Stormtrooper of Death Posted September 20, 2017 Share Posted September 20, 2017 (edited) I posted this question also on facebook, but still didnt get lots of answers. So i post it in this group aswell: Question 1: I have a TRS-80 model 4P with 2 Singlesided DD 5.25 drives. I am able to exchange software , using an old Pentium 2 that has a 3.5 inch drive and a 5.25 inch HD drive. Standard LDos and TRSDos floppies are copied oke, but I am not able to copy other floppies. I use "David Keil Model 3 en 4 emulator" on the MS-DOS Pentium 2. Tried CopyCat 4.1 several times. The progam writes to real 5.25 floppy, but when i insert the floppy in the model 4P, nothing works. Any hints / tips of what program to use for easy exchange of software/data between MS-DOS and TRS-80 ? Question 2: About using newer DD/HD drives in my Model 4P. I have bought 2 old 5.25 inch 1.2MB HD floppy drives. One is a Mitsumi / Newtronics D509 , the other is a Ye Data YD-380C. I read on the internet that the D509 has the jumpers to switch from DriveREady to DiskChange and jumpers to set the driveID (DS0, DS1, DS2, DS3). Can I use a plain cable with all 34 pins intact to connect one of these 2 HD drives (or can I use the standard drive cable that is already in the model 4P) ? The YD-380C also has 2 rows of jumpers that can be changed, but i dont have any info about the meaning of those. Can I use a plain cable with all 34 pins intact to connect one of these 2 HD drives (or can I use the standard drive cable that is already in the model 4P) ? My ideal setup in my 4P would be drive 1 to be the original TRS-80 drive (Single Sided/ Double Density) and drive 0 to become on of the above mentioned HD Double sided / Double Density drives. Greetings from Richard Vermeulen (from the Netherlands) Edited September 20, 2017 by Stormtrooper of Death Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted September 27, 2017 Share Posted September 27, 2017 If the drive you are writing with is an 80-track drive (which an HD floppy always is), it will only write half of a 40-track track. If the disk was bulk-erased at the start, that might be enough, but without the bulk-erase, you get the data from two adjacent tracks interfering with each other. If you're just trying to get it going quick, try a big tape bulk-eraser on a disk before writing it, and make sure that you have a "double-step" option enabled when writing. Note that a "new" disk out of a box will likely already be formatted, unless it's really old. Also, do not use HD media to write in double-density, the magnetic properties of the disk are wrong for that. You really need a 360K drive to write disks, unless you also have an 80-track drive on the TRS-80. The disk controller chip will also need to be able to write 256-byte sectors. I understand that many PC disk controllers can't do single-density, but you shouldn't need that on a Model 4P. Floppy drives in a TRS-80 usually had a drive-select jumper in the drive, and a straight-through cable. On the Model I, I recall that the pin it used for DS3 was "officially" the Side Select pin, making it easy to add double-sided drives, as long as you only used three of them. As I recall, the most annoying thing about putting a "modern" drive in is that the screw hole locations were different from PC-era drives, making it a pain to fit two drives into a Model III/IV full-height hole. But I really wouldn't recommend an HD drive on a TRS-80, since the drive controller doesn't know about the HD signals, particularly the density select. If you do use one, you will probably need a jumper to force it to double density. 1 Quote Link to comment Share on other sites More sharing options...
Stormtrooper of Death Posted September 29, 2017 Author Share Posted September 29, 2017 I bought 2 Panasonic JU-455-5 5.25 floppy drives last week for my 4P. These JU-455 are 360K double sided drives. I had some problems trying to connect them, but now all is working nice. I am now using the original single sided floppy drive as :0 and the new 360K drive as :1 lots of fun using the old model 4P. Since i had it repaired, i use it almost every day. 1 Quote Link to comment Share on other sites More sharing options...
