mxpxpxpx Posted September 28, 2017 Share Posted September 28, 2017 Hello I recently had my Game Gear modded with a new LCD screen from McWill and also VGA out. I have also seen where people have added 2 controller ports for either Genesis or Master System comtrollers. I was wondering if any one out there does this kind of mod? I'd like to get it done if at all possible. Thanks Quote Link to comment Share on other sites More sharing options...
7800fan Posted September 29, 2017 Share Posted September 29, 2017 Player 1 port is probably directly wired to the controller pads. Genesis controller can work as well. Player 2 goes through the link port. One can wire inside rather than to cut up a link cable to make into controller adapter. Quote Link to comment Share on other sites More sharing options...
+pixelpedant Posted October 7, 2017 Share Posted October 7, 2017 Indeed. It's not necessary to wire up the EXT port internally, since it functions as a Controller 2 port with a simple, cheap external adapter. But indeed, you could do that if you want. And the Controller 1 port is usually created by wiring a DB-9 connector to the relevant test points on the PCB. Since an SMS controller has no Start button and a Genesis controller multiplexes its inputs, a controller hack is also required, if the Start button is to be available. Full details on how I went about adding a controller port and modding the controller are available here. Quote Link to comment Share on other sites More sharing options...
