RSS Bot Posted November 22, 2017 Share Posted November 22, 2017 I figure posting on here is better than clogging up the forums. I'm learning a lot by constructing my own kernel. I suppose the first thing to mention is that if you are drawing an asymmetric playfield, you MUST consciously draw the playfield every line. You are forced to update it every line, otherwise the right half will be displayed on the left by the time the beam comes around on the next line. You can have a 2-line resolution, as in a playfield that has its graphics changed every two lines, but you must still must actively update the left and right sides of the screen every scanline. Please find attached the newest version of the kernel I am writing. I dropped the missile for player0, and it still aims to have multi-coloured Player0 and Player1. The code should be well numbered and virtually complete, however erroneous it is. The main issue I have run into now is that I wasn't updating the playfield every scanline. I was loading the left side on scanline 1,and loading the right side on scanline 2. This would look horrible. It would have a shearing effect on the playfield graphics. What would happen is that you would have the left side drawn three times, and then the right side drawn once, I think. It would look like this: PF0 -- @55-22PF1 -- @66-28PF2 -- @0-38So I think I will have to update the playfields like this: I may have to write more than a 2 Line Kernel. Either that or I have to give up an asymmetric playfield. I think using Player Graphics in order to draw the environment is looking more and more likely. Either that, or I need to find a faster way to draw an asymmetric playfield. What I am currently using to draw the playfield is a 5 cycle Indirect Indexed opcode, followed by the write to the register: DoDraw for the player with no colour: 15 cyclesDoDraw for the missile: 14 cyclesCalculating the playfield scanline colour: 8 cyclesDoDraw for the player with colour: 18 cyclesDrawing the player with no colour: 3 cyclesDrawing the player with colour: Loading the colour from pointer (5 cycles) Writing to COLUPX (3 cycles) Extra cycles to handle Indirect Indexing for the player graphics (3 cycles) STA GRP0 (3 cycles) 14 cycles all up. I think I could shave some cycles off this. I think instead of doing this: LDA (Player0Ptr),y - 5 STA Player0GFX - 3 LDA Player0GFX - 3 STA GRP0 - 3 (Total: 14 cycles) I could do this: LDA (Player0Ptr),y - 5 TAX - 2 STX GRP0 - 3 (10 cycles) Which saves 4 cyclesSo assuming I MUST change the colour of the playfield graphics every line, I use up 56 cycles every scanline drawing the asymmetric playfield using Indirect Indexed addressing. That means I have 20 cycles left every line to do other things. My immediate thoughts right now are: I can sacrifice missiles for the NPCs, but now for Che Sacrifice the asymmetric playfield Sacrifice colour for the players Make a 3 or 4 line kernel (I have no idea how to do this) Draw the environment with Player Graphics (Not sure how to do this) Find a faster draw routine (is SkipDraw faster?) I know there is SkipDraw, FlipDraw, DoDraw, and SwitchDraw. Apparently DoDraw is the slowest. I think I'll have to give up on anymore work today and have a rest. I'm at the stage now where I can't remember how to add up numbers. Attached File(s) coloured_guerrilla003.asm (8.76KB)Number of downloads: 0 http://atariage.com/forums/blog/703/entry-14362-guerrilla-game-4/ Link to comment Share on other sites More sharing options...
