mtshark7 Posted September 27, 2017 Share Posted September 27, 2017 I got a TurboGrafx 16 off of my friend but it doesn't have a power supply. I picked up this one but I'm not 100% sure if it will work and or harm the console. Any insight would be great thanks! -Mark Sent from my SM-G955U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Punisher5.0 Posted September 27, 2017 Share Posted September 27, 2017 I wouldn't use it. It's low on voltage and current. I don't know about polarity either. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted September 27, 2017 Share Posted September 27, 2017 voltage is fine its just going to a 5 volt regulator anyway, but yea current is low for whats listed on the console and you do have to make sure the + and - are in the right spots Quote Link to comment Share on other sites More sharing options...
metarog Posted September 27, 2017 Share Posted September 27, 2017 Hey Mark... I used my Sega Master System power supply on my TG-16 for several months with no issues. I've heard you can use a Model 1 Genesis PS also but I only personally know the SMS one works. 1 Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted September 27, 2017 Share Posted September 27, 2017 Yeah, the Genesis Model 1 (or Sega CD) or Master System PS all work fine (US anyway). 1 Quote Link to comment Share on other sites More sharing options...
carlsson Posted September 27, 2017 Share Posted September 27, 2017 Yup, since this one is listed to be compatible with the Genesis, the polarity should be correct. However I agree with the above that the current seems a little on the low side if the TurboGrafx-16 is specified to draw 7.66W and this one delivers 6.12W at most. Then again I seem to remember at least the European Mega Drive 1 has a power supply rated at 10V 850 mA = 8.5W. I don't know what the original US Genesis console or PSU is rated for, so perhaps the numbers are exaggerated. 1 Quote Link to comment Share on other sites More sharing options...
Osgeld Posted September 27, 2017 Share Posted September 27, 2017 they typically are Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted September 27, 2017 Share Posted September 27, 2017 Well in the case of the original Genesis/Megadrive, they have 2 7805 1amp output voltage regulators in them. So the power supplies were usually at least 1amp and I want to say 1.2amp on the earliest ones with 10v output. But to mimic what others have said, a model 1 Genesis or SMS power supply can be used on the TG-16 without issue. That is how I always operated my TG-16 when I picked it up console only in the early 2000's. Quote Link to comment Share on other sites More sharing options...
CatPix Posted September 27, 2017 Share Posted September 27, 2017 Given how different the power supplies are, I guess they took what was avalaible at the time. I always though that it was one reason why the European NES and SNES used AC to AC power supply, it probably make certifications for each country easier to pass than a DC one; and probably allowed to account for different power grids (UK = 240 volts : most of Europe : 220 volts - some remote places in Belgium, France and Italy still used 110 volts up to 1990, so wonky cheap 110volts to 220 volts power supplies used.) I also remember seeing Atari 2600 power supplies ranging between 400mA and 800mA - most likely, by the end of the 80's, 400Ma power supplies were getting rarer and so, more expensive, prompting Atari to use a more common, cheaper power supply. Quote Link to comment Share on other sites More sharing options...
mtshark7 Posted September 29, 2017 Author Share Posted September 29, 2017 Thanks everyone for the feedback! I've decided not to use that power supply due to the amps being less than the console requires. Below I took a pic of the Genesis model 1 power supply for reference. I've also researched this tidbit of information about finding a replacement power supply for your game consoles. (See pic) I ended up buying this 3rd party genesis model 1 power supply and hopefully it will be similar to the actual one. I'll update everyone on here once the power supply arrives :-) Sent from my SM-G955U using Tapatalk Quote Link to comment Share on other sites More sharing options...
zylon Posted September 30, 2017 Share Posted September 30, 2017 Gen1, SMS, and Jaguar power supplies will all work just fine on TG16 1 Quote Link to comment Share on other sites More sharing options...
mtshark7 Posted October 2, 2017 Author Share Posted October 2, 2017 So the Genesis Model 1 3rd party power supply came in and it works. The system fires up and there is video but no audio...I've been looking online and they say the rf module can go bad. I guess I'm going to have to wait for my Video booster to come in the mail for AV output. So should I stick with this power supply? Sent from my SM-G955U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Osgeld Posted October 2, 2017 Share Posted October 2, 2017 yea its probably fine 1 Quote Link to comment Share on other sites More sharing options...
