bradhig1 Posted September 7, 2017 Share Posted September 7, 2017 Downloaded the cd image for smoke and mirrors but fusion says it needs europre cd bios and when I load it with eur cd bios it just goes to the cd player screen. Do I need something else to play it. Quote Link to comment Share on other sites More sharing options...
Lordmonkus Posted September 8, 2017 Share Posted September 8, 2017 It's been a while since I have used Fusion but I believe you need to have the correct bios and tell it where you have them on your hard drive in the Options > Set Config window Sega CD tab. From there you will ideally want your disk images in cue + bin format and load the cue file. Like I said though it has been a while since I have used Fusion because I have since moved to Retroarch using the Genesis GX core. Quote Link to comment Share on other sites More sharing options...
