GDMike Posted November 3, 2020 Share Posted November 3, 2020 (edited) But I don't seem to be getting past setting up the pab. I have, like I mentioned earlier. FLNM BSS 48 - and it's located right after the FSPAB definition. And somewhere, not sure if it matters where I put this, either before or after the pab setup, but I have. PBAD EQU >79E Apparently it makes a difference on where the pab is in relation to its counter parts when defining, at least when defining the filename. Edited November 3, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 3, 2020 Share Posted November 3, 2020 22 minutes ago, GDMike said: But I don't seem to be getting past setting up the pab. I have, like I mentioned earlier. FLNM BSS 48 - and it's located right after the FSPAB definition. And somewhere, not sure if it matters where I put this, either before or after the pab setup, but I have. PBAD EQU >79E Apparently it makes a difference on where the pab is in relation to its counter parts when defining, at least when defining the filename. The filename (pathname) is part of the PAB and, wherever you store it temporarily in CRAM, it must be located in VRAM with its tenth byte (byte 9) containing the filename length byte followed immediately by said filename from byte 10 on. DSRLNK and the DSR do not care how you have set up CRAM excepting for the pointer at >8356. ...lee 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 (edited) BUT I thought, and I keep confusing, byte 9 of FSPAB here but I made that value a higher value to cover the path size. So I made it >30 and the filename followed it as a FLNM BSS 48 And I think I was told it's wrong. So I'm not getting anywhere Edited November 3, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 3, 2020 Share Posted November 3, 2020 Just now, GDMike said: BUT I thought, and I keep confusing, byte 9 of FSPAB here, but I made that value a higher value to cover the path size. So I made it >30 and the filename followed it as a FLNM BSS 48 And I think I was told it's wrong. So I'm not getting anywhere Byte 9 is NOT the value 9 it is the location in the PAB of where you must put the filename’s length. If the full “filename” is DSK2.ABCDEFGHIJ, byte 9 must contain the value 15 because that is how long the filename is. ...lee Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 1 minute ago, Lee Stewart said: Byte 9 is NOT the value 9 it is the location in the PAB of where you must put the filename’s length. If the full “filename” is DSK2.ABCDEFGHIJ, byte 9 must contain the value 15 because that is how long the filename is. ...lee Yes, I understand. But here I have a case where I don't know the length. Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 Just now, GDMike said: Yes, I understand. But here I have a case where I don't know the length. so I thought it should equal the number I have in my BSS statement following the FSPAB. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 3, 2020 Share Posted November 3, 2020 10 minutes ago, GDMike said: Yes, I understand. But here I have a case where I don't know the length. 9 minutes ago, GDMike said: so I thought it should equal the number I have in my BSS statement following the FSPAB. You must reserve enough space for your PAB in VRAM, but, you do not need to copy the reserved length of bytes to the PAB. You just need to copy the actual counted string for the actual file before you call DSRLNK—and, you cannot call DSRLNK without knowing the length of the filename of the file you want to open/create. ...lee 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 1 minute ago, Lee Stewart said: You must reserve enough space for your PAB in VRAM, but, you do not need to copy the reserved length of bytes to the PAB. You just need to copy the actual counted string for the actual file before you call DSRLNK. ...lee So I take it that the byte 9 should be >09 No matter. And then.. "You just need to copy the actual counted string for the actual file before you call to DSRLNK. If this is true. I've got it! Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 (edited) So after the PAB is defined, what should be defined next in my code.. The filename or the count. Sorry but this is gotta be understood. Better yet, can you give me an example of a pab with no defined filename. This way I can see what byte 9 looks like and what follows the pab. Lol ? Edited November 3, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 3, 2020 Share Posted November 3, 2020 2 minutes ago, GDMike said: So I take it that the byte 9 should be >09 No matter. And then.. "You just need to copy the actual counted string for the actual file before you call to DSRLNK. If this is true. I've got it! No—The only reason byte 9 should be >09 is if the filename has that many bytes. DSK1.MYFILE001 has 14 characters. You would store >0E. ...lee Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 Just now, Lee Stewart said: No—The only reason byte 9 should be >09 is if the filename has that many bytes. DSK1.MYFILE001 has 14 characters. You would store >0E. ...lee Oh..I thought your silence was saying my >30 in byte 9 was wrong. So I'm assuming there's nothing wrong with my PAB and it's following information. Ok Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 3, 2020 Author Share Posted November 3, 2020 I might be making things worse but to make things clearer you could consider laying out your CPU RAM image of the PAB so that it is easy to remember what is what. Use the CPU PAB as a mirror image of the VDP PAB. Use the mirror for all control and copy it into VDP RAM before calling dsrlink. For I notice that your CPU PAB does not make it clear where the filename text goes (at least to me) and how much space is allocated for the text. SBUFF EQU >1000 * BUFFER ADDRESS SBUFF1 EQU >1FE4 * PADDED WITH 28 SPACES VDPPAB EQU >79E * PAB ADDRESS ********************************************************* * PAB DATA STRUCTURE MIRROR IN CPU RAM CPUPAB * used for writing entire CPUPAB to VDPPAB POPCOD BYTE 00 * error bits & op code PFLAG BYTE 02 * status flag field PBUFF DATA SBUFF * pointer to VDP file buffer PLEN BYTE >80 * record length for fixed length records PCHARS BYTE >00 * no. bytes to write or no. bytes read from file PRECRD DATA 0000 * relative files record number to read/write OFFSET BYTE 00 * cassette use only FNAML BYTE 09 * filename length FNAME BSS 32 * extra room for long device strings ******************************************************** The idea is you now have each field of the PAB available as a named label. Each field is there to get at it by name. When the CPU PAB image is all set the way you want you blast the whole thing over to VDP RAM with a VMBW and call DSRLINK. To get the results READ the VDP back into your CPU RAM mirror PAB and you can check status for example. You can also create lists of opcodes to make it clearer when you are using the PAB to read,write, rewind etc. * FILE OPERATION CODES FOPEN BYTE 00 FCLOSE BYTE 01 FREAD BYTE 02 FWRITE BYTE 03 FRWIND BYTE 04 FLOAD BYTE 05 FSAVE BYTE 06 FDELET BYTE 07 * EXAMPLE MOVB @FOPEN,@POPCOD This kind of thing helps my old brain remember what is going where. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 3, 2020 Share Posted November 3, 2020 5 minutes ago, GDMike said: Better yet, can you give me an example of a pab with no defined filename You can do whatever you want to the PAB before you call DSRLNK. There is no magic happening when you copy stuff to the PAB location. It just needs to have all of the proper information WHEN you call DSRLNK. ...lee 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 (edited) FSPAB DATA >0012,SBUFF,>8000,>0000,>0030 * OP DV 128 FLNM BSS 48 Edited November 3, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 7 minutes ago, TheBF said: I might be making things worse but to make things clearer you could consider laying out your CPU RAM image of the PAB so that it is easy to remember what is what. Use the CPU PAB as a mirror image of the VDP PAB. Use the mirror for all control and copy it into VDP RAM before calling dsrlink. For I notice that your CPU PAB does not make it clear where the filename text goes (at least to me) and how much space is allocated for the text. SBUFF EQU >1000 * BUFFER ADDRESS SBUFF1 EQU >1FE4 * PADDED WITH 28 SPACES VDPPAB EQU >79E * PAB ADDRESS ********************************************************* * PAB DATA STRUCTURE MIRROR IN CPU RAM CPUPAB * used for writing entire CPUPAB to VDPPAB POPCOD BYTE 00 * error bits & op code PFLAG BYTE 02 * status flag field PBUFF DATA SBUFF * pointer to VDP file buffer PLEN BYTE >80 * record length for fixed length records PCHARS BYTE >00 * no. bytes to write or no. bytes read from file PRECRD DATA 0000 * relative files record number to read/write OFFSET BYTE 00 * cassette use only FNAML BYTE 09 * filename length FNAME BSS 32 * extra room for long device strings ******************************************************** The idea is you now have each field of the PAB available as a named label. Each field is there to get at it by name. When the CPU PAB image is all set the way you want you blast the whole thing over to VDP RAM with a VMBW and call DSRLINK. To get the results READ the VDP back into your CPU RAM mirror PAB and you can check status for example. You can also create lists of opcodes to make it clearer when you are using the PAB to read,write, rewind etc. * FILE OPERATION CODES FOPEN BYTE 00 FCLOSE BYTE 01 FREAD BYTE 02 FWRITE BYTE 03 FRWIND BYTE 04 FLOAD BYTE 05 FSAVE BYTE 06 FDELET BYTE 07 * EXAMPLE MOVB @FOPEN,@POPCOD This kind of thing helps my old brain remember what is going where. Yup. I've got this understood already too. I'm just trying to figure out my pab before I send it to vram. I have COUNT that contains the length of the file name. And I have FLNM that contains the actual file name with the DSK#. In front. Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 (edited) If I set byte nine of the PAB to hex 30 wouldn't that cover any size of my file name that I come across under or equal to 48 bytes as in if the actual file name was really 10 bytes long can't my Pab still function correctly with the > 30 number in byte nine? Edited November 3, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 3, 2020 Share Posted November 3, 2020 (edited) 9 minutes ago, GDMike said: If I set byte nine of the PAB to hex 30 wouldn't that cover any size of my file name that I come across under or equal to 48 bytes as in if the actual file name was really 10 bytes long can't my Pab still function correctly with the > 30 number in byte nine? NO, NO, NO. DSRLNK must have the correct file length at the time you call it. You cannot anticipate it except to reserve the space. That number is not a reservation. It is information you are handing off to DSRLNK about the file you hope to open/create, or whatever operation you intend. ...lee Edited November 3, 2020 by Lee Stewart 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 (edited) Ahahhaa! Exactly. Okay now we're getting somewhere. So I might as well set PAB byte 9 to 10 And use DSK1.file1 for FLNM in a TEXT like. TEXT 'DSK1.FILE1 And now, the question becomes how do I plug in the new file name and the new file length prior to calling DSR link? When FLNM contains "DSK5.FRUIT.APPLES" And COUNT contains 17? Edited November 3, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 3, 2020 Share Posted November 3, 2020 2 minutes ago, GDMike said: Ahahhaa! Exactly. Okay now we're getting somewhere. So I might as well set PAB byte 9 to 10 And use DSK1.file1 for FLNM in a TEXT like. TEXT 'DSK1.FILE1 And now, the question becomes how do I plug in the new file name and the new file length prior to calling DSR link? When FLNM contains "DSK5.FRUIT.APPLES" And COUNT contains 17? LI R0,VDPPAB+9 LI R1,COUNT BLWP @VSBW LI R0,VDPPAB+10 LI R1,FLNM CLR R2 MOVB @COUNT,R2 SWPB R2 count byte to LSB BLWP @VMBW ...lee 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 3, 2020 Share Posted November 3, 2020 Gotta run. I will check in later. ...lee 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 Thank you! This is what I was missing for some reason. Thank you for spending the time ? and bearing with me. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 1 hour ago, TheBF said: * PAB DATA STRUCTURE MIRROR IN CPU RAM I wrote my code already that pushes my pages to >1000 vram, then I found out later that I can only put as much as I need in a record, meaning my 1028 bytes I put in it, I can't use. So I'll rewrite that portion tommorow, putting only 128 bytes before moving in another 128 for the next record. Well, that's part of learning. I do have an understanding of that. Shhooooo. Thanks for the help. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 3, 2020 Author Share Posted November 3, 2020 45 minutes ago, GDMike said: I wrote my code already that pushes my pages to >1000 vram, then I found out later that I can only put as much as I need in a record, meaning my 1028 bytes I put in it, I can't use. So I'll rewrite that portion tommorow, putting only 128 bytes before moving in another 128 for the next record. Well, that's part of learning. I do have an understanding of that. Shhooooo. Thanks for the help. Yes the file system is record based, not memory block based (Well... except for programs using the LOAD/SAVE commands . They can do 8K blocks at a time but that's not typically for data) So if you use DV80 files you can only read 80 bytes max at a time. You literally read the file one line at a time for DV80 files. Each time you do a read command a new line appears in the VDP buffer and the number of chars read appear in what I called the PCHARS field as a byte. For fixed files you read 1 fixed size record at a time. So your VDP buffer does not need to be bigger than 128 bytes. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 3, 2020 Share Posted November 3, 2020 Well I should have working code tommorow then. I'll be back on my SNP posting. Thx ❣️ all Quote Link to comment Share on other sites More sharing options...
apersson850 Posted November 3, 2020 Share Posted November 3, 2020 8 hours ago, GDMike said: Yup. I've got this understood already too. I'm just trying to figure out my pab before I send it to vram. I have COUNT that contains the length of the file name. And I have FLNM that contains the actual file name with the DSK#. In front. No, you have not understood. Look in your code. Your COUNT (which, to add to the confusion, you somtimes call COUNTP) is outside the PAB. First you had this definition PAB Data statements Count Filename Then you went to this definition PAB Data statements Filename Count Both of these are wrong. The COUNT is a part of the PAB data, not something hanging after it. I showed you how to define the PAB several posts ago, and now TheBF has done it again, to get it right. In his definition, FNAML is equivalent to what you call COUNT/COUNTP. 1 Quote Link to comment Share on other sites More sharing options...
