+SpiceWare Posted February 27, 2017 Author Share Posted February 27, 2017 NTSC Coleco Gemini (French Canadian version) appears to work fine. The picture looks just like the original post. Was wondering if it would work with any of the clone systems, thanks! 1 Quote Link to comment Share on other sites More sharing options...
yell0w_lantern Posted February 28, 2017 Share Posted February 28, 2017 I cleaned my Jr and there was no difference. 1 Quote Link to comment Share on other sites More sharing options...
Turbo-Torch Posted February 28, 2017 Share Posted February 28, 2017 NTSC 4 Switch Woody PASSED NTSC 6 Switch Light PASSED ColecoVision Expansion module #1 PASSED 1 Quote Link to comment Share on other sites More sharing options...
maiki Posted February 28, 2017 Share Posted February 28, 2017 A couple of tests: NTSC Jr. (underside of board says Rev. F): IMG_5453.JPG I had this picture once. Replugging Harmony or repowering the console and no black bars. So I think it has to do with bad contacts not the console hardware. 1 Quote Link to comment Share on other sites More sharing options...
alex_79 Posted February 28, 2017 Share Posted February 28, 2017 [...] Are these results assuming everyone has cleaned their cartidge port/harmony cart? [...] I did clean the Harmony cart and the cartridge port of my 7800 before trying the test rom. I must add that it originally used a mask rom for the bios, but I modified it to use eproms instead because I wanted to try the 7800 DevOS. (It now has the standard PAL bios, but burned on eprom) Maybe I will try a different brand eprom to see if it makes any difference. 1 Quote Link to comment Share on other sites More sharing options...
eccofonic Posted February 28, 2017 Share Posted February 28, 2017 Demo worked fine in my NTSC 4 switch Woody using both an original Harmony cart and a Harmony Encore. The RPG demo from the other thread really looks fantastic on a CRT. 2 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted February 28, 2017 Author Share Posted February 28, 2017 Demo worked fine in my NTSC 4 switch Woody using both an original Harmony cart and a Harmony Encore.I don't know if anybody else has tested with the Encore before, Thanks! The RPG demo from the other thread really looks fantastic on a CRT.And that's with "programmer graphics" - imagine how much better it would look if somebody like Nathan had designed the graphics. Quote Link to comment Share on other sites More sharing options...
+Trebor Posted February 28, 2017 Share Posted February 28, 2017 NTSC 2600 4 Switch Woody - Success NTSC 7800 AT84 Serial with Expansion - Success 1 Quote Link to comment Share on other sites More sharing options...
bah Posted March 1, 2017 Share Posted March 1, 2017 I tried a few with no failures, all NTSC: 6 sw heavy-ok 6 sw sears heavy-ok 6 sw light-ok (2 units) 6 sw sears light-ok 4 sw -ok (6 units) 4sw vader-ok sears vid arcade II -ok Junior large rainbow -ok (2 units) 7800 non port- ok 7800 with dumper bios-ok 5200 with vcs converter -ok Gemini-ok and a moment of silence, as a heavy 6 was found dead in this testing.......thanks 3 Quote Link to comment Share on other sites More sharing options...
groundtrooper Posted March 1, 2017 Share Posted March 1, 2017 I don't know if anybody else has tested with the Encore before, Thanks! And that's with "programmer graphics" - imagine how much better it would look if somebody like Nathan had designed the graphics. Spiceware - My Harmony is an Encore. Sorry I didn't clarify in my original report. 1 Quote Link to comment Share on other sites More sharing options...
davyK Posted March 1, 2017 Share Posted March 1, 2017 That's unexpected. Bus stuffing only comes into play to draw the black behind the digits. The digits, sync, etc. are all standard. ... ... BUS uses a custom bankswitching scheme - the Harmony Cart originally only supported the bankswitching in use from back in the day. Check the version of you Harmony's firmware by selecting the [.] line: IMG_8421.jpg then hitting fire: IMG_8422.jpg I'm running v1.05 which is when support for custom bankswitching was added. Using 1.04. Will see if I can find my cable and then try 1.05!! Quote Link to comment Share on other sites More sharing options...
cd-w Posted March 1, 2017 Share Posted March 1, 2017 (edited) I should add my consoles: PAL Jr - ok PAL Light4 - ok Chris Edited March 1, 2017 by cd-w 1 Quote Link to comment Share on other sites More sharing options...
Turbo-Torch Posted March 1, 2017 Share Posted March 1, 2017 Spiceware - My Harmony is an Encore. Sorry I didn't clarify in my original report. Same here...my tests were also done on an Encore. Quote Link to comment Share on other sites More sharing options...
+frankodragon Posted March 2, 2017 Share Posted March 2, 2017 My 7800 NTSC system tested OK with Encore version. 1 Quote Link to comment Share on other sites More sharing options...
+Nathan Strum Posted March 4, 2017 Share Posted March 4, 2017 (edited) My recently repaired NTSC heavy-sixer is happily stuffing busses: Edited March 4, 2017 by Nathan Strum 2 Quote Link to comment Share on other sites More sharing options...
+Nathan Strum Posted March 4, 2017 Share Posted March 4, 2017 Just finished re-capping the last of my 2600's: Sears NTSC four-switch: Vader NTSC four-switch: And finally, an NTSC 7800 (w/expansion port): 2 Quote Link to comment Share on other sites More sharing options...
mojoatomic Posted March 4, 2017 Share Posted March 4, 2017 Wood 4 switch version 8 board - passed sears Tele games light 6 passed 1 Quote Link to comment Share on other sites More sharing options...
davyK Posted March 5, 2017 Share Posted March 5, 2017 Using 1.04. Will see if I can find my cable and then try 1.05!! Upgraded to 1.05 and test passed on 6 switch PAL woody and PAL 7800. 2 Quote Link to comment Share on other sites More sharing options...
Marco Miccoli Posted March 5, 2017 Share Posted March 5, 2017 Atari 2600 jr. (Rainbow) PAL - OK Atari 2600 black PAL - OK Atari 7800 PAL - OK Atari 2600 Haevy-Sixer NTSC - OK 2 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted March 5, 2017 Author Share Posted March 5, 2017 Upgraded to 1.05 and test passed on 6 switch PAL woody and PAL 7800. Awesome, glad that was the solution! You'll have to check out the other Bus Stuffing Demos now Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted March 7, 2017 Author Share Posted March 7, 2017 Thank you for all your help, I really appreciate it! Regrettably, ZackAttack has determined the problem with the Juniors is most likely an electrical issue that, if a solution can to be found, would require hardware modifications to the Junior. Al does not wish to sell games that won't run on the Junior, and I don't blame him one bit, so I won't be using BUS for projects destined for the AtariAge store. I'll probably still do things like tinker with the RPG demo, and will make those freely available for use via Harmony Cart and Stella. cd-w and I have been working on a new cartridge format called CDF. CDF is basically DPC+ with improvements we learned by creating BUS. I'll be using it for the Draconian reboot. CDF features: Fast fetch mode 5 cycle TIA updates like DPC+ 32 datastreams double that of DPC+ and BUS. In DPC+ and BUS after drawing the gameplay area I had to reassign the datafetchers to display the score/lives/level/etc, which took a bit of overhead. With 32 datastreams there's enough to go around without having to reassign them midscreen. identical datastreams All datastreams work exactly the same and have an X.Y increment. Harmony/Melody driver code is simpler (smaller) when all datastreams work the same, plus they're more flexible supporting increments such as 2.0, 1.5, 1.0, 0.5, etc. 2.0 is very useful for flicker blind displays like the 128x200 bitmap or the Draconian logo datastreams configured by C(or ARM) code In DPC+ datastreams could only be configured by 6507 code, taking scanlines worth of processing time to do so. In BUS and CDF this is done in C, which is much faster. 3 voice music Just like DPC+ and BUS digital sample support like BUS - no need to set aside a 2K of Display Data, which was a major headache in Frantic more efficient driver the driver's smaller, like BUS, so more ROM (2K) and RAM (2K) is available for the game designed for C (or ARM) code most features will require the use of C or ARM code. 4 Quote Link to comment Share on other sites More sharing options...
+Nathan Strum Posted March 7, 2017 Share Posted March 7, 2017 Regrettably, ZackAttack has determined the problem with the Juniors is most likely an electrical issue that, if a solution can to be found, would require hardware modifications to the Junior. Al does not wish to sell games that won't run on the Junior, and I don't blame him one bit, so I won't be using BUS for projects destined for the AtariAge store. Disappointing. Understandable, but disappointing nonetheless. Pesky Juniors. Still, CDF sounds like a very promising alternative. 1 Quote Link to comment Share on other sites More sharing options...
cd-w Posted March 7, 2017 Share Posted March 7, 2017 (edited) I would really like to get one of the Jrs that doesn't work with bus stuffing to do my own testing. I've bought 4 PAL Jrs now and they all work fine! If anyone would like to sell their non-working NTSC Jr (and doesn't mind shipping to the UK) - please let me know! Chris Edited March 7, 2017 by cd-w 1 Quote Link to comment Share on other sites More sharing options...
+Nathan Strum Posted March 7, 2017 Share Posted March 7, 2017 I would really like to get one of the Jrs that doesn't work with bus stuffing to do my own testing. I've bought 4 PAL Jrs now and they all work fine! If anyone would like to sell their non-working NTSC Jr (and doesn't mind shipping to the UK) - please let me know! Chris You can use mine. It doesn't not work as bad as some of them do though (I think that made sense). Would you want one that didn't work typically, or the worst case? Quote Link to comment Share on other sites More sharing options...
davyK Posted March 7, 2017 Share Posted March 7, 2017 (edited) The effects achieved in those demos are impressive. Pity about the JRs but there are probably quite a few of them around so I can see why AA would have reservations about selling carts that have problems with them. Edited March 7, 2017 by davyK Quote Link to comment Share on other sites More sharing options...
