Arkanoid_376970 Posted November 22, 2017 Share Posted November 22, 2017 Hey, Grabbed a new belt for my XC12 from MagicKnight and installed it today. After re-assembling the drive will Rewind, but will not Fast Forward or Play. I've disassembled the mechanism again and can't see anything preventing the mechanism from driving forward but it still won't. Any tips guys? Quote Link to comment Share on other sites More sharing options...
NISMOPC Posted November 22, 2017 Share Posted November 22, 2017 Play only works during a CLOAD or a START-OPTION boot. Can't give any advice why FWD is not working... Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 22, 2017 Share Posted November 22, 2017 (edited) over tightened something or mis-routed belt, bent a contact or switch.. disturbed a wire or connection Edited November 22, 2017 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
Marius Posted November 22, 2017 Share Posted November 22, 2017 Perhaps a dumb question from my side... but did the XC12 do all those things before changing the belt? Quote Link to comment Share on other sites More sharing options...
erichenneke Posted November 22, 2017 Share Posted November 22, 2017 (edited) is it doing anything at all when you FF or CLOAD ( like is it trying to turn but just not moving) ? I had a 410 where I changed the belts and it would always need to "warm up" a bit before it really would start getting traction and adequately turning everything enough to load...and that was after belts replaced. and what i mean by warm up is either fast forward and rewind a lot, and/or play/CLOAD for a while. Like the belt itself needs to warm up a bit first. Edited November 22, 2017 by erichenneke Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 22, 2017 Share Posted November 22, 2017 always clean the belt paths and grooves when changing belts.... if not you will sometimes be left with a slipping or burned belts... Quote Link to comment Share on other sites More sharing options...
Arkanoid_376970 Posted November 22, 2017 Author Share Posted November 22, 2017 I think there could be an issue with the direction switch, I tried a CLOAD and after a couple of tries, it worked. This was extremely intermittent however and i can not reliably replicate it. The Rewind function works flawlessly but the play and Fast Forward are being weird. Will pull it apart again Quote Link to comment Share on other sites More sharing options...
Arkanoid_376970 Posted November 30, 2017 Author Share Posted November 30, 2017 UPDATE: I am now able to get the drive to Fast Forward reliably. The Fast Forward leaf switch wasn't making reliable contact, bent it a little and now it works 100% of the time. I am still not able to get my drive to Play, however. Does the drive require a signal over SIO to start playing? If so could this mean a bad connection to the relevant pin on the Atari 600XL or broken SIO cable? From what I can tell by looking at the drive, the Drive actuates a common leaf switch for Play, Fast Forward and Rewind. For Fast Forward and Rewind, this switch is ANDed to determine motor direction. I'm guessing for Play, this switch is ANDed with the command from the computer. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 30, 2017 Share Posted November 30, 2017 (edited) so the post from a while back about bent contact/switches looks to have useful yes it requires sio to command it to play... you can cload from basic then press return or hold start down while powering up then pres return key or you can.... Machine language programs booting from tape: Hold START+OPTION during cold start of the computer (powering up) then press enter key BASIC language programs booting from tape: Hold START during cold start of the computer (powering up) then press enter key in Atari BASIC programs saved with CSAVE command: load using the CLOAD command. in Atari BASIC programs saved with SAVE"C:" command: loaded using LOAD"C:" or RUN"C:" commands in Atari BASIC programs saved with LIST"C:" command: loaded using ENTER"C:" command. or in BASIC again POKE 54018,52 and the motor should turn on and play audio etc. Edited November 30, 2017 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
Arkanoid_376970 Posted December 2, 2017 Author Share Posted December 2, 2017 Awesome, thanks! Managed to get it working, but now have to align the head azimuth, the computer keeps going into the 'self test' after trying to load for 10 seconds. I can hear the data streaming in but the volume varies heavily and seems a bit noisy. Quote Link to comment Share on other sites More sharing options...
