scotty Posted August 3, 2017 Share Posted August 3, 2017 Quick question.... How do you switch between JiffyDos and stock kernel under Vice? Real hardware is a switch, but how do you do it under Vice? Quote Link to comment Share on other sites More sharing options...
+sm3 Posted August 4, 2017 Share Posted August 4, 2017 Quick question.... How do you switch between JiffyDos and stock kernel under Vice? Real hardware is a switch, but how do you do it under Vice? While I don't use JiffyDos myself from within WinVICE, I do believe you can change the drive and kernal ROMs within VICE by hitting the F12 key, and making some selections. I'm basing this off the SDL version of WinVICE which I use with Windows 10. When you press F12, you get a text window that appears and allows you to make changes. Of course JiffyDos isn't included, so you'll have to obtain the ROMs elsewhere. Quote Link to comment Share on other sites More sharing options...
motrucker Posted August 4, 2017 Share Posted August 4, 2017 Just a quick note - not all Jiffy DOS ROMS need, or use a switch. A switchless version exists, so you don't have to drill a hole in your 8 bit's case. http://www.ebay.com/itm/Commodore-C64C-short-board-switchless-JIFFYDOS-with-clips-NO-DRILLING-/161761760176?hash=item25a9c093b0:g:~hkAAOSw5cNYSc7Q Quote Link to comment Share on other sites More sharing options...
