courtesi96 Posted June 25, 2017 Share Posted June 25, 2017 I'm trying to remove a single .BIN program from a .DSK disk image however I can't find any utilities that will work properly. Can anyone lend a hand? At the end of the day I want to take said image and disassemble it on the PC. Quote Link to comment Share on other sites More sharing options...
+sm3 Posted June 25, 2017 Share Posted June 25, 2017 I'm trying to remove a single .BIN program from a .DSK disk image however I can't find any utilities that will work properly. Can anyone lend a hand? At the end of the day I want to take said image and disassemble it on the PC. If you mean for a non Color Computer TRS-80, Matthew Reed's TRStools will do the trick: http://www.trs-80emulators.com/trstools/ It will allow you to examine the contents of disk images, add/remove files etc.. It will even fix the date issue on an LDOS/LS-DOS disk image. Quote Link to comment Share on other sites More sharing options...
courtesi96 Posted June 25, 2017 Author Share Posted June 25, 2017 Sorry, I should have been more specific. This is for the TRS-80 Color Computer. Quote Link to comment Share on other sites More sharing options...
+sm3 Posted June 25, 2017 Share Posted June 25, 2017 Sorry, I should have been more specific. This is for the TRS-80 Color Computer. OK sorry! I don't have much experience with the Color Computer yet. TRStools can also do an instant disassembly of a CMD file too, which is pretty cool. Maybe there is something equal to it out there. It does show there is (read only) support for Color Computer: RSDOS (read-only) (Color Computer) But that may not be of use to you. Quote Link to comment Share on other sites More sharing options...
linville Posted June 25, 2017 Share Posted June 25, 2017 The Toolshed decb command is functional. The syntax is a little weird, but it works. https://sourceforge.net/p/toolshed/wiki/Home/ What else have you tried? 1 Quote Link to comment Share on other sites More sharing options...
courtesi96 Posted June 25, 2017 Author Share Posted June 25, 2017 (edited) I tried CoCoDisk-0.7 and after installing the requisite fdraw it still didn't work. Also, I tried wimgtool but was told it couldn't recognize the DSK format. I don't know if Windows 10 is the culprit but that's what I'm using. Thanks for the link. I think it's working great now! I think I may need to build a Linux box as most of these open source projects are written for that. Edited June 25, 2017 by courtesi96 1 Quote Link to comment Share on other sites More sharing options...
