Ramses Posted September 28, 2017 Share Posted September 28, 2017 (edited) Well, I finally picked up an Intellivision this week and it's working okay aside from the screen shaking up and down after a while. It's sort of a jittery vibrating shake - the movement range is about a half inch to an inch. It initially started doing it after a minute of play and after I removed the tv switch box and connected the system directly to the RF input, it only starts shaking after about 10 minutes of play. I then tried swapping cables and connector adapters but it didn't improve any further. This is on a CRT by the way. If I turn off the system and immediately turn it back on, it still shakes. I have to wait a few minutes before I turn it back on again for it to go away. Also not sure if it's related but in some games, there is a lot of screen noise whenever there is a loud audio noise in a game (for example when you enter a mountain in AD&D). Any ideas? I'm guessing maybe a defective capacitor or power supply? Edited September 28, 2017 by Ramses Quote Link to comment Share on other sites More sharing options...
mr_me Posted September 28, 2017 Share Posted September 28, 2017 Are you using a shielded RF cable? Sounds like the problem happens once the system gets warm. Does tapping the Intellivision do anything to the picture; warm or cold? Quote Link to comment Share on other sites More sharing options...
Ramses Posted September 28, 2017 Author Share Posted September 28, 2017 Tapping it warm or cold doesn't seem to do anything. I'm using an unshielded composite cable with an adapter. I have one RF cable that's shielded but it's pretty old, banged up and working worse than the composite cable. I guess I'll picking up a new one and try that. Quote Link to comment Share on other sites More sharing options...
