ndary Posted May 2, 2017 Share Posted May 2, 2017 Hi, is there a way to re create a floppy from an STX file? i got some original games with bad floppies and i would like to try and recover them thanks... Nir Quote Link to comment Share on other sites More sharing options...
tjlazer Posted May 3, 2017 Share Posted May 3, 2017 Sadly no. It's only for use on Emulators. Quote Link to comment Share on other sites More sharing options...
zzip Posted May 3, 2017 Share Posted May 3, 2017 Hi, is there a way to re create a floppy from an STX file? i got some original games with bad floppies and i would like to try and recover them thanks... Nir looks like it's not a straightforward format to convert. I would check to see if you can find the game online as an .msa or raw .st format. Quote Link to comment Share on other sites More sharing options...
oracle_jedi Posted May 3, 2017 Share Posted May 3, 2017 I have some STX images loaded on my HxC2001 attached to a real ST. They work fine except for the drive always being B: If you found a suitable track copier program, would that not work to make a real floppy from it? The STX format is listed as supported but experimental for HxC. 1 Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted May 3, 2017 Share Posted May 3, 2017 I have some STX images loaded on my HxC2001 attached to a real ST. They work fine except for the drive always being B: If you found a suitable track copier program, would that not work to make a real floppy from it? The STX format is listed as supported but experimental for HxC. STX on HxC is not for writing floppies, only to read from images. Quote Link to comment Share on other sites More sharing options...
ijor Posted May 11, 2017 Share Posted May 11, 2017 STX on HxC is not for writing floppies, only to read from images. True, but as long as they work with the HxC, then you can convert it to a raw format and write it back with suitable hardware (Kryoflux, SCP). And for the rare case with simple protections, you could even use a software copier like Procopy. My (very long) TODO list includes to implement a more complete and reliable solution. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted May 11, 2017 Share Posted May 11, 2017 (edited) True, but as long as they work with the HxC, then you can convert it to a raw format and write it back with suitable hardware (Kryoflux, SCP). And for the rare case with simple protections, you could even use a software copier like Procopy. My (very long) TODO list includes to implement a more complete and reliable solution. What if you use the HxC as drive "B" (source drive) with a Discovery cart and the ST's real Internal floppy drive "A" (destination drive) I think you can write it back to a real floppy, am I right? Edited May 11, 2017 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
+rdemming Posted May 11, 2017 Share Posted May 11, 2017 I have some STX images loaded on my HxC2001 attached to a real ST. They work fine except for the drive always being B: There are in quite lots of disks that only work from drive A:. But this can be solved by adding a switch to your ST that swaps the internal en external drives making the external drive A:. Robert 1 Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted May 11, 2017 Share Posted May 11, 2017 (edited) There are in quite lots of disks that only work from drive A:. But this can be solved by adding a switch to your ST that swaps the internal en external drives making the external drive A:. Robert WOW, that's is very useful mod talk about moving the work load to your external drive. Edited May 11, 2017 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
ijor Posted May 11, 2017 Share Posted May 11, 2017 What if you use the HxC as drive "B" (source drive) with a Discovery cart and the ST's real Internal floppy drive "A" (destination drive) I think you can write it back to a real floppy, am I right? Yep. Never tried, but In theory that should work. And even if the HxC is the only floppy drive, you can still create Discovery Cart images files, either on a hard disk or on ramdisk. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted May 11, 2017 Share Posted May 11, 2017 True, but as long as they work with the HxC, then you can convert it to a raw format and write it back with suitable hardware (Kryoflux, SCP). And for the rare case with simple protections, you could even use a software copier like Procopy. My (very long) TODO list includes to implement a more complete and reliable solution. I don't think that it will work with some bigger %-age of titles. I could write here that I have SW what converts STX to ST and like, but that's not the point. Point is that writing from STX is still basically unsupported. I would not force it at all. Who wants to copy originals let go with Kryo or SCP. It is year 2017. People getting rid of floppies. Not saying that we need totally stop work on it, but doing write support to STX is just too big task. Quote Link to comment Share on other sites More sharing options...
KLund1 Posted May 25, 2017 Share Posted May 25, 2017 I have loaded and STX files into STEEM then copied that to a STEEM HD. Then in the main PC you can see the PRG, INF, etc files. Those can then be copied to floppy with the Win to ST copy program that can be found in here somewhere. (I do not recall it's name) This method takes some time to do, but if you really need to move files it is an option. I have a Falcon with an SD card as the 2nd IDE drive. With HDDriver, I have a FAT 32 partition on the SD, and can easily move files from PC to ST/Falcon then to FD if needed. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted May 26, 2017 Share Posted May 26, 2017 I have loaded and STX files into STEEM then copied that to a STEEM HD. Then in the main PC you can see the PRG, INF, etc files. Those can then be copied to floppy with the Win to ST copy program that can be found in here somewhere. (I do not recall it's name) This method takes some time to do, but if you really need to move files it is an option. I have a Falcon with an SD card as the 2nd IDE drive. With HDDriver, I have a FAT 32 partition on the SD, and can easily move files from PC to ST/Falcon then to FD if needed. That is OK only for not copy protected stuff, and that's minority. I have much faster way for transferring STX to ST - I wrote myself Windows program for that, and does it instantly. But I don't use it for later usage of such ST image files, but for extracting files from them, doing deprotected versions, or if there are no regular files, I can use image of floppy. Of course, there are some STX files where it works not at all - those with track loads for instance. Here I must add that whole idea of "recovering original bad floppies" is very bad. If it is damaged. why you expect that writing on it will result in good readable floppy ? Instead that write on some floppy in good shape. And that is what will be soon not so easy to find. Quote Link to comment Share on other sites More sharing options...
