produces: -
pi@phoenix-pi-x64:~/atari++ $ ./atari++
Failure: object doesn't exist:
unable to build a suitable frontend. Either LibX11, SDL or Curses must be available
Has anyone got any actual command steps on how to create a working build version on a Raspberry Pi ?
Edited by CaptainMidnight
........... a little progress!
After a bit of prolonged googling, I've now successfully (by all accounts) installed the SDL requirement via: -
sudo apt-get libsdl1.2-dev
My next probably even more basic question is what are the minimal paramaters you'd expect that need to be passed to atari++ for it to start ?
Failure: Invalid argument:
unable to define the hardware parameters
OK OK here we go whoop whoop, finally some success, still testing, but at least we get to see the Atari screen running on the Pi. Just in case others or the author would like to know how to get this to work on the latest RPi4 running Pi OS 64-bit, where we go: -
sudo apt-get install libsdl1.2-dev libgtk2.0-dev --no-install-recommends
tar xzf atari++.tgz
./configure
make
sudo make install
then to actually run it: -
atari++ -FrontEnd SDL -Sound SDL
From the looks of it, the issues I've been experiencing could be related to building on the 64-bit version of Pi OS, so when I get a bit of time later I'll trial a build on the Pi OS 32-bit.
Another day, another luck. Here is a version with a modification of the alsa driver. Strangely, the implementation on the pi does not seem to support some of the alsa calls.
atari++.tgz
  • 10 months later...
Hey Guys,
pretty new member here - but long time Atari user.
I have just started trying out the emulator and it seems pretty impressive - I have fiddled with atari800 but want to attach a real 1050 and also make a real paddle (or at least a rotary potentiometer) work - from what I read this should work much better with atari++, but I will still have to try that.
Anyways so far: Great work, thanks for all the effort and sharing!
Compiling on my Laptop (Debian 9) worked "out of the box" - so "./configure && make" did the job! However the PI challenged me slightly, so I thought I share for others. The compile process also worked with a few warnings. However I could not start the executable.
After long time trying different releases and a lot of googling, I found this post and that finally got me in the right direction!
Just wanted to confirm that for running  atari++ on the Raspberry Pi (I tried on a 3) I have to provide
./atari++ -FrontEnd SDL -Sound SDL
Maybe that would be helpful to include in the Manual section of the atari++ homepage?
(The same with the download for 1.83 from official page and also tried with the file provided in last post)
But now to my question - since I do not have a mouse on my raspberry, I encountered the next obstacle (- nothing too bad and I think I can work without the gui and only use commandline options): Once I start the menu, I can navigate with the cursor keys and one time I seem to be able to use RETURN as mouseclick. However after being in a sub menu only moving the mouse cursor works with keyboard but I cannot not confirm any selection anymore - so basically leaving me stuck and helpless ;-).
Is there a trick to do that or is this maybe a bug?
Thanks again, stay safe!
Edited by DKONGsr
forgot something
  • 3 weeks later...
Hello,
I like the Emulator for many reasons but i want to use it with a Atari 1050 true FTDI but it work but with error all the time
I use Atari++ V1.81 Windows
Have Windows 10 Pro 20H2 64Bit
A FTDI to USB who work correctly without any errors with Kafar
Atari 1050 Diskdrive
When i start to boot from disk i get this
then click dismiss and get this
Dismiss again few times
Dismiss again and get this
Then i sellect H from menu of my floppy disk and get this
And dismiss again
So some how it work but with error who i can't explane what i do wrong, when i turn on my happycard in drive i only get errors and never the disk menu
greetings
Ed
I faced the same with an older version, unfortunately using the mouse was the only solution
If you know in advance what options you want to set, you can still edit the config-file or pass arguments on the command-line. You can also define on the command-line which config file to use. You can also mix both ways - set a config file and pass different options on the command-line. You could for example start the emulator with:
atari++ -config "my_atariconf.conf" -volume 25 -ostype OsXL -machine XL -holdoption on -fullscreen on -image.1 "joust.atr"
Concering the command line: You only have to supply command line arguments once, then save the settings in the menu. This will update the configuration file the emulator reads on the next start.
There is a 1.84 version in the making, but that's not yet fully ready. At this point, please do not provide patched source code versions, but please send patch requests to me (for example here in the forum) to have them integrated into trunk. Otherwise, we'll get a lot of partially working or unsupported versions floating around, and that's certainly not what I want.
Thank you!
To start Atari programs with the emulator, I'm using a Python script, that takes care of the startup configuration of each program (especially about holding down the OPTION key or not and about using OsXL or OsB).
Either, I'd have to create a configuration file for every single Atari program.
Or there's a single configuration file, that is rewritten by the script each time a program is started.
Or I'm using a single base configuration file, and the script does the required changes for each program using additional command line options.
I decided for the third option, as in my opinion it was the most elegant.
(Starting Atari programs is only part of the script, it can also start ZX Spectrum programs (using "fuse"), Amiga programs (using "fs-uae") and Arcade games (using "mame").)
I'm not planning on patching your code. If I would, of course I would contact you before releasing anything.
Also, I'd like to point out: Thank you very much for this great emulator! Well done!  ?
Edited by Pokeypy
Hello All,
Can someone explane what i do wrong because the explanation on website is very simple but sofar no luck i want te test the latest version to see if my if it solve my problems. But simpel type in make is not work for me
Using windows 10 download and install GnuWin32 to get make available for me but just type in make, or make -f makefile both gave same error
Hi folks,
happy July 4th, BTW. If anyone wants to try, here is a 1.84 beta of Atari++ which should compile smoothly on raspi, with some compiler warnings fixed, and (potentially) the alsa interface fixed. I actually haven't tried whether it really plays, though, but it may be worth a try.
You need to install the x11 development headers, libasound-dev (the alsa development headers) and probably also the libncurses-dev (curses development headers) to compile.
It also fixes keyboard navigation in the F1-menu. Press RETURN to select a button, or enter a string gadget.
There are  a couple of other fixes around media support which I nearly forgot since it has been a while since I looked into this.
As always, feedback appreciated, even though it may take a while for me to respond (sorry about that).
Greetings,
Thomas
atari++.tgz
On 6/30/2021 at 10:54 AM, Atariaan70 said:
Hello All,
Unfortunately, nothing really related to the emulator, but possibly the Linux subsystem or cygwin(?) of win10 that, according to this message, cannot launch a process. Nothing I can here from my side, sorry.
However, I still have a project file for VisualStudio 8 if you want to try compilation from there. This would then require SDL for video output, and either SDL or DirectSound for audio output. (Both of which unfortunately only qualify as "lousy" compared to alsa, but I'm not experienced enough in windows to provide anything better).
Hello,
So is the version 1.83 just only for Linux and Pi or should it also be for windows. Because you emulators realy nice
I can try it with Visualstudio is that it you let me
regards
22 hours ago, Atariaan70 said:
Hello,
regards
The 1.84, you mean? Well, I cannot really support windows, and it is not my preferred operating system. But well, I will not stop anyone from porting it to windows, or updating the port.  I'm attaching the VStudio support files I have, but those are outdated. If you want to give them a try, please go ahead.
atari++win.zip
Thank you for the files let see what we can do with it, again you made a wonderfull emulatorand i understand you can not control every operating system offcourse i will try  it on a PI later.
Yes 1.83 or 1.84 is only linux or pi
Thomas -- we've been experimenting with atari++ in Argon... So far, so good!
We posted a few small changes to github at https://github.com/ElectricMagic/AtariPP
We'll check out your update!
  • 1 month later...
Thanks for your updates, and sorry for taking so long. As I'm now on vacation, I had some time and merged your changes back into the trunk. Actually, I replaced the PAGE_SIZE macro with a class member (which is much cleaner) and got rid of two compiler workarounds that were only required for g++ 2.95, which is really really obsolete by now, so some old junk just can go.
Please find an updated beta version attached, would be glad to receive some feedback.
Thanks,
Thomas
atari++.tgz
Thanks for incorporating our changes.
There's one error in `CartPhoenix::MapCart` -- it should be using `Page_Length` for the loop increments -- see https://github.com/ElectricMagic/AtariPP/commit/a5a1b4f989884259db494e7ec5902de17866a9f9
And there's an inconsequential fix at https://github.com/ElectricMagic/AtariPP/commit/2cdad907e3547925a76ee738e93c17fc21a519c5, where the enum should be `All` vs `Any`.
https://github.com/ElectricMagic/AtariPP/commit/bf66e03e2a7eeae5d97a96021a9a83d055a499f8 lets us pass a hard-coded command line without nasty typecasts.
  • 1 year later...
So this is an old thread, but I thought I'd necro-bump it :)
I was looking around for a way to create a test-suite for my new language, and I came across atari++, I'm running on a Mac, so Altirra isn't really an option unless I want to mess about with Wine, and Atari800MacX doesn't seem to want to compile on modern Macs. What really caught my eye about atari++ was the E: and H: drivers combined with a "headless" mode. That seemed tailor-made for what I wanted to do...
Run a script, which
  • Reads a source file, runs the compiler and produces an executable (.XEX)
  • Runs the emulator, in headless mode, and pipes in the path to the XEX (using the H: driver to map a convenient directory where the XEX is)
  • Use the E: driver to get the results back from the executable
  • Compare the output with an expected output for that test
  • Lather, rinse, repeat.
The first problem was trivial to fix - there's a missing semi-colon at the end of line 31 in new.hpp and I needed to get rid of a bunch of x86-specific optimisations - mac's being Arm machines these days :)
The second problem is that I can map my H: drive, no problems, just run with:
prompt%  atari++ -InstallHDevice on -H1Dir `pwd` -InstallHasDisk on
... and type "DIR" and see a long, (long!) listing of all the files in the atari++ directory. Cool!
But if I put the E: driver in as well, it stops working:
prompt% ./atari++  -InstallEDevice on  -InstallHDevice on -H1Dir `pwd` -InstallHasDisk on
Thor Dos 2.++ V 1.9 Enhanced Density
Copyright (c) 1990-2020 by THOR
D1:dir
Error - 170
D1:
I'm leaving the video mode to the default (which seems to be X11, on the Mac) but I get the same result if I append "-frontend none" to the command line.
Any clues on this ? It'd be awesome to be able to do a 'make test' and see the entire slew of tests all run in the emulator when I'm making changes to things like "support a new type"...
Hmm, ok there may be a third problem :) I can't get the binary to run... I have /tmp mapped as DPCL1: on Atari800MacX using SpartaDOS and PCLink. and if I compile the test-app to there, I can see:
1145796272_Screenshot2022-12-12at9_56_45PM.thumb.png.aab84b71bd55238d2cfc72c67a085871.png
But if I run the atari++ command above (that doesn't install the E: device handler), and run the same binary, it doesn't actually do the same. I'm running at $4000 so maybe I need to check the memory maps...
1836122858_Screenshot2022-12-12at9_59_06PM.thumb.png.118354360ce8a69c1fdd8385d1a0d336.png
