Problem with Atari800Win 3.1
TXG/MNX
I did found out I could remap the ctrl+shift+w under the ` key and this works but I still don't know why other ctrl+shift functions are accepted like ctrl+shif+M also works...
seems the emulator blocks certain key sequences... or it's a windows issue...
Atari800MacX supports the Action cartridge just fine. There's only one problem......you'll have to buy a Macintosh, instead of your Windows machine (but that has othter advantages :-D.....).
In all seriousness (I'll stop my Winblows bashing for a minute :) ), you might try the WIN32 compile of the Atari800 emulator from http://atari800.sourceforge.net. It's the emulator that Atari800WinPlus is based on, (as well as mine), but Atari800WinPlus hasn't been updated in a little while. One thing that won't work properly with that emulator (or Atari800WinPlus), is state saves. I have a version that works on the Mac emulator, but I need to get time to feed it to the Atari800 team so they can incorporate it.
Mark
Yes, it is still under development. There haven't been any changes in the last 2 months, but the mailing list is still active.
It's what I base my emulator and also Atari800WinPlus is developed off of. In fact this emulator, has some features that WinPlus doesn't, such as cycle exact timing. (The last I saw, someone on comp.sys.atari.8bit said that it might be quite a while before WinPlus gets updated again....I don't know the author ,so can't say.
You might try the full source download for the emulator, as there are some files in the Doc directory that might help. There isn't a comprehensive manual that I know of.
To answer your R/W question, you use the space key to toggle between read only and R/W.
Mark
Archived
This topic is now archived and is closed to further replies.
