help with mads macro
Hi *,
I could need some help with a MADS macro.
Similar to macros like "mva" and "mwa" I would like to have a macro for "double words" (32bit). For instance
 $org 2000
.macro mdwa src,dst
 lda <:src
 sta :dst
 lda >:src
 sta :dst+1
 lda <(:src/65355)
 sta :dst+2
 lda >(:src/65535)
 sta :dst+3
.endm
.struct values
 longvalue .dword
.ends
m values
 mdwa #$12345678,m.longvalue
Unfortunately my attempt does not "compile" . MADS tells me something like "Extra character on line".
It's probably pretty obvious but I'm giving up for now :)
MADS doesn't seem to like comma delimited macro arguments in some instances, but even changing that didn't help here. If it's useful, this is an adaptation of the "mda" macro I use:
	org 2000
mdwa 	.macro " "
	.if .not [:0 = 4]
		.error 'Wrong Number of Arguments!'
	.else
		.if :1 = '#' ; immediate mode
			lda #[:2 & $FF]
			sta :4
			lda #[[:2 >> 8 ] & $FF]
			sta :4+1
			sbc #[[:2 >> 16] & $FF]
			sta :4+2
			lda #[:2 >> 24]
			sta :4+3
		.else
			ldy #3
?1
			lda :2,y
			sta :4,y
			dey
			bpl ?1
		.endif
	.endif
	.endm
.struct values
 longvalue .dword
.ends
m values
n values
 mdwa #$12345678 m.longvalue
 mdwa n.longvalue m.longvalue
It's versatile, since it uses a defined delimiter to allow detection of an immediate mode first argument (see example calls). Use of the index registers is just a personal preference in order to reduce bloat. Edited by flashjazzcat
  • 1 year later...
Hi *,
 $org 2000
.macro mdwa src,dst
 lda <:src
 sta :dst
 lda >:src
 sta :dst+1
 lda <(:src/65355)
 sta :dst+2
 lda >(:src/65535)
 sta :dst+3
.endm
.struct values
 longvalue .dword
.ends
m values
I figured out the cause of the "Extra character on line" error and thought I would post it here for future reference. I was getting the same error, even when I used the example macros from the MADS documentation. The problem was that I was using an older version of MADS, before support was added for argument labels. Older versions only supported numeric arguments.
