John Stamos Mullet Posted January 8, 2021 Share Posted January 8, 2021 7 minutes ago, Greg2600 said: Yeesh, wasn't it a few years ago that he bailed on people here, causing quite a stir? Yes. He's done that a few times, I think. 1 Quote Link to comment Share on other sites More sharing options...
adamchevy Posted January 8, 2021 Share Posted January 8, 2021 Yes. He's done that a few times, I think.It’s good to know it’s a regular occurrence. Thanks! Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted January 11, 2022 Share Posted January 11, 2022 (edited) Maybe as an inspiration for others, here my take on the composite mod. As you can see, I don't like to butcher the case or shield and use one of these to get my video/audio out. Works great! Edited January 11, 2022 by Irgendwer 1 Quote Link to comment Share on other sites More sharing options...
juansolo Posted January 13, 2022 Share Posted January 13, 2022 (edited) If you're handy with veroboard and don't mind tackling a more intensive mod (ie, this isn't for novices), here's ours. It's mainly for PAL machines, but there's one for the NTSC ones also toward the end of the doc (page 8 onwards). AntiJackModDocV3-4.pdf On the AIO mods you can get composite by simply combining the Luma+Sync and Chroma S-Video outs. Though if you have the ability to use S, it's much more preferable. Edited January 13, 2022 by juansolo Quote Link to comment Share on other sites More sharing options...
desiv Posted January 18, 2022 Share Posted January 18, 2022 (edited) OK, finally finished up the mod I did ages ago... What did I need to finish? Well, I didn't have a 3D printer back then, so the 3 RCA jacks (Yeah, I went for 3 and mirrored left/right audio; it's been good for me for years) were just help in place with a piece of plastic I had cut and drilled some holes into... But a while ago after I got my 3D Printer, I found this: https://www.thingiverse.com/thing:4235463 It is for 2 RCA jacks and says no cut, but I had already cut (sorry.. it was a long time ago), so I just modded it a bit for 3 RCA jacks and finally got around to printing and installing it.... Went easier than I had thought. The two holes at the back, that matched up to the two holes that used to hold the RF case in place, instead of using two screws, I used a thick piece of wire, ran it thru the holes and soldered it in. Held great. One plus (other than looking much nicer than my cheapo cut plastic) is that there is a screw in the case where my middle RCA jack is, and with my original mod, the RCA jacks stuck out pretty far and that screw was barely accessible... The new mod had the RCA jacks recessed, so access to that case screw is perfect. 7800 RCA jacks by Desi Villaescusa, on Flickr Edited January 18, 2022 by desiv Quote Link to comment Share on other sites More sharing options...
juansolo Posted January 19, 2022 Share Posted January 19, 2022 (edited) On 1/13/2022 at 5:14 PM, juansolo said: If you're handy with veroboard and don't mind tackling a more intensive mod (ie, this isn't for novices), here's ours. It's mainly for PAL machines, but there's one for the NTSC ones also toward the end of the doc (page 8 onwards). On the AIO mods you can get composite by simply combining the Luma+Sync and Chroma S-Video outs. Though if you have the ability to use S, it's much more preferable. Error in that doc (fairly major one...) now fixed. AntiJackModDocV3-5.pdf Edited January 19, 2022 by juansolo 2 Quote Link to comment Share on other sites More sharing options...
