+darryl1970 Posted October 22, 2019 Author Share Posted October 22, 2019 On 8/20/2019 at 10:27 AM, Shannon said: You know. When I first tried these a couple years back I was like... Meh.. but then recently I was trying to track down the "Donkey Kong Arcade" with enhanced sounds ( RMT ) mentioned in another thread and decided to give this another go. I'd have to say I'm quite pleased. I do have one question. I grabbed an "Donkey Kong Arcade" executable from another thread (kjmann thread?) and I also grabbed the one from here named "DK_A8_RMT.xex" and I'm trying to figure out which one would be considered the most recent version. Does anyone know? The ROMs on page 1 should be the most recent. Quote Link to comment Share on other sites More sharing options...
+JAC! Posted December 9, 2019 Share Posted December 9, 2019 On 7/3/2017 at 3:10 AM, darryl1970 said: Atari 8-bit Computer RMT version (Updated sound) -- DK_A8_RMT.xex Hi Darryl, thanks for the RMT version. I found a small incompatibility in the hack. It assumes BOOT?($09)=$01 which is not guaranteed if the program is loaded from devices other than a DOS boot disk. If possible, you should not use the memory locations $8/9/a/b/c/d at all as they have predefined meanings and usage in the OS and esp. the RESET process. Bst regards, Peter. Quote Link to comment Share on other sites More sharing options...
playsoft Posted December 10, 2019 Share Posted December 10, 2019 16 hours ago, JAC! said: Hi Darryl, thanks for the RMT version. I found a small incompatibility in the hack. It assumes BOOT?($09)=$01 which is not guaranteed if the program is loaded from devices other than a DOS boot disk. If possible, you should not use the memory locations $8/9/a/b/c/d at all as they have predefined meanings and usage in the OS and esp. the RESET process. Bst regards, Peter. It's in the original RMT version by Fandal and Kjmann and seemed to cause a problem with some xex loaders (e.g. Ultimate Cart) but not others (e.g. Atarimax). I was not sure what it was trying to achieve by using BOOT. From what I remember there were at least a couple of instances of it so the simplest fix seemed to be to set BOOT to 1 by adding it to the XEX just before the run: On 11/16/2018 at 8:55 PM, playsoft said: Same hack applied (so that it runs from the Ultimate Cart correctly). DK_A8_RMT_$09.xex 26.87 kB · 243 downloads Quote Link to comment Share on other sites More sharing options...
+darryl1970 Posted December 10, 2019 Author Share Posted December 10, 2019 (edited) 19 hours ago, JAC! said: Hi Darryl, thanks for the RMT version. I found a small incompatibility in the hack. It assumes BOOT?($09)=$01 which is not guaranteed if the program is loaded from devices other than a DOS boot disk. If possible, you should not use the memory locations $8/9/a/b/c/d at all as they have predefined meanings and usage in the OS and esp. the RESET process. Bst regards, Peter. Thanks for the info. 3 hours ago, playsoft said: It's in the original RMT version by Fandal and Kjmann and seemed to cause a problem with some xex loaders (e.g. Ultimate Cart) but not others (e.g. Atarimax). I was not sure what it was trying to achieve by using BOOT. From what I remember there were at least a couple of instances of it so the simplest fix seemed to be to set BOOT to 1 by adding it to the XEX just before the run: Thanks! So, should I add this to the thread as an Ultimate Cart version? Edited December 10, 2019 by darryl1970 Quote Link to comment Share on other sites More sharing options...
playsoft Posted December 10, 2019 Share Posted December 10, 2019 1 hour ago, darryl1970 said: Thanks for the info. Thanks! So, should I add this to the thread as an Ultimate Cart version? Yes, replace the original RMT version with the updated one as you don't need them both. Quote Link to comment Share on other sites More sharing options...
+JAC! Posted December 10, 2019 Share Posted December 10, 2019 So known problem with existing fix. Perfect. I remember older versions of RMT and other tools like G2F frequently had problems of this kind (using reserved addresses). Also it is a difference between 5200 and 800/XL. If you are aware of that, everything is fine. Quote Link to comment Share on other sites More sharing options...
Atari the Jedi Posted February 1, 2020 Share Posted February 1, 2020 This is totally amazing I absolutely love the Popeye. I wanted to see if I can get permission to have Atari age make a cartridge just for me. Popeye is the original game that I got for the system back in the day I still on that same system in that same cartridge and it would love to have an updated version. Thank you Quote Link to comment Share on other sites More sharing options...
ZippyRedPlumber Posted May 17, 2020 Share Posted May 17, 2020 What tools did you use to make these hacks? Quote Link to comment Share on other sites More sharing options...
+darryl1970 Posted July 16, 2020 Author Share Posted July 16, 2020 These have all been updated HERE Quote Link to comment Share on other sites More sharing options...
