CannibalCat Posted January 16, 2017 Share Posted January 16, 2017 Hi, was seeing odd artifacts with an EPROM emulator unit I'm using and was wondering if the speed of memory in it (read time) was a factor, the static RAM is at 70ns. I have a burned EPROM of the same code which has a speed of 45ns and works fine, is there a minimum access speed for the CV? Thanks, Rich Quote Link to comment Share on other sites More sharing options...
PkK Posted January 16, 2017 Share Posted January 16, 2017 At the clock speed of the Z80 in the ColecoVision the memory should have an access time of 280 ns or faster. There might be an additional delay of a few ns due to some logic chips in the paths, so I'd recommend 250 ns or faster to be on the safe side. Philipp Quote Link to comment Share on other sites More sharing options...
+nanochess Posted January 16, 2017 Share Posted January 16, 2017 The old EPROM used are very slow, typically 200ns. I suspect more of a RAM address setup problem. I've had the experience that if you keep CE set some RAM memories show transitory "trash" in reading. I would put CE and OE together. Also if your RAM is fully CMOS maybe you would need pull up. But I don't remember if in inputs or outputs to account for TTL to CMOS different voltages for logical 1. 1 Quote Link to comment Share on other sites More sharing options...
CannibalCat Posted January 16, 2017 Author Share Posted January 16, 2017 The old EPROM used are very slow, typically 200ns. I suspect more of a RAM address setup problem. I've had the experience that if you keep CE set some RAM memories show transitory "trash" in reading. I would put CE and OE together. Also if your RAM is fully CMOS maybe you would need pull up. But I don't remember if in inputs or outputs to account for TTL to CMOS different voltages for logical 1. nanochess... thank you, your advice pointed me in the right direction... problem solved! 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted January 16, 2017 Share Posted January 16, 2017 nanochess... thank you, your advice pointed me in the right direction... problem solved! Glad to be of help 1 Quote Link to comment Share on other sites More sharing options...
