jeremiahjt Posted January 15, 2017 Share Posted January 15, 2017 I plugged in my Lynx the other night to see if I could improve my score for Klax for the high score club and disaster struck. I heard a little pop and the screen was blank. I used the same AC adapter I always use in the same outlet I usually use. I tried the same AC adapter on another outlet and I tried using AA batteries and every time the screen looked the same. Did I fry my Lynx? Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted January 16, 2017 Share Posted January 16, 2017 You really need to check if the 5v level has gone beyond 5v - if it has, it probably killed Suzy or Mikie. is this a Lynx 1 or Lynx 2? Sometimes it can be easier to measure the 5v VCC by using one of those EPROM based repro carts - because its easy to measure on the EPROM to check the 5v level. Quote Link to comment Share on other sites More sharing options...
jeremiahjt Posted January 16, 2017 Author Share Posted January 16, 2017 (edited) You really need to check if the 5v level has gone beyond 5v - if it has, it probably killed Suzy or Mikie. is this a Lynx 1 or Lynx 2? Sometimes it can be easier to measure the 5v VCC by using one of those EPROM based repro carts - because its easy to measure on the EPROM to check the 5v level. Lynx I. I do not have any reproduction carts. Edited January 16, 2017 by jeremiahjt Quote Link to comment Share on other sites More sharing options...
Nachoman Posted January 27, 2017 Share Posted January 27, 2017 similar thing happened to mine, I would suggest not turning it on until you replace the ZD and Mossfet. brought mine back from the dead and didn't fry anything. Quote Link to comment Share on other sites More sharing options...
