NanoPEB is not always recognized.
Pepper
Another option is to reseat the cardreader on the board, or to change it (I once got them for less than 10eu on eBay)
Ok, thanks. I found one on eBay for $6. Hopefully that'll fix the issue. I did notice that it does not read the CF when the TI is powered up. It used to. Is this a common issue for the NanoPEB?
For me, it is a common issue. I "repaired" some by changing the cardreader...
You might be onto something ;) .. I found a sticker on the underside of the CF reader saying "Bad"... Got to love eBay used purchases!
Also, I have an extra wire soldered onto the main board. I don't see it in other pictures of the NanoPEB. It looks to be passing a Ground connection from ^7 on the 74HC000 to the console connector. Should it be there ?
Edited by Pepper
I was having this same exact issue on one of the Nanos I had. The solution for it was to remove the PLCC's, clean and reseat them.
I used 1000 grit sandpaper to remove any oxidation that could have formed. Once that was done I was amazed to find that it was in perfect operating condition. In the end I still got rid of it, because to me Nanos are the most nerve wracking things I've ever owned.
Anyone suggested cleaning the side port contacts yet? Something like cotton swabs and isopropyl alcohol, or maybe a small abrasive rubber if there is room.
I'll give that a go tonight.
@--- Ω --- , The PLCC's are soldered directly onto the board. So reseating is not an option.
I'm also going to try another power supply.... just in case.
We'll get there !
Hmm, good to hear. Not only does it reduce cost for him, it eliminates another problem area. I wonder how long he's been doing it that way. I wish you luck.
Yep, but not so easy to replace components ;)
I agree with you on the nerve wracking part of the nanoPEB. But as the real PEB costs seem insane these days.... I guess I'll deal with it.. If I ever get it working. I really only want it for the memory expansion and rs232 so I can use it to access my BBS and others.
Sent from my Pixel XL using Tapatalk
I took my 12v regulated Bench power supply and dropped the voltage down to 5V with a DC-DC Buck converter. Still the same symptom. So that rules out the PSU as that's been 3 different sources.
Cleaned the sidecar board contacts with some fine sandpaper. No joy.
It's not going to beat me ... well hopefully not ..lol.
  • 2 weeks later...
Have you tried another power socket in the house (e.g. preferable a different circuit). I had 2x nano-PEBs which normally worked without a problem,
then I did not use them for 6-8 months (in a hot / humid environment) and could not get them to work, but I connected it to a power strip extender
(and not sure if that supplied enough power supply or current to all devices connected to it). I moved to another location, still the same problem,
but I kept trying and I got one to work again (also swapping the CF-card), the SAN-Disk CF-card works the best, the Kingston CF-card did not work.
Maybe the CF-card is the problem? Check on the PC (or do a complete reformat and put all files back with TI-99-Dir)
(I still need to troubleshoot the other one if I can get it back again, I ran everything on 600mA and now have a cable for 2A and phone-USB 5V adapter)
Yeah, I tried all of the above. New CF card, reformatted and loaded the vol1 back onto it, etc.
I ended up returning it to the person I bought it from. I suppose, It's not beyond the realm of possibilities that it's my TI that's the issue. Not the NanoPEB.
As I only have one working TI99/4A, I did not have anything to test against. When I get my spare unit working then maybe I'll purchase another NanoPEB. Until then I have plenty of other projects to keep me busy.
I had similar issues and it turned out to be the PS. I think it's very sensitive to regulation.
On a side note, I see that you have the PiDP-8 kit :) I built one myself and I have it running Seti@home 24/7 :grin:
On a side note, I see that you have the PiDP-8 kit :) I build one myself and I have it running Seti@home 24/7 :grin:
Yes, I have the PiDP8/i running a Mystic Telnet BBS. I also have the "blinkin lights" going ;)
I occasionally play Adventure on it also.
I'm looking forward to building his PDP11 clone when that comes out.
