ClassicGMR Posted April 11, 2017 Share Posted April 11, 2017 Can someone tell me why this is happening? I have brand new gold plated AV cables. Lots of them. I have tried multiple cables from these sets on my Intellivision. My Intellivision, however, still sends interference to the TV. Nothing major but it's noticeable. I found a cable from an Atari 2600 I tore down last year... and it takes all the interference out of the signal. I'm no electronics wizard but I really don't get this. Thanks. Quote Link to comment Share on other sites More sharing options...
mr_me Posted April 11, 2017 Share Posted April 11, 2017 Intellivision outputs an rf signal. An av cable is not the same as an rf cable. Try an rg6 cable. 1 Quote Link to comment Share on other sites More sharing options...
ClassicGMR Posted April 11, 2017 Author Share Posted April 11, 2017 So I should buy something like this for the system? I never realized the cable builds were different. I just saw an RCA to RCA connector. Thanks you. Quote Link to comment Share on other sites More sharing options...
mr_me Posted April 11, 2017 Share Posted April 11, 2017 Actually RCA on one end and F-type connector on the other to the TV. Either way you'd need one adapter. I mentioned rg6 because its a common TV cable; thought you might already have one. I really dont know the specifics of the cable; I just know the signals are very different. Quote Link to comment Share on other sites More sharing options...
+H454 Posted April 15, 2017 Share Posted April 15, 2017 So I should buy something like this for the system? I never realized the cable builds were different. I just saw an RCA to RCA connector. Thanks you. Yes, or any shielded cable for sub woofers or digital "coax" are 75ohm. If your at a thrift store, any single rca cable that's at least 3/8 Dia., should be fine. (like monster cables). Something like this: http://www.ebay.com/itm/252470282461?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649 Would work great, the older rca connector style works better with more jacks. Meaning the the one you linked is to thick to fit in some recessed rca jacks on some consoles, plus they fit REALLY tight (you can almost twist a jack out of the back of a unit). If your replacing a cable that connects to a jack inside (like an atari 2600), you need to trim the tip or change the jack to a taller one - like: https://www.digikey.com/product-detail/en/keystone-electronics/577/36-577-ND/316411 Ether way, getting a good RF cable will make your life much easier. But, you might also find you have a jack going bad too! +1 on the rca to f type(coax) adapter - the old switch boxes are more trouble than there worth. Quote Link to comment Share on other sites More sharing options...
