alsp Posted February 17, 2017 Share Posted February 17, 2017 (edited) Hi, This topic opened to reseach market and collect requests for SDrive-ARM device. Please check details on github. Short characteristics: SDrive was developed originally by C.P.U. team in 2008 and use AT Mega 8 processor; It is extension of previous project with following features: Works with Atari 8-bit systems like Atari 800, 800xl, XE/GS, etc. 5V compatible 32bit Cypress CY8C4245AXI ARM processor with: 48 MHz core 32Kb Flash 4Kb RAM MicroSD card reader Capacitive buttons (Next drive, Prev drive, Boot drive) 6 LEDs (1 green, 1 red and 4 yellow) Reset button Each SIO pin connected to ARM I/O pin (Possibility for functionality extension) One RW/RO switch for microSD card original drive ID's switchng DIPs excluded Estimated prices: PCB + Case- $15 PCB + Case + pre-programmed ARM - $25 Assembled device - $50 Please write in this topic if you want to buy. Edited February 17, 2017 by alsp Quote Link to comment Share on other sites More sharing options...
ravard Posted February 17, 2017 Share Posted February 17, 2017 I'm interested in 1 assembled device and possibly 1 PCB and Case. With the PCB and Case, do you supply a complete list of needed components and instructions and I would assemble, solder, and program everything else? Thanks. ravard Quote Link to comment Share on other sites More sharing options...
JoSch Posted February 17, 2017 Share Posted February 17, 2017 I would be interested in one. What exactly would one have to do to assemble it? Even soldering the ARM on the PCB? Quote Link to comment Share on other sites More sharing options...
+Philsan Posted February 17, 2017 Share Posted February 17, 2017 1 assembled device for me. Quote Link to comment Share on other sites More sharing options...
beamer320i Posted February 17, 2017 Share Posted February 17, 2017 Hi, Put me down for one assembled piece please! Quote Link to comment Share on other sites More sharing options...
alsp Posted February 17, 2017 Author Share Posted February 17, 2017 I would be interested in one. What exactly would one have to do to assemble it? Even soldering the ARM on the PCB? Yes, ARM soldering is needed, but used chip is quite easy to solder. Quote Link to comment Share on other sites More sharing options...
alsp Posted February 17, 2017 Author Share Posted February 17, 2017 With the PCB and Case, do you supply a complete list of needed components and instructions and I would assemble, solder, and program everything else? Thanks. Of course all information already placed on github. And if it is needed will be printed and added to package on request. Quote Link to comment Share on other sites More sharing options...
gozar Posted February 17, 2017 Share Posted February 17, 2017 I'd be interested in two assembled drives. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
+Firedawg Posted February 17, 2017 Share Posted February 17, 2017 Hello,Put me down for one assembled piece please and two PCB + Case. Quote Link to comment Share on other sites More sharing options...
akator Posted February 17, 2017 Share Posted February 17, 2017 Would like to order 1 assembled device. Quote Link to comment Share on other sites More sharing options...
VicViper Posted February 17, 2017 Share Posted February 17, 2017 So would it be as simple as loading roms into the SD card? How complicated would this be to run games? As simple as an everdrive? Quote Link to comment Share on other sites More sharing options...
fastofruto Posted February 17, 2017 Share Posted February 17, 2017 Hi, I would like to order 1 assembled device thanks Quote Link to comment Share on other sites More sharing options...
Witchboard Posted February 17, 2017 Share Posted February 17, 2017 Hi. I'm interested, but needing some clarification about the PCB + Case + pre-programmed ARM option. Are all the components included and need to be soldered on to the board, or are they all soldered on with exception of the processor? Quote Link to comment Share on other sites More sharing options...
alsp Posted February 17, 2017 Author Share Posted February 17, 2017 Hi. I'm interested, but needing some clarification about the PCB + Case + pre-programmed ARM option. Are all the components included and need to be soldered on to the board, or are they all soldered on with exception of the processor? Hi, no, this option means as is - there will be one empty PCB, one empty case and one programmed ARM chip. Quote Link to comment Share on other sites More sharing options...
alsp Posted February 17, 2017 Author Share Posted February 17, 2017 So would it be as simple as loading roms into the SD card? How complicated would this be to run games? As simple as an everdrive? ROMs can be just copied to microSD card on any PC with card reader. Games starting are easy also - just assigning needed image to drive in bootloader and after it start game. Quote Link to comment Share on other sites More sharing options...
+Philsan Posted February 17, 2017 Share Posted February 17, 2017 You should move this thread to A8 forum. Here not many people will read it and your link in the A8 SDrive-ARM thread will soon be submerged by other posts. As you can see, at the moment a preorder thread for another device is running in the A8 forum. Quote Link to comment Share on other sites More sharing options...
tep392 Posted February 17, 2017 Share Posted February 17, 2017 Looks really nice. Count me in for 1 assembled unit. Quote Link to comment Share on other sites More sharing options...
AtariBuff Posted February 17, 2017 Share Posted February 17, 2017 1 assembled device, please. Quote Link to comment Share on other sites More sharing options...
Witchboard Posted February 17, 2017 Share Posted February 17, 2017 Hi, no, this option means as is - there will be one empty PCB, one empty case and one programmed ARM chip. So whomever purchases that option would be required to buy all the additional LEDs, resistors, VRM, etc that listed on the parts list document on github? Quote Link to comment Share on other sites More sharing options...
VicViper Posted February 17, 2017 Share Posted February 17, 2017 ROMs can be just copied to microSD card on any PC with card reader. Games starting are easy also - just assigning needed image to drive in bootloader and after it start game. if it's as easy as it sounds, I would take one assembled. Just boot the system up as though I where booting from a drive? Is there an actual graphic user interface, or do I need to load each ROM individually? Quote Link to comment Share on other sites More sharing options...
tep392 Posted February 17, 2017 Share Posted February 17, 2017 Search "atari sdrive" on youtube and you'll find some good video's showing how it works. Quote Link to comment Share on other sites More sharing options...
VicViper Posted February 17, 2017 Share Posted February 17, 2017 Search "atari sdrive" on youtube and you'll find some good video's showing how it works. wow that does look pretty simple, I'm definitely in. Do you need to add files to the SD card other than the roms? Quote Link to comment Share on other sites More sharing options...
tep392 Posted February 17, 2017 Share Posted February 17, 2017 I haven't used this so I don't know what you need to do to setup a new SD card. But I think the programs you load onto it will be ATR disk images, not rom files. Quote Link to comment Share on other sites More sharing options...
alsp Posted February 18, 2017 Author Share Posted February 18, 2017 So whomever purchases that option would be required to buy all the additional LEDs, resistors, VRM, etc that listed on the parts list document on github? First and second variant targeted to geeks who like solder iron =) So all remaining parts can be easily taken from digikey or mouser. 1 Quote Link to comment Share on other sites More sharing options...
Sleepy Posted February 18, 2017 Share Posted February 18, 2017 Hi, please put down one assembled device for me. Thanks, Sleeπ Quote Link to comment Share on other sites More sharing options...
