vattari Posted August 15, 2017 Share Posted August 15, 2017 I've recently tried for the first time my 1200XL which I had in storage for the past 18 months. I plugged it in and the composite video is so-so and the chroma appears to be missing. I set out to do the ClearPic 2002 modification but it appears some work has been done (note the skewer pointing to the R63 position with a wire in place). In locating the parts needing replacing, I'm unable to guage what work has been done previously. Can anyone make it out? Thanks Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted August 15, 2017 Share Posted August 15, 2017 That mod restores power to the SIO plug so that SIO-powered peripherals will work. Very common mod on the 1200XL. I did it myself to both of mine. 1 Quote Link to comment Share on other sites More sharing options...
vattari Posted August 15, 2017 Author Share Posted August 15, 2017 (edited) I thought this was the case after trying my SIO2SD device and it worked first time (I expected it would need this). Any thoughts if a video mod was done? Sent from my iPhone using Tapatalk Edited August 15, 2017 by vattari Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted August 15, 2017 Share Posted August 15, 2017 Doesn’t look like it at first blush but hard to see close details on my phone. That said, the ClearPic mod is excellent but one of Bryan’s UAV mod boards gives you the best Composite and s-Video you can get out of these machines. You’ll have to add Chroma to the unused pin on the DIN of course. None of the NTSC XL’s has it connected for some stupid reason. 1 Quote Link to comment Share on other sites More sharing options...
Gunstar Posted August 15, 2017 Share Posted August 15, 2017 If you do a video mod yourself, for the 1200XL only, I recommend the Supervideo 2.1 mod-1200XL version. The 1200XL is the only 8-bit to have a unique chroma-boost circuit. which, of course, was screwed up in the end by Atari. But the SV 2.1 mod is the only video mod that incorporates a fixed version of this special chroma circuit into it, and the result is the deepest, sharpest color on any Atari 8-bit, through S-video (chroma/luma). It approaches RGB color quality, very close. Of course I have no experience with the UAV device and how it handles color, maybe it makes it as good or better across all 8-bits, but for my 3 1200XL's, it's SV 2.1 1200XL version and nothing else. http://ftp.pigwa.net/stuff/collections/nir_dary_cds/Hardware%20Projects/Super%20Video%202.1XL/supervid5.html Quote Link to comment Share on other sites More sharing options...
