HDX reload question
aftyde
Hi All,
Was tinkering with my HDX RS-232 card and seem to have blown away the DSR. The machine won't start with the interrupt jumper on - so my question is, what would be the correct process to reload the DSR. Do I need to tinker with this jumper? The only com program I have that works is Zterm80 - and it seems to require the interrupt jumper be on. So what is exactly the process... don't want to fry my one connection to the non-TI world... :)
Cheers, Arthur...
Hi All,
Cheers, Arthur...
If I recall you need to remove the jumper to load the DSR. The Jumper is only needed when you are using a terminal program that requires interrupts.
Check your battery to go ahead and makes sure it's still good too.
Edited by Shift838
