Atari 800 display issues
bernie
I just bought an atari 800 of craigslist in "unknown" condition.
I purchased a monitor->composite cable (that my friend tested) and plugged it in to my Vizio 65" LED tv. Unfortunately I get a "no signal" (and no sound).
The 800 powers on (red light) and if I remove the cartridge (I tested with two) I hear clicks when I press the keyboard, so something must be working...
Any ideas of next steps to troubleshoot? I just ordered an RF adapter so that I can plug into antenna switch.
Unfortunately this is the only machine I have that uses Composite input.
Thanks!
B.
Edited by bernie
Thanks!
B.
Let's see. You have the ROM card in front slot, at least one RAM card in behind the ROM. You have
the cartridge door shut. Your cartridge is in the left slot. ? there is no RF port, where you gonna
get a RF output? You ordered a RF adapter. Does that provide RF from the 5 pin monitor port?
Or maybe PAL 800 has RF. I'm in NTSC land. No, sorry, the RF comes out the center of the
back via a RF cable. Your RF adapter goes on the TV.
Edited by russg
Yes. I have 48k of ram and the the ROM in the back (which I removed and reseated), a cartridge in the left slot (tried several), and the cartridge door closed (so the power light comes on).
I have 5 pin monitor port to composite (RCA) lead and get no signal on the TV.
If I remove the cartridge, and reset, If I press any of the keyboard keys I hear click (I assume I'm in Memo).
I tried plugging in the audio part of the cable into a stereo and I hear some chirping when the atari is powered on and off.
I am waiting for adapter to allow me to plug into antenna in (c2/3) on my TV.
I
I
The 10K ROM has to be in the front slot. The cartridge has to be in the left slot. The
cart door has to be shut.
Edited by russg
I'm sure you have tested the power supply brick. The plug should be about 10.6 volts AC with no load on it.
It supplies 5 v dc, inside the computer I think. That's with a NTSC power brick.
I haven't. I tested with 2 power supplies but I can test with my friend's multimeter tonight. Where should I test inside the computer?
Do you have the 5-pin DIN to 4 RCA plug version of the cable? Have you tried connecting each of the 4 RCA plugs to composite video in on your TV just to make sure it isn't wired differently than expected?
No, I have the three RCA version (with two audios joined)
In summary, here is where I am now:
The 800 powers on (red light) and if I remove the cartridge (I tested with two) I hear clicks when I press the keyboard (in memo?), so something must be working...
The monitor->composite cable gets a "no signal" (and no sound comes out if I hook to stereo) I tried plugging in the audio part of the cable into a stereo and I hear some chirping when the atari is powered on and off.
Through RF (via RCA->Antenna adapter I got today) I get no signal on my TV
I unplugged/reseated Ram/combination of RAM in the back
I have tried several cartridges in the left slot with the cartridge door closed (so the power light comes on).
I tried several different power adapters
I tried a basic take apart, and there is no visible damage/spillage internally
What I plan to do:
1. Test power adapters with multimeter
2. Test internal voltages
Questions:
1. How do I unplug the keyboard
2. Where should I test internal voltage
3. Since I'm getting the power light, and when I press the keyboard with no cartridges I get sounds to indicate keypresses; something must be working. How can I isolate if it's the PSU board, or the main board, or the personality board?
4. Anything else I should try?
One thing you can try, is press ctrl+2. It should generate a very annoying buzz from the speaker rather than just the normal keyclick. It seems like the overall machine is working, given the fact that you are generating keyclicks.
I can almost guarantee you have the wrong video cable... There are several computers that use that same cable (Commodore VIC, C64, TI994/A, Sega Genesis, Atari, and even generic MIDI) and wiring is different on most all of them.
Edited by R.Cade
Thanks for the tip ctrl+2 does generate a very annoying buzz.
It may be. I'd be confident of that if I was able to get a signal from the RF though...
Your adapter for RF is RCA to F connector? And the long black cord from the 800 connects to that and you tuned the TV to channel 3? Make sure tv is not auto scanning and you manually picked standard and not hd signals.
Correct. I had 2/3 pre-programed from when I had cable plugged in directly and nothing. I switched to antanna mode and unfortunately even when trying to add channels 2/3 manually my TV does not find a signal to add them. I will try on my friend's TV tonight.
Edited by bernie
So progress... I bought an old 20" CRT TV to test (authentic experience lol?) and I basically see a cycling image of the memo pad:
IMG_1873.jpg?dl=0
https://www.dropbox.com/s/d3ewi62uyw2nz6r/IMG_1871.jpg?dl=0
Via Monitor out cable
IMG_1871.jpg?dl=0
https://www.dropbox.com/s/6ovqwyzovkri7u7/IMG_1873.jpg?dl=0
Via RF
Any ideas how to fix?
[sorry I couldn't get the images to work]
Edited by bernie
