ggn Posted December 26, 2016 Share Posted December 26, 2016 Not sure if it is a present but here's gcc for your Ataris - happy coding! http://d-bug.mooo.com/beyondbrown/post/gcc-6/ 2 Quote Link to comment Share on other sites More sharing options...
Justin Payne Posted December 26, 2016 Share Posted December 26, 2016 Thanks! Quote Link to comment Share on other sites More sharing options...
+GroovyBee Posted December 26, 2016 Share Posted December 26, 2016 Not sure if it is a present but here's gcc for your Ataris - happy coding! http://d-bug.mooo.com/beyondbrown/post/gcc-6/ Sooooo... When can we expect Jaguar support Quote Link to comment Share on other sites More sharing options...
ggn Posted December 27, 2016 Author Share Posted December 27, 2016 Sooooo... When can we expect Jaguar support Honestly, I'd prefer to do intellivision support first . 1 Quote Link to comment Share on other sites More sharing options...
+GroovyBee Posted December 28, 2016 Share Posted December 28, 2016 Honestly, I'd prefer to do intellivision support first . I think the MSP430 port would be a good starting point for that Quote Link to comment Share on other sites More sharing options...
+poobah Posted December 28, 2016 Share Posted December 28, 2016 I think the MSP430 port would be a good starting point for that Well, gcc can make msp430 binaries.... Quote Link to comment Share on other sites More sharing options...
+GroovyBee Posted December 28, 2016 Share Posted December 28, 2016 Well, gcc can make msp430 binaries.... I know . The programmers model between the MSP430 and CP1610 has some similarities. Quote Link to comment Share on other sites More sharing options...
rustynutt Posted January 2, 2017 Share Posted January 2, 2017 Massive undertaking and great read Quote Link to comment Share on other sites More sharing options...
Justin Payne Posted March 18, 2017 Share Posted March 18, 2017 (edited) OK, I'm going out to get it now. Don't expect anything special from me but I just wanted to let you know that you're work will at least get played with tonight. Edited March 18, 2017 by Justin Payne 1 Quote Link to comment Share on other sites More sharing options...
Justin Payne Posted March 19, 2017 Share Posted March 19, 2017 I might need a bit of assistance but first, a recap. My OS is Win 10. I initially tried to go the MinGW/Msys build route. Even though it "says" I don't have to install MinGW 32-bit, I did it anyway. After installing and choosing what applications and libraries I wanted, I ran mingw-static-libraries-6.1.0-x86.exe but it said it couldn't find the version of MinGW. I even ran it from the directory where the applications exist. Next I tried Cygwin. After installing the 32-bit version, I downloaded gcc, binutils, mintlib, & brownout. I followed the Quick installation instructions but after copying and extracting the files to my home directory, running the _postinstall.sh threw a bunch of errors. cp: cannot stat '/lib/gcc/m68k-ataribrown-elf/6.2.0/*.o': No such file or directory cp: cannot stat '/lib/gcc/m68k-ataribrown-elf/6.2.0/*.a': No such file or directory cp: cannot stat '/lib/gcc/m68k-ataribrown-elf/6.2.0/softfp': No such file or directory cp: cannot stat '/lib/gcc/m68k-ataribrown-elf/6.2.0/softfp/*.o': No such file or directory cp: cannot stat '/lib/gcc/m68k-ataribrown-elf/6.2.0/softfp/*.a': No such file or directory cp: cannot stat '/lib/gcc/m68k-ataribrown-elf/6.2.0/softfp': No such file or directory cp: cannot stat '/usr/m68k-ataribrown-elf/lib/libstdc++.*': No such file or directory cp: cannot stat '/usr/m68k-ataribrown-elf/lib/libsupc++.*': No such file or directory cp: cannot stat '/usr/m68k-ataribrown-elf/lib/softfp/libstdc++.*': No such file or directory cp: cannot stat '/usr/m68k-ataribrown-elf/lib/softfp/libsupc++.*': No such file or directory mv: cannot stat '/usr/m68k-ataribrown-elf/lib/libc.a': No such file or directory mv: cannot stat '/usr/m68k-ataribrown-elf/lib/libiio.a': No such file or directory mv: cannot stat '/usr/m68k-ataribrown-elf/lib/librpcsvc.a': No such file or directory cp: cannot stat '/usr/m68k-ataribrown-elf/lib/m68020/libc.a': No such file or directory cp: cannot stat '/usr/m68k-ataribrown-elf/lib/m68020/libiio.a': No such file or directory cp: cannot stat '/usr/m68k-ataribrown-elf/lib/m68020/librpcsvc.a': No such file or directory cp: cannot stat '/usr/m68k-ataribrown-elf/lib/m68020-20_soft/*.a': No such file or directory cp: cannot stat '/usr/m68k-ataribrown-elf/lib/m68020-20_soft/*.a': No such file or directory mv: cannot stat '/usr/m68k-ataribrown-elf/lib/m68020-60_soft': No such file or directory cp: cannot stat '/usr/m68k-ataribrown-elf/lib/softfp/libstdc++.*': No such file or directory cp: cannot stat '/usr/m68k-ataribrown-elf/lib/softfp/libsupc++.*': No such file or directory ./_postinstall.sh: line 74: emulated: command not found ./_postinstall.sh: line 76: libstdc++: command not found cp: cannot stat '/usr/m68k-ataribrown-elf/lib/m68020/softfp/libstdc++.*': No such file or directory cp: cannot stat '/usr/m68k-ataribrown-elf/lib/m68020/softfp/libsupc++.*': No such file or directory I'm sure after going through the script I'll figure out what is going but I just wanted to let you know that some further instructions tweaking might be needed. Quote Link to comment Share on other sites More sharing options...
Justin Payne Posted April 1, 2017 Share Posted April 1, 2017 The site seems to be down. Quote Link to comment Share on other sites More sharing options...
Justin Payne Posted April 4, 2017 Share Posted April 4, 2017 The site seems to be down. Back up and back to figuring this install issue out. I think I might try Linux on Windows 10 1607. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 4, 2017 Share Posted April 4, 2017 I've installed the toolset under an Ubuntu VM and have Hatari on there too. It has been a long time since I did any ST programming (and then using Sozobon) so are there any example projects / makefiles available to help familiarise myself, or even solutions in a dev environment if that works too (e.g. Eclipse). 1 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 5, 2017 Share Posted April 5, 2017 I've found the d_m_l/agtools as something to take a look at however attempting to build a demo produced a missing header file. Any ideas? markk@ubuntu-sevenof9:~/agtools/demos/abreed$ make USE_BROWNELF=yes m68k-ataribrown-elf-g++ -c -m68000 -Ofast -fomit-frame-pointer -fstrict-aliasing -fcaller-saves -flto -ffunction-sections -fdata-sections -fleading-underscore -DUSE_TINY_CRT -DAGT_GCC6_ELF -D__ATARI__ -D__M68000__ -DAGT_CONFIG_STACK=16384 -DAGT_CONFIG_WORLD_XMAJOR -I../.. -I3rdparty/ -x c++ -std=c++0x -fno-exceptions -fno-rtti -fno-threadsafe-statics -Wall -Wno-reorder -Wno-narrowing -o ../../agtsys/system.o ../../agtsys/system.cpp In file included from /usr/m68k-ataribrown-elf/include/c++/6.2.0/bits/postypes.h:40:0, from /usr/m68k-ataribrown-elf/include/c++/6.2.0/bits/char_traits.h:40, from /usr/m68k-ataribrown-elf/include/c++/6.2.0/string:40, from ../../agtsys/common_cpp.h:14, from ../../agtsys/system.cpp:13: /usr/m68k-ataribrown-elf/include/c++/6.2.0/cwchar:44:19: fatal error: wchar.h: No such file or directory #include <wchar.h> ^ compilation terminated. Makefile:559: recipe for target '../../agtsys/system.o' failed make: *** [../../agtsys/system.o] Error 1 markk@ubuntu-sevenof9:~/agtools/demos/abreed$ sudo find / -name "wchar.h" -print[sudo] password for markk: /mintlib-0.60.1-bin/include/wchar.h find: ‘/run/user/1000/gvfs’: Permission denied /usr/include/c++/5/tr1/wchar.h /usr/include/wchar.h /usr/include/x86_64-linux-gnu/bits/wchar.h /usr/m68k-ataribrown-elf/include/c++/6.2.0/tr1/wchar.h Quote Link to comment Share on other sites More sharing options...
Justin Payne Posted April 6, 2017 Share Posted April 6, 2017 I've installed the toolset under an Ubuntu VM and have Hatari on there too. It has been a long time since I did any ST programming (and then using Sozobon) so are there any example projects / makefiles available to help familiarise myself, or even solutions in a dev environment if that works too (e.g. Eclipse). Yea, I went the Ubuntu route as well and didn't have any issues installing and running it in a VM is much better user experience than Cygwin. So, the "permission denied" is interesting. Dumb question but have you tried compiling was sudo or checked to ensure that header file exists? Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 7, 2017 Share Posted April 7, 2017 So, the "permission denied" is interesting. Dumb question but have you tried compiling was sudo or checked to ensure that header file exists? The permission was only as a not uncommon response to a 'find'. The find did locate the header under '/usr/m68k-ataribrown-elf/include/c++/6.2.0/tr1/wchar.h'. Therefore I would think it internal to the compiler as to how it includes that folder in the search path? In '/usr/m68k-ataribrown-elf/include/c++/6.2.0/m68k-ataribrown-elf/bits/c++config.h' there's: /* Define to 1 if you have the <wchar.h> header file. */ #define _GLIBCXX_HAVE_WCHAR_H 1 And in '/usr/m68k-ataribrown-elf/include/c++/6.2.0/cwchar' there's: #if _GLIBCXX_HAVE_WCHAR_H #include <wchar.h> #endif Perhaps there is some copying of header files that the post install script could need? g++ can show the lib search path but how do I confirm the full include folders used? Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 7, 2017 Share Posted April 7, 2017 OK, so adding a "-v" to the compiler options in a Makefile has helped show me the includes: markk@ubuntu-sevenof9:~/agtools/tutorials/tutor0$ make USE_BROWNELF=yes m68k-ataribrown-elf-g++ -c -v -m68000 -Ofast -fomit-frame-pointer -fstrict-aliasing -fcaller-saves -flto -ffunction-sections -fdata-sections -fleading-underscore -DUSE_TINY_CRT -DAGT_GCC6_ELF -D__ATARI__ -D__M68000__ -DAGT_CONFIG_STACK=16384 -DAGT_CONFIG_WORLD_XMAJOR -I../.. -I3rdparty/ -x c++ -std=c++0x -fno-exceptions -fno-rtti -fno-threadsafe-statics -Wall -Wno-reorder -o ../../agtsys/system.o ../../agtsys/system.cpp Using built-in specs. COLLECT_GCC=m68k-ataribrown-elf-g++ Target: m68k-ataribrown-elf Configured with: ../gcc-6.2.0/configure --target=m68k-ataribrown-elf --disable-nls --enable-languages=c,c++ --enable-lto --prefix=/usr --disable-libssp --enable-softfloat --disable-libstdcxx-pch --disable-clocale --disable-libstdcxx-threads --disable-libstdcxx-filesystem-ts --disable-libquadmath --enable-cxx-flags='-O2 -fomit-frame-pointer -fno-threadsafe-statics -fno-exceptions -fno-rtti -fleading-underscore' 'CFLAGS_FOR_TARGET=-O2 -fomit-frame-pointer -fno-threadsafe-statics -fleading-underscore' 'CXXFLAGS_FOR_TARGET=-O2 -fomit-frame-pointer -fno-threadsafe-statics -fno-exceptions -fno-rtti -fleading-underscore' 'LDFLAGS_FOR_TARGET=--emit-relocs -Ttext=0' Thread model: single gcc version 6.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-v' '-mcpu=68000' '-Ofast' '-fomit-frame-pointer' '-fstrict-aliasing' '-fcaller-saves' '-flto' '-ffunction-sections' '-fdata-sections' '-fleading-underscore' '-D' 'USE_TINY_CRT' '-D' 'AGT_GCC6_ELF' '-D' '__ATARI__' '-D' '__M68000__' '-D' 'AGT_CONFIG_STACK=16384' '-D' 'AGT_CONFIG_WORLD_XMAJOR' '-I' '../..' '-I' '3rdparty/' '-std=c++11' '-fno-exceptions' '-fno-rtti' '-fno-threadsafe-statics' '-Wall' '-Wno-reorder' '-o' '../../agtsys/system.o' /usr/libexec/gcc/m68k-ataribrown-elf/6.2.0/cc1plus -quiet -v -I ../.. -I 3rdparty/ -imultilib m68000 -D USE_TINY_CRT -D AGT_GCC6_ELF -D __ATARI__ -D __M68000__ -D AGT_CONFIG_STACK=16384 -D AGT_CONFIG_WORLD_XMAJOR ../../agtsys/system.cpp -quiet -dumpbase system.cpp -mcpu=68000 -auxbase-strip ../../agtsys/system.o -Ofast -Wall -Wno-reorder -std=c++11 -version -fomit-frame-pointer -fstrict-aliasing -fcaller-saves -flto -ffunction-sections -fdata-sections -fleading-underscore -fno-exceptions -fno-rtti -fno-threadsafe-statics -o /tmp/ccYyUqWu.s GNU C++11 (GCC) version 6.2.0 (m68k-ataribrown-elf) compiled by GNU C version 5.4.0 20160609, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version none GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "/usr/lib/gcc/m68k-ataribrown-elf/6.2.0/../../../../m68k-ataribrown-elf/sys-include" ignoring nonexistent directory "3rdparty/" #include "..." search starts here: #include <...> search starts here: ../.. /usr/lib/gcc/m68k-ataribrown-elf/6.2.0/../../../../m68k-ataribrown-elf/include/c++/6.2.0 /usr/lib/gcc/m68k-ataribrown-elf/6.2.0/../../../../m68k-ataribrown-elf/include/c++/6.2.0/m68k-ataribrown-elf/m68000 /usr/lib/gcc/m68k-ataribrown-elf/6.2.0/../../../../m68k-ataribrown-elf/include/c++/6.2.0/backward /usr/lib/gcc/m68k-ataribrown-elf/6.2.0/include /usr/lib/gcc/m68k-ataribrown-elf/6.2.0/include-fixed /usr/lib/gcc/m68k-ataribrown-elf/6.2.0/../../../../m68k-ataribrown-elf/include End of search list. GNU C++11 (GCC) version 6.2.0 (m68k-ataribrown-elf) compiled by GNU C version 5.4.0 20160609, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version none GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: 2c93d6023885db03f31b024536f05798 In file included from /usr/m68k-ataribrown-elf/include/c++/6.2.0/bits/postypes.h:40:0, from /usr/m68k-ataribrown-elf/include/c++/6.2.0/bits/char_traits.h:40, from /usr/m68k-ataribrown-elf/include/c++/6.2.0/string:40, from ../../agtsys/common_cpp.h:14, from ../../agtsys/system.cpp:13: /usr/m68k-ataribrown-elf/include/c++/6.2.0/cwchar:44:19: fatal error: wchar.h: No such file or directory #include <wchar.h> ^ compilation terminated. Makefile:500: recipe for target '../../agtsys/system.o' failed make: *** [../../agtsys/system.o] Error 1 So from a google search the "tr1" issue maybe linked with the which C++ standard is in use by the compiler. I've tried adding this to the include in the Makefile however this only then leads onto "locale.h" not being found, and in this case no file with that name appears in the ataribrown folders. This therefore might be an issue with the cross-tools build in the first place but I wouldn't really know where to start with that. Quote Link to comment Share on other sites More sharing options...
