Wyluli Wolf Posted January 25, 2017 Share Posted January 25, 2017 (edited) I'd like to build an arcade style joystick for the sega master system and have a few questions. 1. Am I correct that a joystick can be built similar to an atari 7800 stick by using a DB9 extention cable and directly wiring to the joystick and buttons without a PCB or chip needed? 2. If the above is correct, it looks like button 1 connects to 6 and button 2 to 9 on the cable. Is anything else needed such as resistors, diodes, etc and if so, where? Thanks! Edited January 25, 2017 by Wyluli Wolf Quote Link to comment Share on other sites More sharing options...
alex_79 Posted January 25, 2017 Share Posted January 25, 2017 Am I correct that a joystick can be built similar to an atari 7800 stick by using a DB9 extention cable and directly wiring to the joystick and buttons without a PCB or chip needed? Correct. it looks like button 1 connects to 6 and button 2 to 9 on the cable. Correct. Is anything else needed such as resistors, diodes No other components are needed. Just wire the buttons to the corresponding pins. 1 Quote Link to comment Share on other sites More sharing options...
Wyluli Wolf Posted January 26, 2017 Author Share Posted January 26, 2017 Correct. Correct. No other components are needed. Just wire the buttons to the corresponding pins. Well that is just too easy! Thanks a bunch! Quote Link to comment Share on other sites More sharing options...
