DirtyHairy Posted June 11, 2017 Share Posted June 11, 2017 As I am going to use it for another project (http://atariage.com/forums/topic/266415-2600-homebrew-for-showcasing-on-our-website/), I am planning on adding an interface for embedding 6502.ts in other webpages. Before going ahead and deciding on an API, I wanted to ask if anybody else is interested in this and, if yes, whether you have any particular suggestions how the interface should look like and what options it should provide The basic setup I have in mind is a Javascript library that you load on your webpage and that gives you access to the emulator as a library. You have to include a canvas element on your page; then you start the emulator with a cartridge image and a bit of configuration, and you're set. However, the details are still variable. Is anybody else interested in using this? 2 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted June 11, 2017 Share Posted June 11, 2017 I've a few pages on my site, like Homebrews Online, that use JStella; though it hasn't worked in a while (probably due to browser changes and /or security settings). When it worked it was pretty slick - all the buttons on Artie the Atari were functional. When it was powered off you could change the game, at which point the game the instructions below Artie would also be changed. It'd be nice to get that working again 1 Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted June 12, 2017 Author Share Posted June 12, 2017 I've a few pages on my site, like Homebrews Online, that use JStella; though it hasn't worked in a while (probably due to browser changes and /or security settings). When it worked it was pretty slick - all the buttons on Artie the Atari were functional. When it was powered off you could change the game, at which point the game the instructions below Artie would also be changed. It'd be nice to get that working again I just took a look; I think hooking up 6502.ts should be no issue (with the only catch that the keybindings are different and cannot be configured atm ). I'll post here once I come up with a first version of the embedding API, then we can see whether this works for you (or make any necessary changes). Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted January 8, 2018 Author Share Posted January 8, 2018 (edited) It has been a while, but I finally have a embedded version of Stellerator running The full documentation (including API docs) is available here, but I'll add a few remarks here anyway: Check out the example page and its source to get started. The emulator instance is exposed as windows.stellerator, so you can open the developer tools and play with it. There are two scripts that you have to download and host alongside your web page. One needs to be loaded via a script tag, the other (the web worker) is loaded by the emulator at runtime. You can grab the scripts from the Github releases page. If you have a javascript application with a dedicated build process, you can also grab the module from NPM and include it in your build. Note that you still have to host the web worker script. The emulator runs fine in recent versions of Chrome, Firefox and Safari. Edge works but currently has severe performance issues. If you try this out and encounter any issues or have suggestions on how to improve the documentation, please comment in this thread or open an issue on GitHub. Edited January 8, 2018 by DirtyHairy 3 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted January 10, 2018 Share Posted January 10, 2018 Great, I'll see about updating my site to use it. Have you solved the issue with joystick controls in iOS yet? Last time I tried it (Sunday the 7th) they were still inverted. 1 Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted January 11, 2018 Author Share Posted January 11, 2018 (edited) Great, I'll see about updating my site to use it. Have you solved the issue with joystick controls in iOS yet? Last time I tried it (Sunday the 7th) they were still inverted. Great, drop me a note if you encounter any issues. I have not yet done anything on the gamepad issue. However, I have thought that I could include a set of nonstandard mappings for known combinations of controller / OS. I'll drop you a note when I get to adding this, I'll need some information about the gamepad's ID and the data the browser identifies itself with I also want to grab one of our company test devices these days and check out the audio issues on iOS. Edited January 11, 2018 by DirtyHairy Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted January 11, 2018 Author Share Posted January 11, 2018 (edited) Just a short followup on iOS audio: I found some time to snatch a test device and fiddle with it before leaving work today. I still need some testing and polishing, but I have a workaround and will publish an update this weekend. However, it will still require a touch anywhere on the page before playing audio, that's what is enforced by Apple. I tested an iPhone 6s must say that I was very impressed by how smooth they emu runs --- the interface remains silky smooth, and I didn't get a single audio dropout. No way to compare this to android where the interface jerks and I couldn't get more then one second of sustained full speed I'll also add fullscreen by tapping to Stellerator and fix interface on mobile, and will be looking at touch controls soon. Edited January 11, 2018 by DirtyHairy 1 Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted January 13, 2018 Author Share Posted January 13, 2018 (edited) I just published 0.9.8. It includes the promised iOS audio fix: audio starts once you tap anywhere on the display (this is unavoidable and enforced by Apple). In addition, I have made changes to the Stellerator UI to display properly on phone-sized devices. However, I have excluded click-for-fullscreen for the time being as I had to find out that iOS does not support the HTML5 fullscreen API . I have hacked around this by displaying the canvas element above everything else, but the browser toolbar will still interfere. This is a known problem on iOS, and there is not much that can be done about it. I think it will still work sort-of fine once I have touch support (at the expense of manually scrolling the display to remove the toolbar), but there is not much point before that. I'll also add support for adding Stellerator as a home screen application, which will also get rid of the toolbar if it is launched that way . Speaking of touch, I think I have finally come up with an input scheme that might be practical for actual gaming (that's what has been keeping me from working on this so far). I have started the implementation, but it may still take some to to be ready for prime time. Edited January 13, 2018 by DirtyHairy 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted May 31, 2019 Share Posted May 31, 2019 It has been a while, but I finally have a embedded version of Stellerator running The full documentation (including API docs) is available here, but I'll add a few remarks here anyway: Ran across this tweet with javatari running in a model 3 https://twitter.com/ManuelPazosMSX/status/1131824395582877698 So decided to try your demo Appears to be running, but I couldn't figure out how to get it to play. Will look into it more this weekend. 1 Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 31, 2019 Share Posted May 31, 2019 Flap the doors to play. Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted May 31, 2019 Author Share Posted May 31, 2019 (edited) Appears to be running, but I couldn't figure out how to get it to play. Will look into it more this weekend. Pretty cool Now if they only exposed an API to query the steering wheel in JS --- would lend itself nicely to pole position. Out of curiosity: do you hear audio? If Tesla supports the JS touch API in their browser (which I guess is based on webkit), you should be able to use the touch controls to play. Edited May 31, 2019 by DirtyHairy Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted May 31, 2019 Share Posted May 31, 2019 I tried copying the source and put it on a new page atari_draconian.html. Despite the page name, that should load up FlapPing. I FTPed the files to my site as: htdocs/atari_draconian.html htdocs/js/compiled/stellerator_embedded.min.js htdocs/js/compiled/stellerator_embedded.min.js.map htdocs/js/compiled/worker/stellerator_worker.min.js htdocs/js/compiled/worker/stellerator_worker.min.js.map I get this warning: and these errors: Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted May 31, 2019 Author Share Posted May 31, 2019 (edited) Your web page works for me, I see FlapPing running happily. Maybe a caching issue? You can ignore the webaudio warning, it is a harmless Safari issue. You can ignore any errors about the .map files, too, those are for debugging only (they are similar to debug symbols). Edited May 31, 2019 by DirtyHairy 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted June 1, 2019 Share Posted June 1, 2019 That was it. Exceedingly slow for Draconian, even sluggish for Stay Frosty. No gamepad support, and no audio. I'm uploading a video of it in action to my site, will post a link when it's done. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted June 1, 2019 Share Posted June 1, 2019 The upload of the 4K video kept aborting, had to shrink it to 1080p. http://www.spiceware.org/movies/IMG_1610.m4v 1 Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted June 1, 2019 Author Share Posted June 1, 2019 (edited) A pity about the performance, but still pretty cool.... Now Tesla should add at note not to play VCS games while on autopilot Edited June 1, 2019 by DirtyHairy Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted June 2, 2019 Share Posted June 2, 2019 I bought Full Self Driving, which means Talith will get an upgraded computer at some point. I'll try again after that occurs. Quote Link to comment Share on other sites More sharing options...
