Ripdubski Posted June 9, 2017 Share Posted June 9, 2017 I bought a GBS8200 upscaler to connect my STE to an LCD display. When it didn't work as planned, I started researching and found that STE's lack a clock signal on pin 2 of the monitor port. I'm trying to determine how to get that signal presented, and level of difficulty. Any help or advice would be appreciated. Thanks Wade Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted June 10, 2017 Share Posted June 10, 2017 There is no clock on any of old analog composite or RGB monitor outputs. You have nothing to do in STE, and you can not. It seems that you just bought not good upscaler for STE. Why it works not well ? Probably because STE produces not proper interlaced video. In any case, it is worth to try how it works when STE is set to 60 Hz refresh rate - if it is not already in it (US TOS) . Quote Link to comment Share on other sites More sharing options...
vattari Posted June 12, 2017 Share Posted June 12, 2017 Instead of Pin 2 (I assume you're using this for a composite sync on the GBS8220's 5 pin connector), try the 6 pin connector that takes the H and V signals Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
