Rhindle the Dragon Posted December 26, 2016 Share Posted December 26, 2016 Has anyone ever come up with an alternative to the crappy potentiometer-based paddle controllers? I know they sell reproductions, but if I'm thinking right, they will also suffer from jitters after a while since they are based on the same mechanism. It seems like a super-easy problem to fix. Maybe modify a rotary encoder somehow? Somebody look into this! Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 26, 2016 Share Posted December 26, 2016 Rotary controllers would not work for a paddle game, the signals are completely different. Quote Link to comment Share on other sites More sharing options...
Papa Posted December 26, 2016 Share Posted December 26, 2016 (edited) Fixing said pots is one of the many exercises for the VCS enthused. Prying tiny metal tabs and cleaning forty year old grease brings the controller back to decent functionality (I've cleaned many and Buttons is using my best ones for chopping down brick game scores on highscore.com). The best alternative to the pots is found with the Gemini system and it's single PCB, potless controllers that use one metal rod and some feelers to cram a paddle and extremely sensitive controller into one frame. There are conductive pathways that are touched by activators like with more modern controllers (no frail metal, taped-down blisters to break off or collapse) although the dial for the paddle is like this as well. It's a circle that is brushed down on by a metal 'feeler'. If these are clean they are quite good. You have to hold down the button when you start certain games with them and I believe someone somewhere mentioned a 'Y' connector that makes them functional with all paddle games as they don't work with a couple of them. Edited December 26, 2016 by Papa Quote Link to comment Share on other sites More sharing options...
Turbo-Torch Posted December 26, 2016 Share Posted December 26, 2016 It's an answer to a problem that doesn't exist. I can take 40 year old paddle controllers and have them working perfect again in a few minutes by simply removing the back and spraying something like Deoxit into the pots. I'd rather have an electromechanical device that requires minor maintenance maybe once every ten years and can stand up to DECADES of use vs. a modern piece of shit that will fall apart within a year. 8 Quote Link to comment Share on other sites More sharing options...
Supergun Posted December 26, 2016 Share Posted December 26, 2016 100% agreed. Quote Link to comment Share on other sites More sharing options...
Atarian7 Posted December 26, 2016 Share Posted December 26, 2016 It's an answer to a problem that doesn't exist. I can take 40 year old paddle controllers and have them working perfect again in a few minutes by simply removing the back and spraying something like Deoxit into the pots. I'd rather have an electromechanical device that requires minor maintenance maybe once every ten years and can stand up to DECADES of use vs. a modern piece of shit that will fall apart within a year. There's also a way to "permanently" fix them by taking them apart and cleaning the grease off. I can't do it myself though. I ruined a pair of paddles because I couldn't put them back together properly. There's a step-by-step guide here on Atariage somewhere. Quote Link to comment Share on other sites More sharing options...
karokoenig Posted December 26, 2016 Share Posted December 26, 2016 (edited) I fix mine based on a YT tutorial every now and then. There are several online that lead you through the process step by step. It's not rocket science, no special tools needed. Even I could do it easily. Edited December 26, 2016 by karokoenig Quote Link to comment Share on other sites More sharing options...
alex_79 Posted December 27, 2016 Share Posted December 27, 2016 I disassembled and cleaned all my paddle sets about 10 years ago, and they're still working great. They're electrically so simple that a replacement can be built by anyone with very basic electronic skills using cheap off-the-shelf parts, so I don't think it would be worth the effort to design a digital alternative. Quote Link to comment Share on other sites More sharing options...
Skippy B. Coyote Posted December 27, 2016 Share Posted December 27, 2016 If you're not the most technically inclined and don't want to deal with jittery paddles or trying to refurbish them yourself I'd recommend ordering a set of upgraded paddle controllers from Best Electronics with their lifetime warrantied super pots in them. I picked up a pair earlier this year and they're so vastly superior to any original production Atari paddle controllers I've ever used (and I had owned 6 of them before this) that I'd recommend them to anyone into paddle controller games. Smooth as silk operation, zero jitter, and perfect precision control every time I've used them. Plus they're warrantied against jitters for life so you can always get them replaced for free under warranty should you ever have any problems with them. 2 Quote Link to comment Share on other sites More sharing options...
xucaen Posted December 27, 2016 Share Posted December 27, 2016 I cleaned a pair of paddles a few times, still jitters. Best Electronics used to sell replacements pots, but last time I checked he was looking for a new supplier, so I was never able to completely fix my paddles. Quote Link to comment Share on other sites More sharing options...
ubersaurus Posted December 27, 2016 Share Posted December 27, 2016 He's got a new supplier and new pots in as of the past couple months. 2 Quote Link to comment Share on other sites More sharing options...
Inky Posted December 27, 2016 Share Posted December 27, 2016 I've always thought about adapting a slide potentionometer, like used in radio station sound boards, as a replacement paddle. Having very little electronics knowledge, I wouldn't know where to begin with this. Quote Link to comment Share on other sites More sharing options...
Rom Collector Posted December 28, 2016 Share Posted December 28, 2016 I've always thought about adapting a slide potentionometer, like used in radio station sound boards, as a replacement paddle. Having very little electronics knowledge, I wouldn't know where to begin with this. Those kinds of pots are usually more prone to contamination to dust, smoke, etc. Quote Link to comment Share on other sites More sharing options...
Inky Posted December 28, 2016 Share Posted December 28, 2016 Those kinds of pots are usually more prone to contamination to dust, smoke, etc. Perhaps, but I'm still curious how something like this would work on the 2600 1 Quote Link to comment Share on other sites More sharing options...
gliptitude Posted December 28, 2016 Share Posted December 28, 2016 I mostly use the paddles to play Night Driver, so the 2P paddle never gets used and is just in the way. A single plain old stock paddle, untethered to a second paddle would constitute a nice "alternate paddle controller" for me. Can I just cut the 2P paddle off and hide the spare wire ends, without messing up P1? Quote Link to comment Share on other sites More sharing options...
alex_79 Posted December 29, 2016 Share Posted December 29, 2016 (edited) Yes. Anyway, there could be some game that have paddle 1 and 2 reversed (as they're not marked in any way). So if you have some soldering skills, a better solution would be to wire a new cable and add a switch on the controller to select which player you want to use. In that way it can also be used for alternating 2-player games. This is mine (you can see the switch on the side of the controller): Edited December 29, 2016 by alex_79 3 Quote Link to comment Share on other sites More sharing options...
xucaen Posted December 29, 2016 Share Posted December 29, 2016 He's got a new supplier and new pots in as of the past couple months. I just ordered two. Awesome! Soon I'll have 4 working paddles and can play Warlords again. Quote Link to comment Share on other sites More sharing options...
Supergun Posted December 30, 2016 Share Posted December 30, 2016 I have always felt that the gittery paddles are just as much a part of the Atari gameplay experience as the fuzzy video from the antenna connection, not having a pause button, having to get up to hit reset so you can restart a game, etc. The only thing that matters is: "Have you played Atari today?" Quote Link to comment Share on other sites More sharing options...
Level42 Posted December 30, 2016 Share Posted December 30, 2016 I've been thinking of replacing the "consumer grade" pots with versions like used in f.i. Atari's Star Wars arcade cabinet (the yoke has two expensive pots). (like these: http://www.ebay.com/itm/172395261311?vectorid=229466&lgeo=1&item=172395261311&rmvSB=true) The values differ but it should be possible to get the right one's. HOWEVER..... I never looked further into this because I have two paddle sets which I bought "recently" (i.e. couple of years) and they simply work just fine. One set was already cleaned by Mr.Atari, the other I did myself. A bit of contact spray should fix any real problems. I usually clean up with pure alcohol afterwards. (p.s. those "arcade" quality pots are also bigger and have a larger spindle. If they would fit it would require some mechanical changes to the Paddle units. And a final note: I replace those pots on my arcade machines too. Often they are jittery as well....it's dirt and dust.....usually cleaning them is enough but when I restore entire cabs it makes sense to replace them.) Quote Link to comment Share on other sites More sharing options...
Inky Posted December 30, 2016 Share Posted December 30, 2016 Is there a technical document on the wiring and pot specifications somewhere? I am seriously considering building a slide pot paddle. Quote Link to comment Share on other sites More sharing options...
alex_79 Posted December 30, 2016 Share Posted December 30, 2016 Pots are 1 Mohm, linear (not logarithmic!) 1 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 30, 2016 Share Posted December 30, 2016 Might become quite challenging to play Kaboom! with a logarithmic one. 1 1 Quote Link to comment Share on other sites More sharing options...
Rom Collector Posted December 31, 2016 Share Posted December 31, 2016 So if you have some soldering skills, a better solution would be to wire a new cable and add a switch on the controller to select which player you want to use. In that way it can also be used for alternating 2-player games. This is mine (you can see the switch on the side of the controller): Alex, this is a great idea I would like to do myself. Can you tell us more, perhaps in a new thread, or message me? Quote Link to comment Share on other sites More sharing options...
alex_79 Posted December 31, 2016 Share Posted December 31, 2016 You only need a dpdt switch and a new cable. The switch connects the pot and button to either paddle 1 or paddle 2 inputs of the port. You can use a genesis extension cord which has all pins connected, or build your own using a cable with at least 6 wires and a 9-pin female connector. A standard connector with shell won't fit on all consoles (especially heavy sixer and 7800, where the ports are quite recessed), so you need to modify them. I posted some pitures of the method I use in the videopac.nl forum:http://videopac.nl/forum/index.php?PHPSESSID=544fa181217704b34e199770b3418383&topic=2330.msg22880#msg22880 1 Quote Link to comment Share on other sites More sharing options...
Rhindle the Dragon Posted January 1, 2017 Author Share Posted January 1, 2017 Whoa... I got NO notifications that anyone replied. Thanks guys! I'll have to check out Best Electronics. Quote Link to comment Share on other sites More sharing options...
