how to adapt your 2600 controller for about a dollar
bohoki
it may sound like a sensational headline but if you have some skill and fortitude it can be done
parts list
some thin wire (i just used some old ac adapter wire) so free
momentary push button (for start)
db-9 male connector less than 50 cents most places they can be found
db-15 female connector less than 50 cents
two 240k resistors about 10 cents each
soldering iron (if you dont have one you probably shouldn't attempt this)
ohm meter for testing your work
ok disclaimer time all information is for entertainment purposes only no warranties expressed or implied by reading this you agree to hold harmless any and all agencies affiliated. use of solder may expose you chemicals that cause harm . improper or proper assembly may cause harm to your system. the end product will not be fcc approved , ul listed ,osha approved or ergonomically designd device may result in hand damage, eye damage, crotch fires ,toe aches ,inner ear discombobulation do not attempt to do this at home
ok to make it less confusing i'll break it into stages
left and up directions
down and right directions
buttons
start button
adapter harness
since you will be using the original cable and plug after modification you should mark the plug end with some tape (not for 2600)
i recommend using a joystick that has 2 fire buttons you can isolate them and use them as b1 and b2
if not drill a hole and use a momentary pushbutton the resistors will be inside the joystick carcas not in the adapter harness
you will also need to cut off the metal housing for the 15 pin plug and fuse the 2 plastic parts together with the soldering iron (careful because freshly cut metal is often sharp)
here is my horrible complex confusing diagram but if you just take them one by one you can do it
after opening your joystick you will want to isolate the common ground from the buttons via circuit board cuts or with a wico or suncom stick cutting wires (the black one is often the ground what you want is the top and left common to still be connected and
the right and bottom to remain connected and have the buttons common also be tied to the right and bottom
any questions?
Edited by bohoki
