jum Posted December 4, 2017 Share Posted December 4, 2017 Quick question for advanced Lynx programmers - is it possible to clear the collision buffer AND write non-zero collision numbers to it using just one "background" sprite? At the moment I am drawing a 1-pixel background sprite with collision number 0, stretched to fill the screen. This clears the screen buffer AND the collision buffer. Then I am drawing my "playfield" sprite, which has collision number 1. Is there some trick where I can just draw my playfield sprite, and the transparent pixels write collision number 0, while the opaque pixels write collision number 1? Or am I dreaming? Quote Link to comment Share on other sites More sharing options...
+karri Posted December 4, 2017 Share Posted December 4, 2017 I believe that you could set the collision buffer to your write page buffer and draw it in one go by setting it as a background sprite so that all pixels are drawn. Quote Link to comment Share on other sites More sharing options...
sage Posted December 4, 2017 Share Posted December 4, 2017 Thats maybe not the way the collision buffer should be used. But yes you can initialize with other numbers. but why would you want to? Any sprite will fill the collition buffer with its "collision number", if the sprite has correct type and collision is on. Transparent pixel <!=> uncollidable pixel -> read the docs. Quote Link to comment Share on other sites More sharing options...
jum Posted December 4, 2017 Author Share Posted December 4, 2017 (edited) Thanks Karri and Sage. Karri - drawing sprite to the collision buffer directly is an interesting idea. Problem is that it does not save me any sprite draws, I still need to draw to the display buffer too. (Edit: actually I might try this, as it should be faster than a sprite writing to display buffer and collision buffer). Is there any source code out there that does this? Sage - true, however what I want is to write 0 to collision buffer for transparent pixels, and 1 to the collision buffer for opaque pixels. (ie: "clear" the collision buffer where no playfield is, and write 1 to collision buffer where there is playfield) My current collision code is correct and work properly, I was just wondering if there was a faster way to do it. Edited December 4, 2017 by jum Quote Link to comment Share on other sites More sharing options...
+karri Posted December 4, 2017 Share Posted December 4, 2017 You could create a small asm file for drawing the sprite to the collision buffer. Just replace DRAWPAGE with the address of the collision buffer. draw_collision_sprite: ; Draw it in collision buffer sta SCBNEXTL stx SCBNEXTH lda DRAWPAGEL ldx DRAWPAGEH sta VIDBASL stx VIDBASH lda #1 sta SPRGO stz SDONEACK @L0: stz CPUSLEEP lda SPRSYS lsr bcs @L0 stz SDONEACK lda #TGI_ERR_OK sta ERROR rts 1 Quote Link to comment Share on other sites More sharing options...
sage Posted December 6, 2017 Share Posted December 6, 2017 No, I dont thing this is possible in one step. 1 Quote Link to comment Share on other sites More sharing options...
+karri Posted December 6, 2017 Share Posted December 6, 2017 No, I dont thing this is possible in one step. True. Drawing to collision buffer won't display anything on the screen. So you have to do this in two operations. 1 Quote Link to comment Share on other sites More sharing options...
jum Posted December 11, 2017 Author Share Posted December 11, 2017 (edited) So a quick test: 1. Draw "clear" sprite to clear draw buffer and collision buffer, followed by a "playfield" sprite with collision enabled (1 call to Suzy) : snap_clearSCB.bmp 2. Draw playfield sprite directly to collision buffer, then draw it to the draw buffer (2 calls to Suzy): snap_directCollClear.bmp The green area shows how many hcounts it took to draw. If you can believe Handy, then method 2 is way faster. (If you don't want to download/look at the images, then method 1 takes almost a whole frame, and method 2 takes about 60% of a frame = 60 hcounts). Results can be predicted from: Method 1: - Draw clear sprite = 75% of "normal" sprite draw time (NSDT), as it does not have to read pixels (write only) - Draw playfield sprite = 100% of NSDT - Total = 175% of NDST Method 2: - Draw background non-collideable sprite to collision buffer = 66% of NDST - Draw background non-collideable sprite to draw buffer = 66% of NDST - Total = 134% of NDST So you would expect method 2 to be about 30% faster, even before implementing it. (Also, why does it take almost a whole frame just to clear the draw buffer and collision buffer?) Edited December 11, 2017 by jum Quote Link to comment Share on other sites More sharing options...
+karri Posted December 11, 2017 Share Posted December 11, 2017 While I was writing "Always winter, never Christmas" I found out that at least Mednafen is so much faster than a real Lynx. So I would prefer to get these test results from a real Lynx if possible. The result sounds reasonable. The collision buffer is probably a great idea when dealing with random areas. But when you have a large, full-screen rectangle then drawing the whole area twice is faster than trying to draw into two buffers at once. Quote Link to comment Share on other sites More sharing options...
jum Posted December 12, 2017 Author Share Posted December 12, 2017 While I was writing "Always winter, never Christmas" I found out that at least Mednafen is so much faster than a real Lynx. So I would prefer to get these test results from a real Lynx if possible. The result sounds reasonable. The collision buffer is probably a great idea when dealing with random areas. But when you have a large, full-screen rectangle then drawing the whole area twice is faster than trying to draw into two buffers at once. I will test on real Lynx (using SD card adapter) and get some screenshots. Quote Link to comment Share on other sites More sharing options...
LordKraken Posted December 12, 2017 Share Posted December 12, 2017 While I was writing "Always winter, never Christmas" I found out that at least Mednafen is so much faster than a real Lynx. Well that's probably not true with Handy But I agree, testing on real hardware makes sense when you're benching/profiling stuff. Quote Link to comment Share on other sites More sharing options...
jum Posted December 12, 2017 Author Share Posted December 12, 2017 (edited) Comparison of the 2 screen clear methods, using Handy and using a real Lynx (note: real Lynx seems to be faster than Handy). Note: I think the frame rate is set to 75fps. If so I will do another comparision with 60 fps version. Edit: No difference when frame rate is changed to 60 using tgi_setframerate(60). Possibly tgi_setframerate() is broken? Edited December 13, 2017 by jum Quote Link to comment Share on other sites More sharing options...
+karri Posted December 13, 2017 Share Posted December 13, 2017 (edited) Thank you! There is a small difference. But even a small difference can be a game changer in fast games. You may be able to get one frame time less for every draw cycle. With Reiko's Robot Run the speed difference is the opposite. Emulation is faster. The same is true for sending sound samples directly to the speakers. Edited December 13, 2017 by karri 1 Quote Link to comment Share on other sites More sharing options...
+karri Posted December 14, 2017 Share Posted December 14, 2017 Comparison of the 2 screen clear methods, using Handy and using a real Lynx (note: real Lynx seems to be faster than Handy). Note: I think the frame rate is set to 75fps. If so I will do another comparision with 60 fps version. Edit: No difference when frame rate is changed to 60 using tgi_setframerate(60). Possibly tgi_setframerate() is broken? Strange. I have to check the framerate stuff. It is also used for the clock() function. And abcmusic. FD93 = PBKUP. Magic 'P' count, (W) reset = x,x,x,x,x,x,x,x INT((((line time - .5us) / 15) * 4) -1) At 60 Hz, 'PBKUP' = 41. (0x29) HTIMBKUP = $FD00 ; horizontal line timer (timer 0) rate50: lda #$bd ; 50 Hz ldx #$31 bra setRate rate60: lda #$9e ; 60 Hz ldx #$29 bra setRate rate75: lda #$7e ; 75 Hz ldx #$20 setRate: sta HTIMBKUP stx PBKUP Quote Link to comment Share on other sites More sharing options...
