WIP- Space Taxi
Just Jeff
Making this game is going to be a lot of hard work.
Have no fear. The tiger team from group Savage has secured the adventure capitol necessary for implementing the code, should actual game code be necessary. Though I will have to submit revised sales estimates, reducing from 10 to 20 million, down to 100 to 200 as many have suggested.
Not every game concept or early WIP becomes a completed game in the end. That's just the nature of development projects done in a person's spare time. I don't think comparing those unfinished projects to the Knight Rider "project" is really fair, though.
My point was that Knight Rider is not really a serious project.
  • 3 years later...
Good Morning,
I re-familiarized myself with what I had going on and then did the taxi thrust, momentum, gravity, and drag routine.  Take a test drive and let me know how it feels.  Let me know what it would take for me to put you in this car today.
A .bin that jumps right to it is attached below, but I also posted it on the first post of this thread and intend to update that one regularly so it's easy to find.
I feel like I re-invented wheel here so maybe there is some more efficient way to implement it.  I used 4 bytes of RAM which are currently at $81 - $84:
VMoveIncrement          ds 1 ;Accumulates the the vertical speed on every frame.  When the sign changes, the taxi moves up or down a line
VerticalSpeed           ds 1 ;Changed by the joystick and then decays with gravity
HMoveIncrement          ds 1 ;Accumulates the the horizontal speed on every frame.  When the sign changes, the taxi moves left or right a clock
HorizontalSpeed         ds 1 ;Changed by the joystick and then decays with drag
And here's the movement routine I came up with.  Basically, the joystick controls the rate (Speed) at which the byte (Increment) is incremented.  When the increment byte changes sign, the taxi moves up or down a line, or over a clock.  Then the sign is flipped back.  This allows for 128 speeds in each direction.
-Jeff:
CabMovement:     SUBROUTINE
.processHSpeed              ;Check to see if its time for a horizontal 1 clock move
    lda HorizontalSpeed
    beq .doneHMove          ;? Can I somehow reduce this to one branch check?
    bmi .goingLeft          ;Positive numbers move the cab right, negative is left
    adc HMoveIncrement
    sta HMoveIncrement
    bpl .doneHMove          ;If we have accumulated more then 128 bits
    inc ObjectX             ;then there is a 1 clock move
    clc
    adc #128                ;Flip the byte back over to positive while preserving the accumulated bits
    ;ora #$ff               :? This seems to halve the speed for some reason
    sta HMoveIncrement    ;Roll it over 180 degrees to positive
    jmp .doneHMove
.goingLeft
    adc HMoveIncrement
    sta HMoveIncrement
    bmi .doneHMove          ;If we have accumulated more then 128 bits
    dec ObjectX             ;then there is a 1 clock move
    sec
    adc #128                ;Flip the byte back over to negative while preserving the accumulated bits
    ;ora #$ff               :?This seems to halve the speed for some reason
    sta HMoveIncrement
    jmp .doneHMove
.doneHMove
.processVSpeed              ;Check to see if its time for a horizontal 1 line move
    lda VerticalSpeed
    bmi .goingDown          ;Positive numbers move the cab up, negative is left
    adc VMoveIncrement
    sta VMoveIncrement
    bpl .doneVMove          ;If we have accumulated more then 128 bits
    inc ObjectY             ;then there is a 1 line move
    clc
    sta VMoveIncrement      ;Roll it over 180 degrees to positive
    jmp .doneVMove
.goingDown
    adc VMoveIncrement
    sta VMoveIncrement
    bmi .doneVMove          ;If we have accumulated more then 128 bits
    dec ObjectY             ;Then there is a 1 line move
    sec
    sta VMoveIncrement
    jmp .doneVMove
.doneVMove
.checkBounds                ;? Temporary code to roll the cab over to the other side of the screen
    ldx ObjectX
    cpx #152
    bne .notRight
    ldy #1
    sty ObjectX
.notRight
    cpx #0
    bne .notLeft
    ldy #151
    sty ObjectX
.notLeft
    ldx ObjectY
    cpx #190
    bne .notTop
    ldy #9
    sty ObjectY
.notTop
    cpx #0
    bne .notBottom
    ldy #189
    sty ObjectY
.notBottom
.gravity                    ;? Probably move this code to Overscan
    ldx VerticalSpeed
    cpx #128                ;Downward speed maxes out at 128.  127 would be up
    beq .noGravityInc
    lda FrameCounter        ;Governs the rate of gravity
    and #%00000011          ;Change VerticalSpeed speed every 4 frames
    bne .noGravityInc       ;If not 0, then skip the gravity increase
    dec VerticalSpeed       ;Increase downward speed (or decrease upward speed)
.noGravityInc
.drag                       ;Reduce horizontal speed if moving to create drag
    lda FrameCounter
    and #%00000111          ;Apply drag every 8th frame
    bne .nodragInc
    lda HorizontalSpeed
    beq .nodragInc          ;If stopped, then no drag
    bmi .goingLeft2         ;If cab if moving left, then reduce Horizontal speed by 1
    dec HorizontalSpeed     ;Therfore cab is moving right, so decrease HorizontalSpeed by 1
    dec HorizontalSpeed     ;Counteract the inc HorizontalSpeed below that always happens when moving.
.goingLeft2
    inc HorizontalSpeed
.nodragInc
    rts
SpaceTaxi.asm.bin
Edited by Just Jeff
  • Like 4
Code simplifications:
;clc
;adc #128 ;Flip the byte back over to positive while preserving the accumulated bits
and #$7f ; make positive
;sec
;adc #128 ;Flip the byte back over to negative while preserving the accumulated bits
ora #$80 ; make negative
Edited by glurk
On 8/6/2022 at 1:00 PM, Bomberman94 said:
The space taxi itself looks really nice. The physics are great and „feels“ correct to me - it could drop a bit faster so it becomes more difficult. Now we need some nice graphics and a collision/landing routine ??
Thanks!  I got something done on all this. I increased the gravity and also the upward thrust and yeah I think its better.  Also added some collision and landing routines as well and even some graphics and sounds.  Most of it, I would call placeholder graphics and sound- more to come.
;clc
;sec
Did this too..  Saving a few bytes and cycles.  Thanks!
New .bin attached.  No fancy crash sequence yet- just a red flash on the screen and your taxi is reset on the top left of the screen.  I debugged most of it, but there are a few left.  You can escape the top left of the screen- basically because P0 isn't written yet where the collision should happen.  Also, if you drive into the side of one of the landing pads, its correctly ruled a crash, but when you're reset on the top left, the taxi just hovers there until you push up.  I have to add more to the landing checks- right now, you can have one leg on the pad and one off and its ruled a good landing.  I think when I fix that, the weird hover will go away.
I think what I'll be doing is cycling through different graphics when landing which will test each leg, one at a time.  If one doesn't collide then its a crash.
-Jeff
SpaceTaxi.asm.bin
Edited by Just Jeff
  • The title was changed to WIP- Space Taxi
Thank you for continuing with this! Space Taxi is one of my favourite games on the C64 and seeing it come to life on the Atari 2600 is going to be amazing. You've got an awesome start to it so far!
Looking forward to playing it on ZPH in the future!
- James
-Jeff
Wow - I played your last bin file (although I have a PAL Atari 2600). Great : physics are fantastic and „feels right“. First walls, platforms and I must say: From the looks of it, it could be even better than on the C64 😳
    ldx VerticalSpeed
    beq .noGravityInc
.noGravityInc
I think you should not use the frame counter here, because it doesn't allow fine adjustments of gravity.
I would use fractional math instead:
.gravity
    lda  VerticalSpeedLo
    sec
    sbc #gravity
    sta  VerticalSpeedLo
    bcs .noGravityInc       ;If no underflow, then skip the gravity increase
.noGravityInc
Also, instead of a fixed maximum speed, you could add friction. E.g. decreasing the speed by a fraction of the speed itself. That way the speed will max out automatically.
Of course the same would work on horizontal speed too.
On 8/6/2022 at 1:46 PM, Prizrak said:
Would be amazing to use the AtariVox and give us "Hey Taxi!"
I give you "Hey Taxi!"..  No AtariVox though.  See attached .bin.
Additionally, the taxi is now fully functional, including landing gear with the very reasonable feature of disabling horizontal thrusters while deployed.
I also rewrote the collision routine so that it can detect half-misses with one leg on and one leg off.  It uses 3 frames to test the collision using 3 different images.  If all three images collide/don't collide as expected, the landing is good.  Two nice side effects of this was that I didn't have to write any code for attempting to land with the gear still up.  Due to the fact that the gear up image is 8 bytes higher than the gear-down image, the frame that is supposed to have no collision, does have a collision- so its ruled a crash.  The other side effect was that the taxi shows a little bounce due to the delay while checking all the frames.  I was worried about it but I think it actually looks good.  Also added the code for crashing due to coming in too fast vertically.
In this bin, I changed the playfield priority so you can view the collision detection if you want to click through frame by frame.  You will see:
image.png.aef9e387862a37bcce274ee425cbb003.png Initial collision detection which triggers the check routine.
image.png.61c6b4d43c539e9a30c5c8882c512636.png Should be a collision.  If the taxi was off the left side a bit, its a crash.
image.png.13d9d6ffc3a20b415e0bd5906de6391b.png Should be a collision.  If the taxi was off the right side a bit, its a crash.
image.png.e2406d414005ba9e0ffb3dad0d25b1be.png Should not be a collision. (Detects side impacts and roof impacts, etc)
And here is the table.  Its checked against the playfield/P0 collision register which sets D7 when there is a collision:
CollisionTable:             ;These match the frame on which collisions should or should not occure when checking.
    .byte $80               ;This one is never used because zero offset graphic frame is already known to collide.
    .byte #0                ;Both legs short- shouldn't be a collision
    .byte #$80              ;One leg short- should be collision
    .byte #$80              ;The other leg short- should be collision
That's all for now-
Jeff
SpaceTaxi.asm.bin
Edited by Just Jeff
  • 2 weeks later...
On 8/6/2022 at 4:47 PM, 4ever2600 said:
Pad 3 please..
I'm on it!
I told myself I wasn't going to worry about comb lines and I'd probably have to shrink the screen down by 16 clocks for time reasons anyway, but things are coming together nicely so far and I'll see if I can stick with the full screen.  Early HMOVEs fit in fairly easily so far and I think its worth it.  Player 1 is the gate, passenger, pad numbers and platform "caps?".
I'm in the middle of writing the taxi and passenger states so basically at this point the game is:  When the passenger, who is clearly inebriated, appears at pad 2, you pick him up and bring him to pad 3.  An argument ensues and he refuses to get out of the cab.  In a fit of suicidal rage, you take off and slam the taxi into a wall, taking the both of you out and starting the process all over again.  Is that how the original game is played?  I don't remember exactly.
SpaceTaxi.asm.bin
Edited by Just Jeff
6 hours ago, Just Jeff said:
I'm on it!
LOL NO WAY!  I used to play that game almost all the way through and never remember it actually happening in the game!  Maybe it's just lore, like a side story they are telling you in the instructions?  Companies used to do that to hype up the game.
Then again, I could just be wrong...  been a long time.
    ldx VerticalSpeed
    beq .noGravityInc
.noGravityInc
.gravity
    lda  VerticalSpeedLo
    sec
    sbc #gravity
    sta  VerticalSpeedLo
.noGravityInc
OK, I see the difference.  Thanks!  Though yours does still run every frame- correct?  This looks a little like what I did for friction I think, though my "#gravity" is effectively #1 there.
As for friction being a fraction of the speed itself- how do you suggest doing that?  LSRs of the speed byte?  A divide loop?  I'm pretty happy with the way the taxi behaves now, except it is pretty noticeable at very slow speeds that the friction is a bit much.  So I think this would help that.
Attaching the latest .bin..  This is now a somewhat playable screen.  Notice an itinerary is now on the bottom right corner, in the dashboard.
It took me quite a while to figure this out and used more tables than I thought it would.  Most of this is based on RAM bytes named "Itinerary" and "PassengerState".  In the attached bin, the Itinerary essentially says- Pad2, Pad3, Pad 4, Up.  PassengerState tracks if he is visible, boarding, hailing, etc,  The goal of all of this is that the kernel only has to decide if the passenger is on that level of pads or not- nothing more.  So in the above screenshot, the kernel only knows the passenger is on pad 1 or 2 because in RAM, Sprite1 is already loaded with zeros, and Sprite2 is already loaded with the passenger graphics.  When it gets to pads 3 and 4, it simply skips over them both.
In VBLANK:
FlightPlanLevels:   ;This is how the kernel determines if it should diplay the passenger on a particular level of pads
    ;.byte 1        ;Need an odd number of pads
    .byte 2
    .byte 2
    .byte 1
;Moved FlightPlanSides to bank2 because it loads graphics from bank 2
;This table contains ObjectX and ObjectY limits to check if contact was made at the right pad from the Itinerary.
FlightPlanPickUps:  ;From bottom, up
WestLimitPU
    ;.byte #0       ;Making Itinerary offset $ff = Up.
    .byte #117      ;Pickup     Pad 4
    .byte #0        ;Dropoff    Pad 3
    .byte #117      ;Pickup     Pad 2
EastLimitPU
    ;.byte #35      ;Dropoff
    .byte #152      ;Pickup
    .byte #35       ;Dropoff
    .byte #152      ;Pickup
NorthLimitPU
    ;.byte  #186    ;Dropoff
    .byte #114      ;Pickup
    .byte #114      ;Dropoff
    .byte #186      ;Pickup
SouthLimitPU
    ;.byte #123     ;Dropoff
    .byte #75       ;Pickup
    .byte #75       ;Dropoff
    .byte #123      ;Pickup
ShoutOuts4:  ;Currently keeping the graphics 8 high- so this number times 8
    .byte #UPGfx_HEIGHT-8   ;Up!
    .byte #HeGfx_HEIGHT-8   ;Hey!
    .byte #PaGfx_HEIGHT-8   ;Pad 3
ShoutOuts5:
    .byte #PexGfx_HEIGHT-8  ;Up!
    .byte #YGfx_HEIGHT-8    ;Hey!
    .byte #D3Gfx_HEIGHT-8   ;Pad 3
And in another bank:
FlightPlanSides:
    ;.byte 0 Removed so the last item is a pickup, and therefore the gate will open
    .byte 1
    .byte 0
    .byte 1
The in-kernel decision:
.loop2                          ;-----0 3 Five cycles quicker for the remainder of the loop
    sta GRP0                    ;3 11
    lda PassengerLevel          ;3 14 Check to see if the passenger is on this line
    bne .notHere                ;2/3 16/17 Zero means he is on this level of pads
    lda Sprite1,x               ;4 18
	sta GRP1				    ;3 21
-Jeff
SpaceTaxi.asm.bin
Edited by Just Jeff
1 hour ago, Just Jeff said:
As for friction being a fraction of the speed itself- how do you suggest doing that?  ASRs of the speed byte?  A divide loop?
I am always doing shifts. Not only powers of 2 but also combinations of shifts (e.g. 3/32 or 5/64) are easily possible here for the friction. And that is usually good enough. Also make sure that the frictions friction does not become zero at low speeds (e.g. by rounding up).
ZeroPage Homebrew is playing Space Taxi on tomorrow's stream LIVE on Twitch, hope you can join us!
Games:
 WATCH AT 1080P60 FOR FULL QUALITY
