+DavidMil Posted June 14, 2017 Share Posted June 14, 2017 I just read an old article written by, Tom Halfhill, about Atari 1200XL's that says Atari put a current limiting resistor (R53) in the SIO port to discourage anyone from designing devices that drew 5 Volt power from the computer itself. Has anyone ever had a problem with this.? He specifically points to to the XM301 modem as not working till this modification is made. The article goes on to explain how to get around this by replacing the resistor with a wire jumper. He also said that Atari recommends that you take computer to a distributer to have this done. Anyone have any more info about this? Thanks, DavidMil Quote Link to comment Share on other sites More sharing options...
Rybags Posted June 14, 2017 Share Posted June 14, 2017 The solution is to replace or bridge R63 with a piece of wire which will let the SIO device draw more power. http://atariage.com/forums/topic/221719-sio2sd-and-atari-1200xl-having-problems/?do=findComment&comment=3136311 1 Quote Link to comment Share on other sites More sharing options...
+DavidMil Posted June 14, 2017 Author Share Posted June 14, 2017 The solution is to replace or bridge R63 with a piece of wire which will let the SIO device draw more power. http://atariage.com/forums/topic/221719-sio2sd-and-atari-1200xl-having-problems/?do=findComment&comment=3136311 So the article I read is incorrect! And the correct resistor to bypass is R63 (right beside R53) and not R53 as the article states. Thanks for the correct info, DavidMil Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted June 14, 2017 Share Posted June 14, 2017 I replaced the existing resistor with a 1 ohm jumper rather than just a wire. Looks neater. 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted June 14, 2017 Share Posted June 14, 2017 The operative thing would be to test before doing anything - simply check continuity between the resistor and the +5V / Ready SIO pin. Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted June 14, 2017 Share Posted June 14, 2017 This is correct. You can do the same to improve the video, but I forget which ones to do.. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted June 14, 2017 Share Posted June 14, 2017 This is correct. You can do the same to improve the video, but I forget which ones to do.. Here's the ClearPic mod. I've done it on one of my 1200XL's, but one of Bryan's little UAV boards is an easier install and works even better. http://retrobits.net/atari/clearpic.shtml Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted June 14, 2017 Share Posted June 14, 2017 Ahhh... thanks Dr.Venkman. I restored 10 1200xl's two years ago. I just did the first three to improve the video. NEW 1200XL KEYBOARD MYLARS ARE NOW AT BEST ELECTRONICS ! Quote Link to comment Share on other sites More sharing options...
ACML Posted June 15, 2017 Share Posted June 15, 2017 (edited) Here's the ClearPic mod. I've done it on one of my 1200XL's, but one of Bryan's little UAV boards is an easier install and works even better. I have modified more than a few 1200XLs with the ClearPic 2002 mod and have found it to be very good. I have never tried Bryan's mod. Any chance you could post photos of the two with same image for comparison. I have another 1200XL mobo to mod and I'd like to see if this is something I should try. Thanks Edited June 15, 2017 by ACML Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted June 15, 2017 Share Posted June 15, 2017 I have modified more than a few 1200XLs with the ClearPic 2002 mod and have found it to be very good. I have never tried Bryan's mod. Any chance you could post photos of the two with same image for comparison. I have another 1200XL mobo to mod and I'd like to see if this is something I should try. Thanks Sadly, no. I have only two 1200XLs - one that had the ClearPic mod that now has one the UAV board in it, and a second totally-stock board that doesn't work properly; I'm still trying to figure that one out. Photos of my results with the UAV, however, are posted here. Quote Link to comment Share on other sites More sharing options...
1050 Posted June 16, 2017 Share Posted June 16, 2017 I had a 1200XL that would not boot up a disk drive until I soldered a wire around that resistor. After that it worked fine. The problem is real. This is from Atari_1200_XL_Home_Computer_Field_Service_ Manual_Rev01.pdf, page 3. http://www.atarimania.com/documents/Atari_1200_XL_Home_Computer_Field_Service_Manual_Rev01.pdf R63 at 100 ohms will be brown, black, brown. The non- players will be violet, yellow, red, 4k7 as they say it in Europe. At any rate the PIA is U23 and note the horrible handwriting for U23 - that three matches exactly the three in R63. It looked like 65 to me first time thru there but that one is actually unreadable. Have no clue why they said 53. This exact area is in error across ALL other Atari XL/XE schematics, L10 which takes the place of this resistor is not in fact taking the place of this resistor. L10 instead feeds +5 to MMU, cartridge and the center portion of the mother board where the 800XL and 600XL have a lot of TTL logic chips. On other XL/XE, +5 buss is actually fed directly to READY line despite how it is depicted on schematics. L10 is not used for READY line at all. 1 Quote Link to comment Share on other sites More sharing options...
