+S.D.W. Posted April 14, 2017 Share Posted April 14, 2017 I spoke with Heather (SkydivinGir) through Amibay and she said she would consider doing another run of the Vic-20 Final Expansion cartridge if enough people were interested. She said she has 5 people on a waiting list but needs 15 total to make it financially doable... Here is a link to the last offering... http://www.amibay.com/showthread.php?87848-Pre-Orders-Final-Expansion-3-Rev-11&highlight=final+expansion Some info... • Built-In Menu System.• A Built-in SD2IEC drive capable of running the latest SD2IEC firmware.• SD2IEC EEPROM File System (Beta). Allows you to store some files in the SD2IEC without using an SD card. See SD2IEC documentation for usage.• Diskloader to access files on the SD2IEC from the menu system.• Battery Backed Real Time Clock (RTC) for accurate Time/Date stamps on SD2IEC.• 512KB configurable memory expansion.• 512KB Programmable ROM. Flash your programs to ROM directly from your VIC-20.• FE3 DOS Wedge with SJLoad (JiffyDOS Compatible Load/Save).• Dual Reset Buttons – Resets current running configuration or back to menu.Final Expansion WIKI: http://sleepingelephant.com/denial/w...inal_ExpansionFinal Expansion Manual: http://koti.kapsi.fi/~jvaltane/vic20...r%20Manual.pdfThe Final Expansion 3 Rev 11 has the following changes:• Dual IEC Headers allow you to use standard IEC cables as well as connect other IEC devices to your VIC-20 at the same time.• IEC cables can still be soldered directly to the PCB in place of the IEC headers if you prefer. Strain relief holes are provided on the PCB to allow for this type of assembly.• Component changes to allow for easier sourcing of parts and assembly of the kit.• Tactile switches allow for easier case mounting and removal of the case when replacing the Battery.• Downloadable 3D case designed by COREi64. (See Below)• One of three labels to match the case mounting option of your choice: Standard VIC-20 case without IEC Headers (cable directly wired), Standard VIC-20 case with IEC headers (top case cut to accommodate IEC Headers), or COREi64 designed case.• EEPROM pre-programmed with games by Jeffrey Daniels of the VIC-20 DENIAL Website. Cheers 917k Quote Link to comment Share on other sites More sharing options...
eightbit Posted April 17, 2017 Share Posted April 17, 2017 I would be down for one of these! Quote Link to comment Share on other sites More sharing options...
RobertB Posted April 18, 2017 Share Posted April 18, 2017 The one I bought from her works perfectly! Truly, Robert Bernardo June 10-11 Pacific Commodore Expo NW - http://www.portcommodore.com/pacommex July 29-30 Commodore Vegas Expo v13 - http://www.portcommodore.com/commvex Quote Link to comment Share on other sites More sharing options...
motrucker Posted April 20, 2017 Share Posted April 20, 2017 Anything you get from this lady will be first class! Quote Link to comment Share on other sites More sharing options...
+S.D.W. Posted May 4, 2017 Author Share Posted May 4, 2017 If you are interested, click the link I left in the first post and let her know. Quote Link to comment Share on other sites More sharing options...
Spawn222 Posted February 28, 2020 Share Posted February 28, 2020 Are these still being made would like one Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted February 29, 2020 Share Posted February 29, 2020 I have a penunlimate coming don't need it. Quote Link to comment Share on other sites More sharing options...
towmater Posted July 27, 2022 Share Posted July 27, 2022 I'm late to the party... Everything seems to work in my FE3, but not the SD2IEC functions. I thought perhaps I needed firmware on the SD card, but SkyDiverGirl's github has about twenty different firmwares for the SD card function (including, for example, "PetSD" firmware FSR.) So, I'm wondering which is the "right" firmware to put on the SD, if I haven't already fubar'ed it by feeding it the wrong firmware. So ultimately pressing F3 on the Final Expansion menu does nothing, but everything else seems OK. Quote Link to comment Share on other sites More sharing options...
