Swami Posted September 3, 2017 Share Posted September 3, 2017 On my 1010 program recorder, the FF/play caster only spins about a quarter turn and stops, so I figure it is the belts. I open it up and the belt that is the problem goes under the structures inside, so I start unscrewing the screws. Three of the five come out easy and the last two will not budge, no matter what. I sprayed some detoxit on them and left them sit for 30 min. Still won't budge. They put some red glue on screw heads during manufacture, so I don't know if that is causing it or they were just tightened to much. They are only screwed into plastic, so this is surprising. How do I get these gosh darn screws out to change the FF/play belt? Thanks. 1 Quote Link to comment Share on other sites More sharing options...
baktra Posted September 3, 2017 Share Posted September 3, 2017 (edited) Well, once the bottom cover is removed, you need only one screw to unscrew and one to loosen. I would recommend referring to the field service manual, page 3-10, section REPLACING THE 1010C DRIVE BELT. ... I wish a field service manual for XC-12 was available too... Edited September 3, 2017 by baktra Quote Link to comment Share on other sites More sharing options...
Swami Posted September 3, 2017 Author Share Posted September 3, 2017 Thank you. Instruction manuals are always helpful! The shield that needs to be removed was apparently already removed by the previous owner, perhaps. I was trying to also replace the counter belt, which seemed even more loose, since the belts came as a pair. But I replaced just the drive belt and the FF/play/rewind and counter all seem to work properly, so I guess I'll just leave it be and hope the counter belt continues to hold up. This is what it looked like when I opened it: 2 Quote Link to comment Share on other sites More sharing options...
Swami Posted September 3, 2017 Author Share Posted September 3, 2017 Well, once the bottom cover is removed, you need only one screw to unscrew and one to loosen. I would recommend referring to the field service manual, page 3-10, section REPLACING THE 1010C DRIVE BELT. ... I wish a field service manual for XC-12 was available too... Replaced just the drive belt and seems mechanically okay. Tried to load pre-recorded "Space Invaders" and after turning on with Start pressed down, pressing play and return the monitor beeps a few time after a few seconds and I get BOOT ERROR, several times in a row. It boots and plays fine on my brand new XC12 using same procedure. I suppose need to try cleaning heads and then realign heads. Quote Link to comment Share on other sites More sharing options...
