pohlmacs Posted March 31, 2017 Share Posted March 31, 2017 (edited) I have two copies of Bounty Bob Strikes Back and it seems that pressing right, up, or down on the standard console-stored controller is not working. I have tested other games and the controls seem to work just fine. If I start the game, I can only go left. If I go into the settings * menu, I can only press left and no right up or down either. However, after I plugged in the WICO Command Control and Joystick, I was able to control the game properly. Anyone else having this issue and/or has any known workaround/solution? It is a really bummer to now have every single Atari 5200 game and have it not work properly like all of the other games. -Craig Edited March 31, 2017 by pohlmacs Quote Link to comment Share on other sites More sharing options...
stringfellow Posted March 31, 2017 Share Posted March 31, 2017 the problem is that you have two copies and they get mad because they each want to be the only copy you have. You can fix this by sending me one. 2 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted March 31, 2017 Share Posted March 31, 2017 This is a known issue with Bountry Bob. out of all my 5200 stock controllers, I think I only have 2 that will work semi decent with Bounty Bob. The Wico's as you noted seem to work much better, but I honestly do prefer the control of the stock sticks over the Wico 'plug'... Basically the adjustment for the deadzone on BB is so strict that most 5200 sticks aren't able to be calibrated to within the needed values. I've also noticed that in testing, not all 5200 sticks will read the same values from their extremes as others. The earlier ones I recall had larger starting values on the pots in the controllers vs newer ones. And BB didn't seem to want to work with any of the older controllers with higher value readings. That the Necromancer conversion are the only two games that seem to be really strict on the calibration for the stock controllers to work. 1 Quote Link to comment Share on other sites More sharing options...
Atari Nut Posted April 1, 2017 Share Posted April 1, 2017 I had the same issue. I got mine to work by making a slight adjustment. See here... Quote Link to comment Share on other sites More sharing options...
vintagegamecrazy Posted April 1, 2017 Share Posted April 1, 2017 Atari Nut. That will calibrate Missile Command to make it work right but it does nothing to fix the control issues with Bounty Bob Strikes Back. I am tried this endlessly with multiple controllers and calibration the Wico controllers work but the competition Pro digital controllers won't. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted April 1, 2017 Share Posted April 1, 2017 Atari Nut. That will calibrate Missile Command to make it work right but it does nothing to fix the control issues with Bounty Bob Strikes Back. I am tried this endlessly with multiple controllers and calibration the Wico controllers work but the competition Pro digital controllers won't. Exactly! Basically for me to get BB working with a stock 5200 controller required a perfectly calibrated console with a lot of trial and error getting just the right calibration on the stock controllers. Because of this, I've now started to use BB as the perfect test game for the standard cardinal directions testing with stock 5200 controllers since that game is so finicky. Quote Link to comment Share on other sites More sharing options...
Atari Nut Posted April 2, 2017 Share Posted April 2, 2017 Atari Nut. That will calibrate Missile Command to make it work right but it does nothing to fix the control issues with Bounty Bob Strikes Back. I am tried this endlessly with multiple controllers and calibration the Wico controllers work but the competition Pro digital controllers won't. Interesting. It worked for me with Bounty Bob. Quote Link to comment Share on other sites More sharing options...
reklen Posted April 2, 2017 Share Posted April 2, 2017 I've never had trouble with Bounty Bob, but I have a hell of a time going diagonal on Popeye with any 5200 controller. Quote Link to comment Share on other sites More sharing options...
