Rhindle the Dragon Posted January 10, 2017 Share Posted January 10, 2017 I'm continuing this from my latest blog post, Two Fries and a Hamburger, so that "All may benefit from discussion". After installing a composite mod on my Atari, the voltage regulator failed and took a couple of RIOTs with it. Another user suggested I just replace the VR, that it would work better because it's new. Is this a good idea? And do the new regulators fit the old cage heat sinks? Quote Link to comment Share on other sites More sharing options...
BigO Posted January 10, 2017 Share Posted January 10, 2017 (edited) That regulator is a common, standard part. The the only challenge I would expect in swapping it out is maybe the regulator is riveted to the board/heat sink. Edited January 10, 2017 by BigO Quote Link to comment Share on other sites More sharing options...
+save2600 Posted January 10, 2017 Share Posted January 10, 2017 That regulator is a common, standard part. The the only challenge I would expect in swapping it out is maybe the regulator is riveted to the board/heat sink. If so, all you gotta do is snip or drill that puppy out! Quote Link to comment Share on other sites More sharing options...
BigO Posted January 11, 2017 Share Posted January 11, 2017 If so, all you gotta do is snip or drill that puppy out! Yep. It's absolutely doable. I would be totally comfortable drilling or filing/grinding away the rivet. Just throwing out a caveat in case someone else isn't. 1 Quote Link to comment Share on other sites More sharing options...
