Tornadoboy Posted August 17, 2017 Share Posted August 17, 2017 (edited) I'm building a franken-TI in a reused case from a internet firewall and I'm trying to incorporate everything I need inside it, it's going to have the Finalgrom, F18, 32k, USB keyboard adapter (if I can get the PCB), speech synth and hopefully a Raspberry Pi once the adapter is released. It seems to me there was a way to do this with the disk controller so can someone point me in the right direction? It would also be handy too to know how to make it pass-through so other devices could be put after it. Edited August 17, 2017 by Tornadoboy 2 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted August 17, 2017 Share Posted August 17, 2017 hmmm, very hard to say anything without seeing a full fotostory of that :-D Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted August 17, 2017 Share Posted August 17, 2017 (edited) I'm building a franken-TI in a reused case from a internet firewall and I'm trying to incorporate everything I need inside it, it's going to have the Finalgrom, F18, 32k, USB keyboard adapter (if I can get the PCB), speech synth and hopefully a Raspberry Pi once the adapter is released. It seems to me there was a way to do this with the disk controller so can someone point me in the right direction? It would also be handy too to know how to make it pass-through so other devices could be put after it. I don't know much of anything about how the PEB works itself. I imagine you'd need some butchered backplane or need to make one single slot. With a side expansion port extension cable you could probably for it inside the unit you are making and also utilize a side port splitter for the passthrough. That's assuming that a plain old adaptor from the side port expansion to the sams card edge connector is all that is needed (the butchered backplane or custom board mentioned earlier). Although I think the flex cable card is needed also (preSAMS connection). So maybe a 2 slot custom or butchered backplane. I think Fabrice designed a new TI with all things internal, he maybe able to answer this definitively. http://atariage.com/forums/topic/266585-tiny-994a-computer/ Edited August 17, 2017 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
Tornadoboy Posted August 17, 2017 Author Share Posted August 17, 2017 Found this about how to connect a disk controller without the PEB, it's under "resurrecting the TI disk system" http://www.stuartconner.me.uk/ti/ti.htm I wonder if I can use that setup for the SAMS? Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted August 19, 2017 Share Posted August 19, 2017 Found this about how to connect a disk controller without the PEB, it's under "resurrecting the TI disk system" http://www.stuartconner.me.uk/ti/ti.htm I wonder if I can use that setup for the SAMS? I don't see a reason why you couldn't. All you would need is a ribbon cable and appropriate connectors on both ends per Stuart's description along with a few pull-up resistors. I would be very interested in hearing about your results if you do decide to give it a shot. Quote Link to comment Share on other sites More sharing options...
Tornadoboy Posted August 19, 2017 Author Share Posted August 19, 2017 It's going to be pretty crammed in there so I'm going to have to get creative in how I place and wire things, it should be an interesting project. 1 Quote Link to comment Share on other sites More sharing options...
