traindriver69 Posted January 1, 2017 Share Posted January 1, 2017 Hi all have recieved a nanoPEB from a website and while looking around trying to work out how to use it i found a post saying the memory should be 11840 BYTES OF STACK FREE24488 BYTES OF PROGRAM,well mine says 11832 bytes of stack memory. is this a problem will it cause any issues. many thanks in advance Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted January 1, 2017 Share Posted January 1, 2017 Do you have a power supply plugged in? Is it switched on? Sent from my LG-H830 using Tapatalk Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted January 1, 2017 Share Posted January 1, 2017 Stack memory changes based on variables and devices. Sent from my LG-H830 using Tapatalk Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted January 1, 2017 Share Posted January 1, 2017 Type call mount(1,1) in basic or xbasic Sent from my LG-H830 using Tapatalk Quote Link to comment Share on other sites More sharing options...
PeBo Posted January 1, 2017 Share Posted January 1, 2017 My nanoPEB reports the same memory size (24488/11832) which I always assumed was an 8k loss as a result of the additional commands (CALL MOUNT/CALL UNMOUNT) will be interseting to read what others have to say. Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted January 1, 2017 Share Posted January 1, 2017 My nanoPEB reports the same memory size (24488/11832) which I always assumed was an 8k loss as a result of the additional commands (CALL MOUNT/CALL UNMOUNT) will be interseting to read what others have to say. I believe those numbers are 24k upper memory expansion as used by XB. 11k of remaining VDP memory and the missing 8k is the >2000 - >3FFF bank of the 32k, that XB doesn't directly use, but you can load machine code into or whatever... XB just doesn't manage it for XB code, so it doesn't report it. Routines like CALL MOUNT actually live in paged in DSR roms (>4000 - >5FFF space), and don't impact XB memory reports. -M@ Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted January 1, 2017 Share Posted January 1, 2017 Hi all have recieved a nanoPEB from a website and while looking around trying to work out how to use it i found a post saying the memory should be 11840 BYTES OF STACK FREE 24488 BYTES OF PROGRAM,well mine says 11832 bytes of stack memory. is this a problem will it cause any issues. many thanks in advance The stack memory difference is a proper "side effect" of the cf7/nano reserving 8 bytes of VDP RAM to track its three mounted disk volumes. This is a good thing. 4 Quote Link to comment Share on other sites More sharing options...
