+MrFish Posted May 1, 2017 Share Posted May 1, 2017 The emulators sound all "typically POKEY" but there are differences in the base clocking in NTSC and PAL. To get rid of many problems, some tricks can be used, like that "Filter correction" to control the cancelling effect. There exist timing problems in all emulations, that don't exist on the real thing. The most stable one is the "asap" plug in for Winamp. Then there are smaller problems with the volume, as POKEY tends to sound a lot louder with high tones. And the distortion is missing in most emulations. Altirra has the "non-linear" channel mixing. Which is also "over". Have you brought any of these supposed issues with Altirra to the attention of phaeron? This emulator is being very actively developed. 1 Quote Link to comment Share on other sites More sharing options...
marok Posted May 1, 2017 Share Posted May 1, 2017 (edited) I downloaded ASAP, and it sounds great and has a LOT of plugins for various stuff. Doesn't seem to want to force 60Hz, though. the .RMT files all seem to be 50hz PAL natively, no matter how you compose the track... hmm Right. So, as far I know, only transforming to sap format allows to switch music onto NTSC play mode. Wilys_Castle_POKEY01_sap.zip Edited May 1, 2017 by marok 1 Quote Link to comment Share on other sites More sharing options...
Fragmare Posted May 3, 2017 Author Share Posted May 3, 2017 Decided to see JUST how close I could get the POKEY to sound to the NES version of this and came up with this... should sound quite a bit more accurate now. The timbre is obviously not going to be the same, and the bassline as an octave low, but I almost think it sounds better an octave lower. Also, the notey toms are now present at the end of the tune and the note cancelling and/or distortion has been drastically reduced. As always, XEX attached https://youtu.be/3BfSrzrG4qI Wilys_Castle_POKEY01c.xex 5 Quote Link to comment Share on other sites More sharing options...
emkay Posted May 5, 2017 Share Posted May 5, 2017 Interesting, that Youtube claims a copyright infringement with my edit. Well, it also shows the range of the tune, where the infringement happens. Then it play the whole tune. What does that mean? Quote Link to comment Share on other sites More sharing options...
