+grips03 Posted December 17, 2016 Share Posted December 17, 2016 Added Red led in the top right area. Hopefully this avoids the voice module. I don't recommend using the IDC / ribbon cable to db9 as you have to trim both the connector and the O2 case interior in order for them to fit. It would be much nicer to use the original O2 joystick cable, cut to 18 inches and buy the black plastic pin type db9 connectors, listed below. I only had IDC/db9 cables on had so I had to make do. Digikey: 5745051-2 black plastic db9 male with 4-40 insert and pin contact, would need 4-40 screw to hold in place Digikey: 5208006-2, 208006-1, 208006-2 black plastic db9 male without threaded insert, pin type solder contact, need screw and nut to hold in place the pin type solder contacts work well with heat-shrink tubing or Digikey: 1-745203-1, 745203-9 which have a little solder tray, need screw and nut to hold in place Still waiting to make holes for RCA jacks. I was thinking of using recessed area in the back but looks like it would interfere with system board. I can relocate the joystick ports on system board, however even with that there might not be room. Too bad as looks wise it would be ideal. Ordered cartridge connector, so for now that spot is empty. I bought two types one that takes 4-40 screws so might be able to use in lieu of rivets. 2 Quote Link to comment Share on other sites More sharing options...
metarog Posted December 18, 2016 Share Posted December 18, 2016 Looking good so far... I really like the controller ports in the front. The LED is right on the border where the Voice sits but it might just be okay. Thanks for sharing the pics... keep us updated. 2 Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 18, 2016 Author Share Posted December 18, 2016 Added rca jacks today, to back left. Used AMP UP connector to connect between top and bottom of console. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 27, 2016 Author Share Posted December 27, 2016 red led hit the Voice module. Need to move down by a couple of mm. Quote Link to comment Share on other sites More sharing options...
metarog Posted December 27, 2016 Share Posted December 27, 2016 Bummer, I have a couple extra silver frame covers if you want an unblemished one. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 28, 2016 Author Share Posted December 28, 2016 Bummer, I have a couple extra silver frame covers if you want an unblemished one. sure that would be great. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted March 19, 2017 Author Share Posted March 19, 2017 I've done a couple more of these and IDC db9 cables was the best method. Order Qty 2: H7MXH-0906M <--digikey.com Quote Link to comment Share on other sites More sharing options...
