WIZZARD77 Posted January 24, 2017 Share Posted January 24, 2017 (edited) I've recently been playing my 2600 (4-switch) alot lately with all the new homebrews out. I have it s-video modded with one of the Electronicsntimentalities boards that I installed a while ago and it works well, but Lately I've noticed buzzing through the speakers when bright colors are diplayed. The Sword of Iffrit game select screen, with the whole screen white, produces the noise it is less in game (green backgrounds) but still noticeable. It doesn't drown out the sound at all just abit annoying. What i'm wondering is, what can I do to reduce the noise? Edited January 24, 2017 by WIZZARD77 Quote Link to comment Share on other sites More sharing options...
mojoatomic Posted January 24, 2017 Share Posted January 24, 2017 Replace the 2 .1uF chicklet caps in the power supply stage and the 2 820pF polystyrene caps in the audio section. I suspect the .1uFs are bleeding. Quote Link to comment Share on other sites More sharing options...
mojoatomic Posted January 24, 2017 Share Posted January 24, 2017 (edited) c241-c242 & c206-c207 on the cx2600A model. Also, without knowing what your A/V mod looks like, I might also suspect dressing of ground on your a/v connections. Edited January 24, 2017 by mojoatomic Quote Link to comment Share on other sites More sharing options...
WIZZARD77 Posted January 24, 2017 Author Share Posted January 24, 2017 I'll see if have some replacement ones (i should ) and swap out for new ones to see if it helps. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
mojoatomic Posted January 24, 2017 Share Posted January 24, 2017 Most welcome. Also, while your at it... might as well replace the two 4.7uf radial caps and the 2200uf axial at C201, C214,& C243 as they most certainty have a high ESR value and are 20 years past needing replacement. Quote Link to comment Share on other sites More sharing options...
